Author Topic: Who made this Loop fairing?  (Read 2761 times)
Offline T4halo
« on: March 22, 2019, 05:50:46 PM »
My new to me 1970 Ambassador came with floor boards, leg guards and this fairing. Wondering who made it and if it’s worth putting on the bike?  It has a little character but should clean up.
Thanks,
T4
7th & 10th SF retired
Re: Who made this Loop fairing?
« Reply #1 on: March 22, 2019, 07:07:28 PM »
That's the factory "polizia" or "Buffalo" fairing. Best protection of any handlebar fairing I've ever ridden behind. My '69 V700 and '69 Ambo both came with one, I added one to "Barney" the '71 Ambo.
« Last Edit: March 22, 2019, 07:10:28 PM by Antietam Classic Cycle »
Offline giusto
  • Giusto il canne del Como
    • photobucket
« Reply #2 on: March 22, 2019, 07:40:07 PM »
Thanks,
T4
Great to hear you found something you like. My ambo came with the same faring and it cant wait to get out of the garage....maybe this weekend if it warms up enough to melt the ice on my driveway
post some pics of the rest of the bike...where'd you get it?
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline Perazzimx14
« Reply #3 on: March 22, 2019, 07:41:22 PM »
Buffalo re-pops also available for $167.83 through MG Cycles. Never rode behind one but like the looks.
Offline T4halo
« Reply #4 on: March 22, 2019, 07:51:28 PM »
Thanks Frank. Found it here in southern MI.
Looked like this last week.
Now it looks like this.
« Reply #5 on: March 22, 2019, 08:14:43 PM »
Sure, you can buy the body and screen, but not the "special bits" - all of the mounting hardware, the aluminum trim and rubber gasket at the base of the screen. Greg Bender has drawings on his website so one could make the mounts, the aluminum trim is a little harder but still doable and I guess you could substitute a piece cut from a bicycle inner tube for the rubber gasket.
There are two different types: "short nose" for most Ambos and Eldos, and "long nose" for V700s and early Ambos with the deeper headlight bucket.
Guzzi made similar fairings for small-blocks and early Tontis.
Offline chuck peterson
« Reply #6 on: March 22, 2019, 09:22:20 PM »
Very super cool original bits....imho. I can see the important pieces thru the hole
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline T4halo
« Reply #7 on: March 22, 2019, 09:54:55 PM »
All the original mounting hardware is there. The handlebar mounts and headlight bucket bits have not been removed or lost. I cant believe how lightweight this fairing is. I cant wait to put it on and see how well it works.
T4
Offline bigbikerrick
« Reply #8 on: March 23, 2019, 11:15:29 AM »
That "Polizia" fairing is  IMHO the best you can get for a loop. The aluminum trim on the front, the mounting brackets ,and the special nuts that hold it onto the headlight mounts can be very hard to find. New , re pop windshields are available from MG cycle for less than $100.
 Once you ride behind a buffalo fairing, you will be hooked..Its that good!
I went from a Wixom ranger fairing, to the buffalo, and prefer the buffalo hands down. With the Wixom, you have to remove the fairing to check the fuses in the headlight bucket. I never liked that.
Another plus,is the buffalo fairing is very quick/easy to remove, and remount if you want to "go naked"! :thumb:
Rick.
