Author Topic: 2014 Norge  (Read 4503 times)
Offline inditx
2014 Norge
« on: August 04, 2017, 02:44:58 PM »
Searched but didn’t find if anyone has used the helibars on a 2104 Norge? The same ones listed for Breva and Norge up to 2010 I mean.
inditx
This is the day.....
Online PJPR01
Re: 2014 Norge
« Reply #1 on: August 04, 2017, 03:03:25 PM »
Helibars are only available up to the 2010 Norge Model, but not for later years.
You'll have to find an alternative setup for handlebar modification...
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline JeffOlson
Re: 2014 Norge
« Reply #2 on: August 04, 2017, 05:00:11 PM »
I looked for those, too, for my 2014 Norge. I even contacted Hellibars. No luck.
I wonder how difficult it would be to fabricate an S-bend in a couple of short handlebar pieces, plug the pieces into the existing brackets, and re-attach the handgrips, etc...
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline ITSec
Re: 2014 Norge
« Reply #3 on: August 04, 2017, 06:23:29 PM »
The HeliBars for the earlier bikes put their grips in almost exactly the same position as the stock risers do on the 8v bikes. Thus, there was not the same demand for the modifications. I believe some owners of later bikes have had riser blocks machined that sit between the stock risers and the base plate on the triple tree, using longer machine screws to allow the block to simply be sandwiched in...
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline old as dirt 2
Re: 2014 Norge
« Reply #4 on: August 05, 2017, 09:00:28 AM »
I was also toying with the same idea using some rox risers.
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
Online Trialsman
Re: 2014 Norge
« Reply #5 on: August 05, 2017, 11:36:50 AM »
That is exactly what I did and it worked out perfectly for my '15 Norge.  Just be aware that the bar units are dampened so they need to "float" not tighten to crush.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
Offline Huzo
Re: 2014 Norge
« Reply #6 on: August 05, 2017, 12:37:22 PM »
What is the general consensus as to why they need to be raised ? I'm just interested that's all. There's a lot of support for the practice, so it must have some credence to it.
Offline lorazepam
  • Almost ready for suspenders
Re: 2014 Norge
« Reply #7 on: August 05, 2017, 06:50:11 PM »
Old farts with big bellies who don't want to lean forward.
Offline Huzo
Re: 2014 Norge
« Reply #8 on: August 05, 2017, 11:36:18 PM »
Ok, that's honest. I'm an advocate for modifying the 'bar where it exits the top of the casting, such that your wrist does not kink and your palm sits evenly across the grip. The bars on the Norge are unnecessarily wide, I took off the up/down switches for the screen and made new bars 40mm shorter, coupled with the rotation I mentioned, I suggest that a lot of the effect you're after is achieved. Check this out..
« Last Edit: August 06, 2017, 08:50:39 AM by Huzo »
Re: 2014 Norge
« Reply #9 on: August 08, 2017, 08:05:24 PM »
what did you do with the windshield switches? I don't see them in the pic.
2013 Norge
2008 MP3 500
Offline Gliderjohn
Re: 2014 Norge
« Reply #10 on: August 08, 2017, 08:24:58 PM »
Don't see any windshield height switches either.???
East Mountains, NM
Offline ITSec
Re: 2014 Norge
« Reply #11 on: August 08, 2017, 09:35:03 PM »
Looking carefully at the full size image, there's some kind of switch just above the ABS button. Might be it...
ITSecurity
Offline Huzo
Re: 2014 Norge
« Reply #12 on: August 09, 2017, 12:59:29 PM »
A 2 way switch just above the ABS switch
« Last Edit: August 09, 2017, 01:06:11 PM by Huzo »
Offline inditx
Re: 2014 Norge
« Reply #13 on: August 16, 2017, 03:49:31 PM »
Sweet!
inditx
Offline Huzo
Re: 2014 Norge
« Reply #14 on: August 17, 2017, 12:12:10 AM »
Sweet!
Yeah that set up on the standard Norge is garbage. Dumping those silly switch blocks means you can have the 'bars 40 mm shorter EACH side and that increases the effectiveness of the fairing markedly.
Offline ITSec
Re: 2014 Norge
« Reply #15 on: August 17, 2017, 01:59:58 AM »
Personally, I prefer the bars in their original width. I added the handguards from the Stelvio instead. I did change out the switches for two-way momentaries as described elsewhere, which let me put the cruise control accel/decel on the left, and the windshield in a single switch on the right.
ITSecurity
Offline Huzo
Re: 2014 Norge
« Reply #16 on: August 17, 2017, 02:55:38 AM »
I know that your particular Norge is a well used and well sorted piece of kit. I respect your opinion, so to that end, why do you like the 'bars so wide, given that it's universally accepted that the Norge is a nice light neutral handling bike? And would you agree that the grips do not allow you to ride with your wrist straight, or if you do, your palm is not resting evenly on the grip ? Just interested, that's all..
Offline Huzo
Re: 2014 Norge
« Reply #17 on: August 17, 2017, 02:58:14 AM »
Sweet!
I had a look back at previous posts (for once), but didn't see. Is your bike a Norge, or are you chasing one, inditx?
Offline ITSec
Re: 2014 Norge
« Reply #18 on: August 17, 2017, 12:38:26 PM »
Maybe my arms or shoulders are different from yours. I do have the HeliBars on it which does change the position somewhat, but not as dramatically as your approach (I believe you said 40mm each side). I find the wrist position with the HeliBars is pretty much perfect for my physiology; the angle is changes slightly from stock. From my perspective, I'd turn the question around: given that the Norge has such nice, neutral handling, why do you want a 3.5" narrower, higher effort steering design?
My primary long-distance bike prior to the Norge was a Suzuki DL1000 V-Strom. I found I really like having a wider bar with less steering effort required. I've never found the bar design I have has been a problem in the twisties, or prevented me from reacting quickly.
My point in making my comment was to say that solutions for handlebars are going to vary as much as do the riders - and that I've never felt a need to go to a narrower hand location than that provided with the Helibars (about 15mm per side inwards but more than that back and up, which is what I really got them for).
BTW, I have ridden bikes with narrow bars and with clip-ons, and they have their place. In my view that's mostly on a track, but I do like the riding position of the Griso.
ITSecurity
Offline Huzo
Re: 2014 Norge
« Reply #19 on: August 17, 2017, 12:50:26 PM »
Yeah look I guess that's all completely fair IT. I'm not a really big guy across the shoulders, if I was, maybe my arms would diverge at a lesser angle and therefore the wrist issue would not even have arisen. So to that end , fair enough.
As for the question as to why I wanted a heavier steering bike, I'd have to admit that the Physics bear you out, but I cannot spot the difference. So I thought that since the bars are feather light with respect to steering inputs, anything that rendered them a little heavier, even if it's not discernible, would be an acceptable alteration. The blood and guts of it all was, the narrowing of the bars, brings your hands back within the protection zone of the fairing and it looks less like a dirt bike also.
