Clock disconnect
Topic: Clock disconnect (Read 1490 times)
Swedemoto
Gosling
Clock disconnect
May 24, 2016, 01:52:00 PM »
I have an '80 SP that I want to disconnect the clock. I have schematics, just want to make sure I do this right. To simplify this, can I just pull the No.6 fuse? Or pull the green wire? Thanks.
pehayes
Re: Clock disconnect
Reply #1 on:
May 24, 2016, 02:10:00 PM »
It appears from the wire diagram that #6 only powers the clock, so that should work. How about just pulling the spade connector off the back of the clock? Tiny bit of tape to protect the loose connector. Your preference.
rodekyll
Not my real name
Reply #2 on:
May 24, 2016, 02:12:27 PM »
NO!!!!! THE RED WIRE!!!!!
Swedemoto
Gosling
Reply #3 on:
May 24, 2016, 02:30:11 PM »
I'll give that a shot. seems the simplest way. I didn't see a red wire!
Clock disconnect
