Author Topic: California Vintage - Protect the Panniers  (Read 1795 times)
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
« on: March 08, 2019, 05:21:48 AM »
I want to protect the panniers of my CalVin against abrasion caused by the holders in the area marked in red.
I do not want to bend the holders because they just got new chrome.
Has anybody a smart idea (rubber, etc.)?
« Last Edit: March 08, 2019, 05:23:09 AM by janguzzi »
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Re: California Vintage - Protect the Panniers
« Reply #1 on: March 08, 2019, 06:05:21 AM »
IRC Racers Tape.
www.findtape.com.  Get the 8 mil thick.
Offline janguzzi
« Reply #2 on: March 08, 2019, 07:23:03 AM »
Cannot find it ...8 mm thick tape?
Maybe Armaflex HT tape ...
Kind Regards
www.janguzzi.de
Offline leafman60
« Reply #3 on: March 08, 2019, 07:41:19 AM »
Maybe.
Buy some industrial strength Velcro (or similar) in black.  Use the soft side part to apply an abrasion resistant surface to your contact points.
https://www.velcro.com/products/industrial-strength/900400__industrial-strength/
« Last Edit: March 08, 2019, 07:44:07 AM by leafman60 »
Offline RinkRat II
  • Lake Powell AZ
« Reply #4 on: March 08, 2019, 08:15:09 AM »
 Google "spiral cut tubing".  You should find it at a hardware store or on line. Comes in colors and clear and works around corners.
     Paul B :boozing:
Offline Zoom Zoom
« Reply #5 on: March 08, 2019, 10:04:49 AM »
Some good ideas. I'm curious what color the bike is. White or Black. I also guess there is a little space there and even when the bags are mounted, there is a certain amount of vibration.
So, here are my thoughts. Even if you use the soft side of the velcro, there could be some abrasion to whatever surface is rubbing against it. I'm taking into consideration that it will trap dirt and eventually scuff the piece rubbing against it. Using both pieces stuck to both sides would help prevent that.
With regard to using rubber: Lets say that the bags are black or your concern is greater than looks, which by the way, would likely not be impacted. If it were me, I would get a roll of double sided tape from the hardware store. Gorilla Tape would work good for this. It is just a little thicker than scotch tape but sticks amazingly well. With the bags in their correct mounting location, use masking tape to locate the spots on the bag where you want some abrasion resistance. Inside those 4 rectangles, attach the Gorilla tape and attach a strip of old inner tube to that. Be sure to allow enough width of the rubber strips to allow for the small bit of movement that you are [evidently] concerned with.
Just remember that whatever you put there, there is a high probability dirt will get into the space as well. Just take that into consideration.
John Henry
« Last Edit: March 08, 2019, 12:44:32 PM by Zoom Zoom »
Offline janguzzi
« Reply #7 on: March 09, 2019, 02:13:57 AM »
Thank you for all the feedback so far!  :thumb:
« Last Edit: March 09, 2019, 02:14:13 AM by janguzzi »
Kind Regards
www.janguzzi.de
