Author Topic: 120 rear tyre - LM2...  (Read 1638 times)
Online Dukedesmo
« on: January 27, 2017, 10:29:16 AM »
Been servicing the LM2 today, mechanically everything is now spot-on.
The rear tyre is worn down to 1mm and both front and rear were on the bike when I bought it 2 yrs ago. Having checked the manufacturing codes they are both 10+ yrs old so I'm replacing the front as well and this also gives me a chance to check wheel bearings etc.
Currently fitted with Pirelli Sport Demons and these seem a decent tyre so I'll likely get the same again (I've long been a Pirelli man).
Front is a 100/90-18 and rear is a 110/90-18 and, being used to more modern bikes they do look super-skinny especially the rear.
I'm thinking I'd like to get a little wider at the rear but due to the proximity of the driveshaft there's not much room with just 7.5mm clearance between tyre edge and shaft.
Does/has anyone used a 120 rear? it should fit (5mm wider per side).
Any recommendations or tales of woe?
Le Mans II
Ducati 916
Ducati M900
Re: 120 rear tyre - LM2...
« Reply #1 on: January 27, 2017, 10:45:05 AM »
120 will fit but it won't handle or steer as well especially when the rear squares off.
kirby1923
« Reply #2 on: January 27, 2017, 11:05:45 AM »
I have a CX100/LM2 and have run 120/90 on the rear.
Not all 120/90s are the same dimension wise but I can tell you that the sport demons will fit fine.
What you have to be careful about is the clearance under the rear fender/mud guard.
It can destroy the wiring to the tail lights. Good idea to re-route (not hard to do) prevent the tyre having contact with same.
« Reply #3 on: January 27, 2017, 11:14:45 AM »
I have a 120 rear on mine and I won't install another one for the above reason. And the wheel won't roll when the bike is on the center stand when it's sitting on flat ground.
« Reply #4 on: January 27, 2017, 11:52:17 AM »
I used a 130/80 on the rear and 110 on front if I was touring on mine. 100 on the front for sport. I also put the shorter LM1 shocks on my LM3
Online Dukedesmo
« Reply #5 on: January 27, 2017, 12:20:36 PM »
Sounds like it's too much trouble for an extra 10mm that maybe would give an extra 3-4mm contact patch. I'll stick with the 110.    :thumb:
Le Mans II
Ducati 916
Ducati M900
Offline Stevex
« Reply #6 on: January 27, 2017, 12:23:56 PM »
I'm running Sports Demons on my LM2, personally find them a bit wooden, but that's probably as much to do with the
80's suspension as the tyres.
When the Demons wear out I'm going to give ContiClassicAttack Radials a go.
http://www.conti-bike.co.uk/conticlassicattack/
First read about them here:
http://www.guzzitech.com/forums/threads/conti-radial-review.16623/
kirby1923
« Reply #7 on: January 27, 2017, 12:35:16 PM »
I run classic attack radials 110/90 on the rear of my CX100.
Three so far, getting twice the mileage that I got on the Pirelli SD (8000) miles typical and good traction, (as good or better as the SD), and handling.
Since they ,(classic attack), produce only a 90/90/18 front and its a bit quick steering wise I run 100/80 BT 45 on front.
I'm happy with this combination.
« Last Edit: January 27, 2017, 03:30:45 PM by kirby1923 »
« Reply #8 on: January 27, 2017, 01:11:10 PM »
I've run a 120/90 rear tire on my CX100(LM2) for thousands of miles and unlike Roper found no issues with it's handling vs. a 110 rear.   It gives you about 125 taller rpm (makes your speedo more accurate) and I got 10K to 18K miles out of my rear Bridgestone S11 & Dunlop 491.   1 time I put a 110/90-18 front tire on it and that was a disaster!  But a 110/90-16 on the front works great.  :thumb:   Have ridden my CX for 94K miles.
« Last Edit: January 27, 2017, 09:30:04 PM by Arizona Wayne »
