Author Topic: cast wheel mod to fit lemans 3  (Read 1871 times)
Offline roadron
« on: March 07, 2019, 07:43:28 PM »
I want to fit a cast wheel made for 195mm fork spacing to  lemans 3 forks with the 180mm spacing . I have the lemans 3 deep dish discs to be fit. It looks like I can machine the mounting bosses down to fit the lemans 3 discs . Doable? How much needs to be milled off the bosses each side?
« Last Edit: March 09, 2019, 06:59:52 PM by roadron »
83 Lemans café project
98 ducati 900ss final edition
58 bmw sidecar rig
Offline mtiberio
    • TiberioRacing
Re: cast wheel mod for lemans 3
« Reply #1 on: March 07, 2019, 10:10:11 PM »
Quick answer: "enough to center the rotors under the calipers". Most 195 front ends had 25mm of offset in the rotors, so the hubs are a lot wider than the 180mm Lemans 1 or 3 front ends with their deep dish rotors. What the exact offset of those deep dish rotors is, escapes me at the moment, otherwise it would be trivial to calculate. I believe I have seen a CX100 (195 front end) with Lemans 1 wheels and rotors but with a 7.5mm spacer between the rotors and hub.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Tusayan
« Reply #2 on: March 07, 2019, 10:53:07 PM »
I believe you're correct and that the CX100 came with those aluminum spacers. I'd assume the LM II did too.  I probably have a set of them because about 30 years ago I put a set of Marzocchi Strada forks on my CX, supplied to fit a LM III, and that involved removing the spacers.  Their exact thickness, I cannot say...
Offline DAMMAG
« Reply #3 on: March 08, 2019, 02:24:58 AM »
I installed LM1000 wheels on my LM3 using the LM3 disks. Is this the sort of thing you are doing?
I "simply" got some carriers machined to suit the wheel, the disks and the offset.
Offline roadron
« Reply #4 on: March 08, 2019, 10:34:58 PM »
Looks like I need to remove 15mm each side from what i'm seeing here
58 bmw sidecar rig
Offline roadron
« Reply #5 on: March 09, 2019, 01:28:10 PM »
I found a pic of a lemans 1 wheel. Looks like I'll have to machine much more than 15mm so my calculation is off .
58 bmw sidecar rig
Offline roadron
Re: cast wheel mod to fit lemans 3
« Reply #6 on: March 09, 2019, 07:02:51 PM »
does anyone know the width boss to boss on a lemans 1 or 3 or cx100 boss to boss?
58 bmw sidecar rig
