Author Topic: Is this a fallacy ?  (Read 9667 times)
Offline Huzo
Is this a fallacy ?
« on: March 21, 2019, 05:37:06 PM »
I’ve long read the comment regarding how a bike will change angle of lean quickly due to the “low centre of gravity”.
I have a working man’s level of scepticism regarding this but welcome educating.
As I see it, when you introduce an input from the ‘bars, the wheels are displaced laterally and the centre of mass initially tries to remain in the same plane of motion, centred somewhere around your nether region.
Hi there Isaac....!
Akin to, if you get a broom and stand it vertically on your palm, brush upward, you can keep it upright by moving the point of support around the C of M. The heavier is the head of of the broom, the quicker you can move your palm due to the higher centre of mass.
When you push on the bar of your new V85, the wheels will be moved an amount, out from under the C of M and the bike will begin to fall over, until the COUNTERSTEER...! Takes effect and balance is restored.
So in the real world, I’m suggesting that a given bike would be more “flickable” with a bag of cement strapped to the tank than without....!
Different thing in the static state at the lights though..
Comments...?
« Last Edit: March 21, 2019, 08:32:42 PM by Huzo »
Offline malik
Re: Is this a fallacy ?
« Reply #1 on: March 21, 2019, 06:27:51 PM »
Hugo, you seem to like mind stretches, concept manipulation - have you read "The Upper Half of the Motorcycle, on the unity of rider & machine", by Bernt Spiegel. Recommended. I think you'd like it. For example - part 1 is entitled "It's a miracle that motorcycling works at all".
« Reply #2 on: March 21, 2019, 06:40:30 PM »
 It is more complicated than that Huzo . Mighty Honda experimented with fuel tanks placed really low , not unlike a modern Gold Wing on their GP bikes sometime around 1990 . The results were mixed , apparently the bikes became more stable at really large lean angles and high speeds , but resisted quick steering inputs . On a GP bike with stupid steep steering head angles this wasn't a big deal , but the riders claimed it *felt weird* , so Honda gave up on the idea . As a general rule , at slow speeds a higher CoG is beneficial , at higher speeds like a GP bike is capable of a lower CoG is better . Confused yet ?
 So like so many other hard and fast rules , it kinda depends . Probably for street purposes a CoG a around the gap between the fuel tank and the top of the engine is about right, depending on steering geometry and wheelbase .
 Oh , heavier bikes probably work better with a slightly lower CoG , really light bikes don't seem to care as much , then again we are now dealing with center of mass, which is different than CoG .
« Last Edit: March 21, 2019, 07:33:50 PM by oldbike54 »
Offline Aaron D.
« Reply #3 on: March 21, 2019, 06:47:21 PM »
As usual Dusty is pretty much spot on. Honda figured it out in the '80s. You can do the vectors if you wish but..
I prefer bikes with lower center of gravity. They feel like fun. A modern trials bike would be too far for a street bike but I liked the horizontal singles I've ridden.
Offline fubar guzzi
« Reply #4 on: March 21, 2019, 07:28:15 PM »
 :popcorn:  between Huzo + dUSTY MY HEAD IS SPINNING===EITHER TOO MUCH makers Mark or===lack of education on my part :weiner:
Offline yogidozer
« Reply #5 on: March 21, 2019, 07:46:18 PM »
Picture a lollipop. One standing with the pop on top, the other with the pop on bottom.
Which would tip over easier?
« Reply #6 on: March 21, 2019, 07:56:24 PM »
Phil Irving wrote a book, Motorcycle Engineering . It's my go to book for questions like these for it covers this as well as other good stuff.  When I go out to the shop tomorrow I'll look at it.  See if you can find a copy, it'll make you the smartest guy in the room.
Offline Huzo
« Reply #7 on: March 21, 2019, 08:17:21 PM »
Hmmm...
Just a couple of quick ones Dusty.
A bike does not “know” it is leaned over in a balanced turn because the sum of forces are zero, other than the centripetal force accelerating it towards the centre of the circle..
and
Why is the centre of mass different than the centre of gravity, when the sum of gravitational vectors acts through the centre of mass ?
Offline Huzo
« Reply #8 on: March 21, 2019, 08:22:37 PM »
I’m a big supporter of blind loyalty Aaron, but I was addressing the voracity of the statement that a bike is more “flickable” due to it’s “lower centre of gravity”.
If I wanted muddy waters, I’d go for a dip in the Mississippi, or put on a CD of an old blues man..
Just a bit of focus on what I was asking about and a response based on physics, not “how you feel”, or what you (or I), “prefer..”
« Last Edit: March 21, 2019, 08:36:53 PM by Huzo »
Offline Huzo
« Reply #9 on: March 21, 2019, 08:25:57 PM »
The one with the pop on top is inherently more statically unstable, but can be stabilised more readily by moving the point of support back under the mass when displaced from vertical than the upside down one.
Put the one in the picture on your hand and balance it by moving your palm, you’ll have some success.
Now try moving the pop halfway down the stick, you’ll have less success maintaining dynamic stability.
When a point of support is moved under a mass to maintain balance, we rely on inertia to hold the c of m still, in a spatial sense as that point of support is re positioned.
« Last Edit: March 21, 2019, 08:38:07 PM by Huzo »
Offline Huzo
« Reply #10 on: March 21, 2019, 08:30:12 PM »
I already am, I’m the only guy in the room.. :rolleyes:
Offline Huzo
« Reply #11 on: March 21, 2019, 08:34:08 PM »
When considering this concept, the rider and machine are a single mass with only one centre of gravity (mass).
Offline Knuckle Dragger
« Reply #12 on: March 21, 2019, 08:42:33 PM »
Hmmm...
and
You're doin' my head in cobber.  One needs a few beers before contemplating this type of esoterica.  Mass carried high, i.e further away from the pivot will have greater inertia at speed (in relation to the arc of leaning motion, not the bike's linear motion).  Therefore, the whole mass becomes less 'chuckable' or 'flickable'.  Greater countersteering effort is required to counter not just the gyroscopic effect of wheels in rotation, but the 'arc of inertia' (my own ridiculously pompous name for it) of mass.  Once flicked or chucked over, the gyro effect counterbalances the combined mass through the bikes 'linear' cornering arc unless further attitude changes (lean angles) are called for, such as straightening up again.  Think of it as an arc of a pendulum.  The further away the mass is placed from the fulcrum, the greater the 'strain' on the pivot for a given velocity of motion.....  I think!  Bugger me, I'm not so sure at all anymore....
Sideways mobile masses have a greater effect the further they are from the pivot point.  Which is why leaning my own corpulent, portly arse to the inside of a bend off the bike's seat makes a substantial difference to lean angles: not the prettiest sight, but extremely useful in the wet.
« Last Edit: March 22, 2019, 02:12:31 AM by Knuckle Dragger »
Severus bastardis
« Reply #13 on: March 21, 2019, 08:53:37 PM »
 Well , not exactly , the rider isn't static . The rider can and does affect both center of gravity and center of mass . See , here is the problem , you attempting to answer the question W/O allowing for the variables . In the simplest terms , yes a higher CoG will allow the bike to be more flickable , until as you mentioned , other accelerative forces come into play .
 Oh , while the center of mass and the CoG will almost always be the same , once a rider is introduced , that changes .
 Ain't motorbike physics fun  :laugh:
Offline mtiberio
    • TiberioRacing
« Reply #14 on: March 22, 2019, 12:32:52 AM »
You're doin' my head in cobber.  One needs a few beers before contemplating this type of esoterica.  Mass carried high, i.e further away from the pivot will have greater inertia at speed (in relation to the arc of leaning motion, not the bike's linear motion).  Therefore, the whole mass becomes less 'chuckable' or 'flickable'.  Greater countersteering effort is required to counter not just the gyroscopic effect of wheels in rotation, but the 'arc of inertia' (my own ridiculously pompous name for it) of mass.  Once flicked or chucked over, the gyro effect counterbalances the combined mass through the bikes 'linear' cornering arc unless further attitude changes (lean angles) are called for, such as straightening up again.  Think of it as an arc of a pendulum.  The further away the mass is placed from the pendulum, the greater the 'strain' on the pivot for a given velocity of motion.....  I think!   Bugger me, I'm not so sure at all anymore....
You are correct, and it is officially called "moment of inertia".
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Huzo
« Reply #15 on: March 22, 2019, 04:13:01 AM »
Hmmm...
« Reply #16 on: March 22, 2019, 04:32:58 AM »
Dusty has done a nice job here.  I'll add, and I wish I could remember exact, but several years ago Kevin Cameron wrote about how MotoGP bikes has their COG and Moment of Inertia in such a way that the COG was higher up.  Something about a pendulum effect and getting the bike from one side over to the other quickly and with less effort.  Bottom line was the COG was not low.  There was also mention that a designer can get the COG below street level.
I don't remember all the engineering details but the fact that a MOTOGP bike (I know, not for the street!) didn't have that low GOG and for better, or worse, I stopped reading all the OEM marketing nonsense about it.
« Last Edit: March 22, 2019, 10:52:21 PM by kingoffleece »
Offline yogidozer
« Reply #17 on: March 22, 2019, 05:16:58 AM »
Which would cause more reaction, an input on the "pop on top" or the other one?
Hugo asked---how a bike will change angle of lean quickly due to the “low centre of gravity”.
Offline Huzo
« Reply #18 on: March 22, 2019, 05:45:49 AM »
That’s right Yogi.
All I wanted to discuss without diverging down side streets of unrelated analogies was...
Is a low c of g a benefit in enhancing “flick ability”, the answer I suggest is no. I’d like to get an answer from a Physicist, because our knowlege can be contaminated from years of conventional wisdom.
We must remember that when viewed from the front, a bike does not have the rider move about above the wheels to initiate a lean, the wheels move about below the rider.
Have you ever ridden too close to a gutter on your left  on your pushbike and tried to turn right to get away?
Sometimes you can’t because the wheels have to move out from under you to the left initially, to get the bike leaning to the right.
« Last Edit: March 22, 2019, 05:51:27 AM by Huzo »
Offline Aaron D.
« Reply #19 on: March 22, 2019, 06:37:13 AM »
Sheesh. Agreement is not blind loyalty.
« Reply #20 on: March 22, 2019, 08:11:46 AM »
It's a fallacy.
Sure, you can weave at slow speeds and displace the wheels laterally, but the rider has to force that.
In normal riding, steering inputs at the handlebars push the bike over.  The tires stay on the same line.
The steering input is resisted by the gyroscopic force of the wheels and the steering geometry.
« Last Edit: March 22, 2019, 09:27:43 AM by rocker59 »
Offline Testarossa
    • Skiing History
« Reply #22 on: March 22, 2019, 12:18:57 PM »
Talking about CoM and polar moment of inertia as they affect "flickability" doesn't make much sense to me -- other parameters must be just as important or more so. These would be mainly steering geometry (rake, trail, wheelbase) and gyroscopic effects (weight of wheel rims/tires, rotational speed) and overall inertia (mass x velocity). Comparing my Mille with my '70 Triumph, the Triumph is absolutely more flickable -- it's 20% lighter (including rider weight), the steering geometry is close (about 27 degrees rake for the TR vs about 29 degrees Tonti) and 55 inches vs 58 inches wheelbase. The Guzzi wheels probably have more rotational inertia. Full fuel vs empty weight is only a 4.5% difference in both bikes so I don't think the high tank much affects the height of the CoM. So quantifying "flickability" could be a complex equation.
« Reply #23 on: March 22, 2019, 01:20:03 PM »
Thinking I could hobble out to the shop, take down Phil Irving's excellent Motorcycle Engineering, scan through it, refreshing my feeble brain and be able to speak intelligently on the topic. After reading some of the first chapter: An outline of the Problem,  I understand I forgot most of the rest of the book and need a couple weeks to read it again.  Don't have time for that as its spring here and I have to get all the motorbikes ready.  back to the original post, according to Phil, there are two considerations to start off with: the crew sits ON the machine, Not IN it. the second is that, by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself. so when we put such a thing in motion, it is complex enough for me to have to read over it.
Offline rtbickel
« Reply #24 on: March 22, 2019, 01:24:54 PM »
Math is hard!  Did you make it around that last corner without falling over?  Its all good then! :evil:
2020 V85TT
« Reply #25 on: March 22, 2019, 01:30:38 PM »
that's the rub now aint it. My problem was that things were fine rolling down the road, but due to disease, my right leg wouldn't go down so id fall over at a stop. so on went a sidecar. everybody is happy!
Offline Noguzznoglory
« Reply #26 on: March 22, 2019, 01:53:46 PM »
the bike with the added upper weight would be more flickable in that that it would be easier to start the lean with the added weight that high. but once the lean is started the inertia of the extra weight would make it harder to stop that motion. it would tend to keep going over until another force stopped it.
relates to polar moment of inertia on a race car in which one attempts to keep the weight between the wheelbase. weight at the extreme ends makes the vehicle easier to rotate around the central axis (hanging the tail out) but harder to stop that rotation. think corvairs and porsches
93 750 Nighthawk
73 Honda CB350
73 Honda CL450
04 Breva 750
15 Norge
16 VERSYS 650
Offline Testarossa
    • Skiing History
« Reply #27 on: March 22, 2019, 02:43:08 PM »
There's a big difference between top-heavy and flickable. My VX800 felt topheavy -- it wanted to fall into slow turns -- but wasn't flickable. Thanks to a long wheelbase and I suppose relaxed head angle it felt stable in a straight line and in high-speed turns.
Offline Tusayan
« Reply #28 on: March 22, 2019, 03:46:46 PM »
I think low CG may be good when the roll rate is slow enough that the bike is rolling about the tire contact patch, and therefore the CG is changing elevation relative to the ground as the bike rolls.  Higher CG and lower roll moment of inertia (around the CG) works better when the roll rate is higher and the CG is not changing elevation, the suspension is instead extending or compressing during the period over which the bike is rolling.  The latter case is what a race bike more often does, hence Honda’s conclusion that low CG isn’t the point.
If ‘slow’ steering geometry means that the rider is not strong enough to roll the bike quickly, low CG is probably a good thing. The best example of that might be a bevel SS Ducati.
« Last Edit: March 22, 2019, 04:00:05 PM by Tusayan »
« Reply #29 on: March 22, 2019, 03:47:51 PM »
[/quot]
my point exactly
93 750 Nighthawk
73 Honda CB350
73 Honda CL450
04 Breva 750
15 Norge
16 VERSYS 650
