Author Topic: V85 bevel drive seal leak  (Read 3302 times)
Offline Littlefield
« on: August 01, 2026, 04:00:53 PM »
I’m seeing a little oil at the drain hole just ahead of the final drive. I drained the oil and confirmed it was not overfilled, 160 ml.
Haven’t gone any further but I guess it must be the bevel drive input seal. Looking at the service manual I can’t tell if this is a do-at-home thing. Do you have to remove the pinion from the drive housing and disassemble it to get at the seal?
Offline Vagrant
Re: V85 bevel drive seal leak
« Reply #1 on: August 01, 2026, 06:50:41 PM »
They have now dropped to 130 cc max. Try that and a different brand first.
Offline yrunvs
« Reply #2 on: August 01, 2026, 07:41:43 PM »
I'm not doubting you but can you post a link or your source as to this new 130cc number?
« Reply #3 on: August 01, 2026, 08:14:19 PM »
Do a search on here it is well covered, most likely by Vagrent
Offline Littlefield
« Reply #4 on: August 01, 2026, 09:17:39 PM »
I can’t get the search to work. Digging around some more it sounds like the pinion seal replacement is straightforward.
Online ridingron
« Reply #5 on: August 02, 2026, 01:43:17 AM »
I just typed "How much oil in final drive?", clicked "search", and got back 10 links, all on this site. A couple were for other models so maybe add V85 to the question.
If that doesn't work, something is amiss with your computer.
« Last Edit: August 02, 2026, 01:48:40 AM by ridingron »
Offline yrunvs
« Reply #6 on: August 02, 2026, 07:20:57 AM »
So I typed in "How much oil in final drive" as suggested. What came up were some links from this site so I clicked on a link for the V85tt oil amounts and the amount of oil suggested and endorsed by Vagrant is 160cc. So let me again ask where the 130cc figure came from?
https://wildguzzi.com/forum/index.php?topic=112186.0
« Last Edit: August 02, 2026, 07:24:51 AM by yrunvs »
Offline kballowe
  • - Kevin the Great -
« Reply #7 on: August 02, 2026, 07:24:21 AM »
Google V85 oil leak.  Plenty of links there.
Offline yrunvs
« Reply #8 on: August 02, 2026, 07:56:16 AM »
Apparently the newer models owners manual references 130cc but that took some digging to reveal many threads stated the 160cc level and when I ask AI this is the answer I get (below). I wonder how many V85tt owners have heard about the 130cc level?
When I ask AI this is the answer I get.
Filling Guidelines
To prevent overfilling, it is advisable to fill with a maximum of 160 cc after draining the oil. This ensures that you do not exceed the capacity and helps maintain the integrity of the seals.
The V85TT final drive requires 180 cc (or 180 ml) of oil. However, it's recommended to fill with a maximum of 160 cc after draining to avoid overfilling.
Filling Guidelines
« Last Edit: August 02, 2026, 08:03:00 AM by yrunvs »
Offline Vagrant
« Reply #9 on: August 02, 2026, 08:12:24 AM »
180 leaked so they went to 160. It leaked so now it’s 130.
Look at a 26 bike or manual.
Offline JHBettsSr
« Reply #10 on: August 02, 2026, 08:19:18 AM »
This is from the 2Q000586 workshop manual for E5+ bikes:
'17 Triumph Bonneville T120
'13 BMW K1600GT
'25 Moto Guzzi V85TT
Offline yrunvs
« Reply #11 on: August 02, 2026, 08:43:48 AM »
Wow! 180 to 160 to 130 and you have to read the latest owners manual to get there.
Offline yrunvs
« Reply #12 on: August 02, 2026, 08:45:09 AM »
« Reply #13 on: August 02, 2026, 10:24:05 AM »
It was discussed here many times a while ago.  130 is the amount and it was referenced at the time.
Offline Moparnut72
« Reply #14 on: August 02, 2026, 10:45:45 AM »
The manual for my '26 V7 850 says 125 to 130 cc's. I don't know if the V85 is the same or not.
Kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline davethewelder
« Reply #15 on: August 02, 2026, 07:45:31 PM »
When I had a V85TT, it spewded gear oil out of the vent.  I was in some muddy trench and spinning the rear wheel and the Traction control would engage, so I figured that the quick stoppage would fling it out the vent.   I did drop the gear lube and reinstalled 160cm.
Offline Littlefield
« Reply #16 on: August 02, 2026, 08:28:03 PM »
Just an FYI, when searching for reasons the 2026 final drive oil capacity is reduced I got a couple of AI replies stating the new models final drives have been redesigned with a smaller housing therefore less oil.
Online Dr. Enzo Toma
« Reply #17 on: August 02, 2026, 08:36:34 PM »
AI responses don't actually know, if you want to know compare the parts diagrams and see which, if any, part numbers changed and go from there for a more informed dive into it.
My V7 850 only leaked out that swingarm hole when the final drive was chewing up gears from being improperly shimmed (not serviceable, per Moto Guzzi). When it was overfilled, it leaked from between the wheel and final drive. YMMV on the V85.
https://wildguzzi.com/forum/index.php?topic=123836.0
MGNOC Member
Online ridingron
« Reply #18 on: August 02, 2026, 11:19:51 PM »
I want one of those screw in plugs. Is that plug on your bike? What year/model.
« Reply #19 on: August 03, 2026, 01:10:50 AM »
The part number for that "max 130cc" etched plug is 2B012828. I bought one for my V7 850 after dealing with this same issue.
MGNOC Member
Offline Huzo
« Reply #20 on: August 03, 2026, 05:48:19 AM »
That makes sense, if you put zero in, it doesn’t leak at all…!
Offline yrunvs
« Reply #21 on: August 03, 2026, 07:25:29 AM »
The parts list for pre E5+ states
2B0068275 Complete transmission
I found E5+ parts list here.
https://oem-bike-parts.hr/en/parts/motoguzzi/v-85/2025/v85-tt-e5-2024-emea-eu-gso/engine-rear-transmission
Moto Guzzi V85 TT E5+ 2024-2026 (NAFTA)
Rear transmission
TRANSMISSION COMPLETE
2B013050
Back order
£933.73
So maybe 160cc is the correct amount for my 2022. That's the amount it's had in it for a few thousand miles and no leak yet.
« Last Edit: August 03, 2026, 07:32:21 AM by yrunvs »
Offline guzziart
« Reply #22 on: August 03, 2026, 08:00:18 AM »
Rear transmission
2B013050
Back order
£933.73
That's what I'm running in my '23 Travel, no leaks, etc.
Offline Huzo
« Reply #23 on: August 03, 2026, 02:47:03 PM »
I took the one made of Mozzarella out of mine @ 2,000 km and installed a German one. The original was as hard as a bull’s arse and leaked like a biscuit.
This one is perfect after 40,000 km and I refill with 150-160 ml.
I cannot bring myself to put 130 ml in, I blew my nose yesterday and more than that came out…!
Just seems cruel.
Offline Vagrant
« Reply #24 on: August 03, 2026, 08:33:47 PM »
As I recall the 2012 Gold wing uses 130 cc and all the heat from that engine and the exhaust pipes run right by it yet it survives. They just need lube. They don’t need to be drowned in oil.
« Reply #25 on: August 04, 2026, 10:53:55 AM »
Rear transmission
2B013050
Back order
£933.73
You would want to compare the rear transmission components rather than the completed assembly, as the revision of an individual component, such as the fill plug, may result in an updated part number for the completed assembly.
https://oem-bike-parts.hr/en/parts/motoguzzi/v-85/2025/v85-tt-e5-2024-emea-eu-gso/engine-rear-transmission-components
If it's not leaking, then stick to what works! :)
« Last Edit: August 04, 2026, 10:55:55 AM by Dr. Enzo Toma »
MGNOC Member
Offline Shorties178
« Reply #26 on: August 05, 2026, 04:54:35 AM »
I've always put 160Ml in my '20 Travel V85 since new. I have had a couple of instances of a small leak from that hole in the swingarm below the rear drive pinion, however after a wipe it always stopped. On a recent trip though I experienced a catastrophic leak from the main crown wheel seal. After fitting a new seal, I topped up with 180ml because of a total strip down. The bike only went 300km's and the seal blew again. THEN I read of Dr Enzo's troubles on another forum and learnt of the new fill amount of 130ml. So, after fitting another Crown wheel seal I only put in 130ml and after 6 decent day trips with plenty of 110km/h highway running it is still holding oil. Shame Guzzi could not issue advice notices to owners when they change amounts. It may have saved me a lot of money and a ruined holiday. I still don't understand though why 160ml has been ok for 60000km, nor why they will leak when they have a breather to relieve pressure.
Offline DoubleGuzzi
« Reply #27 on: August 05, 2026, 07:33:37 AM »
I still don't understand .. why they will leak when they have a breather to relieve pressure.
Likewise.
Nearly natural progression..
Online ridingron
« Reply #28 on: August 05, 2026, 10:37:06 PM »
I really doubt Guzzi redesigned the final drive housing.
The breather isn't breathing?
A seal isn't sealing?
The pressure has to go somewhere. The pressure goes through the weakest seal, be it the actual seal or the breather.
Offline Vagrant
« Reply #29 on: August 06, 2026, 08:15:03 AM »
Lack of QC!
