Ground for diode board
Topic: Ground for diode board (Read 1020 times)
ritratto
March 23, 2019, 03:22:49 PM »
Does anyone have have a photo or know exactly how the ground on a round head tonti diode board goes? Ground to the frame or battery? Thanks
1978 G5
1998 Centauro ( oppsidaisy!)
2003 V11 LeMans
wirespokes
Re: Ground for diode board
Reply #1 on:
March 23, 2019, 04:16:48 PM »
The diode board grounds through the negative side mounting bolts. I'm more familiar with the airheads that use the same Bosch charging system and that's how they work. I'm pretty sure my T3 and LM4 ground the same way. It wouldn't hurt anything to run a ground cable straight from the battery to the diode board, but making sure all ground connections are bright, shiny and clean would be good enough and all that's really needed.
