Author Topic: V1100 Engine Connecting Rod Installation  (Read 1833 times)
Offline John Croucher
« on: March 15, 2019, 06:13:27 PM »
Does the hole/oil passage in the side of the connecting rod go up/away from oil pan?  I did not note this during disassembly and the manual says to follow "disassembly directions in reverse" when installing rods.
 Following disassembly instruction in reverse did not happen I can assure you.
Offline Idontwantapickle
Re: V1100 Engine Connecting Rod Installation
« Reply #1 on: March 15, 2019, 06:45:16 PM »
Yes, on the high side.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline TOMB
« Reply #2 on: March 16, 2019, 08:54:59 AM »
The machined sides of both con rod faces the right side of the bike as your sitting on the bike.
Been that way since the 70's.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #3 on: March 16, 2019, 09:40:15 AM »
TOMB
Both sides of the rods are machined.  One side does have a code number for matching up caps. On the opposite side of the oil passage hole.  Now that I think about it,  the code was down and could be seen from the open oil pan, making the hole on top.
Thanks for the help.
