Author Topic: Stelvio fork...male slider connection to casting.  (Read 2565 times)
Offline pyoungbl
« on: June 16, 2017, 01:27:23 PM »
On the Stelvio NTX you will find upside down forks.  The male part is attached to a cast fitting which incorporates mounts for brake caliper, axle, and front fender.  The male part appears to be a press fit into said casting.  Am I correct in thinking that it's press fitted?  Guzzi only sells the part as an assembly and when I tried to unscrew the part nothing budged.  My problem is that it is possible to rock the chrome cylinder in that casting, ever so slightly.  I can actually see fluid moving in that joint.  This appears to be the source for the fork oil leaking on that leg.  Unless I am missing something the only solution is a new part....about $460.  Any ideas?  I'm not going to take a chance on a part from a wrecking yard!
Peter Y.
Oh, and this means I will not be taking the Stelvio on my 2 week trip starting Sunday.  My trusty V7 get the nod this time.
'13 V7 Special (red/white)
Offline ChuckH
Re: Stelvio fork...male slider connection to casting.
« Reply #1 on: June 17, 2017, 04:57:57 AM »
Peter,
I suggest you PM Mark Elliott (Markcarovilli on this site).  He bought my '12 Stelvio (the cool orange color) and I know he rebuilt the forks last winter.
Chuck
« Reply #2 on: June 17, 2017, 05:44:01 AM »
The castings are apparently threaded on to the bottom of the Staunchion and require some sort of special tool to remove. Beyond that I know nothing because I farm out all my serious suspension work to a specialist who is much more experienced and smarter than me.
Offline Phang
« Reply #3 on: June 17, 2017, 06:30:50 AM »
This youtube video shows how to separate them.
https://youtu.be/wADxhvP40Rw
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline pyoungbl
« Reply #4 on: June 17, 2017, 11:32:29 AM »
Phang, thanks for the video.  We have a different design; no set screw on the stanchion and no holes in the tube to turn the tube.  I'm pretty sure the tube is a press fit not threaded.  Guzzi and Aprilia only sell the tub/stanchion as an assembly.
Chuck, a rebuild does not require taking the tube out of the Stanchion.  I'll PM Mark to see if he discovered a way to take these apart.
Peter Y.
Offline Phang
« Reply #5 on: June 17, 2017, 11:41:27 AM »
my bad, I shouldn't assume it is similar to my Griso SE.
the Showa on the Griso have threaded tube and available separately.
Offline pyoungbl
« Reply #6 on: June 17, 2017, 03:27:34 PM »
After I sent my last I thought it best to actually take a very close look at the staunchion and tube.  Press fitting seems excessive.  This time I did find a tiny set screw.  Nevertheless, there are no holes to use to turn the tube.  Pete might be correct, some kind of special tool to get this thing apart.  Darned if I can figure out how any tool could grip the tube.  You are lucky to be able to just get the tube by itself.
Offline Markcarovilli
« Reply #7 on: June 17, 2017, 03:33:49 PM »
Could a srap wrench work - will grip pipe really well and they sell them to grip polished pipe...
Mark
« Reply #8 on: June 17, 2017, 04:22:32 PM »
Get a piece of aluminium bar and turn the centre out to JUST allow the fork to slide in. Then cut a slot in the aluminium bar to allow for contraction when you grip it in a vice. You can the put a suitable bar through the lower axle hole and wind it off. A square aluminium bar will work best. Don't grip the stanchion anywhere that a seal runs.
« Last Edit: June 17, 2017, 04:24:44 PM by Huzo »
Offline Bonafide Bob
« Reply #9 on: June 17, 2017, 04:36:44 PM »
 I use one of these to grip the fork tubes.
https://www.ebay.com/i/262151705217?chn=ps&dispItem=1
« Reply #10 on: June 18, 2017, 02:21:03 AM »
Yep, hard to improve on that I reckon. I just tend to go to the shed and do what I know how, but sometimes I'd be better served by researching what's available.
