Author Topic: Question on installing engine guards on v7iii  (Read 9087 times)
Offline Rhodan
« on: March 24, 2019, 01:36:49 PM »
To install the givi engine guards, it looks like I need to remove the bolts that link the upper and lower part of the frame.  Besides only doing one side at a time, anything else to consider?
Never installed engine guards before.  Looks straightforward but removing the frame bolts did give me pause.  :huh:
The shop said it doesn't need locktite and there's no torque spec.
Offline F-22
Re: Question on installing engine guards on v7iii
« Reply #1 on: March 24, 2019, 01:49:27 PM »
Well, some blue loctite wouldn't hurt anything... It's a fairly large diameter screw for a narrow flange, so it could potentially loosen. The general recommendation/ standard for self-locking screw design is that the flange diameter is ~5x as tick as the screw diameter, which isn't true in this case (but e.g. very true for cylinder head studs).
« Reply #2 on: March 24, 2019, 05:38:39 PM »
Locktight it
Offline Rhodan
« Reply #3 on: March 24, 2019, 08:59:06 PM »
Thanks to you both.  Blue loctite it is.
« Reply #4 on: March 25, 2019, 09:44:35 AM »
I put a floor jack under the engine with just enough pressure to keep it from moving when I installed the MG engine guard.
Offline Rhodan
« Reply #5 on: March 25, 2019, 02:29:23 PM »
Not a bad idea.  I don't think I have my hydraulic floor jack any more but even a scissor jack with a hefty and wide piece of wood would work.
Out of curiosity:  have you seen them/heard about them moving or simply a precaution?
Were the bolts reasonably easy to remove or a pain in the patoot?
I did get a set of hex bits for my 3/8" ratchet.  Thought that would be better than trying to wrestle a regular hex key.  Even if it wasn't necessary, it was still a good excuse.   :wink:
« Reply #6 on: March 25, 2019, 02:34:45 PM »
I've done this both times I've installed sliders on our V7s.
The first time I used a jack to support it and worked on one side at a time.
Just last week I did it on the V7D and was able (because of the slider design) only remove one bolt at a time so I didn't even use a jack. I imagine you could remove a bolt and temporarily put a small pin or stud through the frame holes to keep them from possibly moving.
Yes a hex bit (instead of a hex wrench) is handy.
The nuts on the back seem to be captured from turning by the frame, but I still put a backup wrench on them when tightening just to be sure.
« Reply #7 on: March 25, 2019, 04:29:48 PM »
There is always a risk of moving.
On many of my bikes the aftermarket engine guards would use engine mounts and some guys would get themselves into trouble.  Better safe than sorry.
Of course, like Kev said, still do one side at a time.
« Reply #8 on: March 25, 2019, 11:06:31 PM »
I did one side at a time on my 2105 V7.  No issues-did not even need a jack.
« Reply #9 on: March 26, 2019, 01:38:23 AM »
I ground up a short podger to line the first hole up and put the bolts semi snugly in. then use the jack/engine hoist/levers to line up the second.
« Reply #10 on: March 26, 2019, 06:57:41 AM »
Better to have it there and not need it, than to find out you needed it and didn't have it there.   :angel:
Offline JRD
« Reply #11 on: March 28, 2019, 11:39:39 AM »
Kev, which engine guards do you use?
« Reply #12 on: March 28, 2019, 11:46:43 AM »
I used sliders on both my V7s. Over Racing for the Stone and Sato Racing for the Dark.
Offline JRD
« Reply #13 on: March 28, 2019, 02:21:39 PM »
Looking good, I’ll check them out.
« Reply #14 on: March 28, 2019, 07:38:35 PM »
I find extra lighting important, which is why I installed the Guzzi engine guards.
Offline Rhodan
« Reply #15 on: March 29, 2019, 03:35:48 PM »
Nice ride!
Offline Rhodan
« Reply #16 on: March 29, 2019, 03:41:16 PM »
Engine guards are finally installed.  Very anticlimactic.
I did end up using a jack as insurance but now that I've done it once, I think it would have been fine without.
Blue Loctite was used.
I did one side at a time.
The Guzzi and the Givi bolts/nuts were different sizes.  Not a problem, just a note.
The hex bits were REALLY handy but they hadn't torqued the heck out of the bolts so they weren't hard to get off.
I like 'em!
upload images
« Reply #17 on: March 29, 2019, 03:53:24 PM »
I like 'em!
upload images
Congrats.  Different sizes?  Or different lengths?
Offline Rhodan
« Reply #18 on: March 29, 2019, 04:02:59 PM »
Different sizes meaning I needed a different hex bit for the bolt head and wrench for the nut.  I think the length was the same or near to it.
I also wanted to say:  Thank You to everyone who had suggestions and shared their experience.
Online egschade
« Reply #19 on: March 29, 2019, 05:14:08 PM »
1) I like your color choice
2) The engine guards are a good place to mount driving lights
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline Rhodan
« Reply #20 on: March 29, 2019, 05:25:29 PM »
I'm trying to save all my spare watts for heated gear.  Just got this in the mail
https://www.aerostich.com/aerostich-electric-warmbib.html
How much do lights like that pull?  I like the placement; it must really light up the road.
« Reply #21 on: March 30, 2019, 06:53:58 AM »
My lights are LED and don't pull much.  Of course you can shut them off when using your heat.  Mine are for conspicuity during the daytime.  Need all the help we can get making sure drivers see us.
Offline JRD
« Reply #22 on: July 31, 2019, 11:40:23 PM »
Installed the Givi TN8202 engine guards on my V7III tonight. It went well overall, took about an hour. Center stand made it easy, also used a scissors jack to support the engine.
Struggled with one set of frame holes that weren’t properly aligned but the Givi bolt finally went through without stripping its threads. Used blue loctite for insurance.
The Guzzi service manual specifies torquing the frame bolts to 50 nm/~37 ft lbs but the 6mm socket walls in the Givi bolt heads started to strip at about 40 nm. They seem plenty tight though.
Well, that’s about it. I like the way they look (for engine guards) and hope they stay as clean and unscratched as they are tonight.
Offline Bobic69
« Reply #23 on: August 01, 2019, 01:44:58 AM »
Shame Sato don't make the sliders in black (or red for the Racer). They stand out like dog's balls in the natural aluminium.
Bellagio
« Reply #24 on: August 01, 2019, 05:32:27 AM »
Probably be easy enough to powdercoat if that's an issue.
Funny I've often powdercoated parts black in the past including a few sets of HB side and top case carrier racks before they started offering them in g black too, but it never occurred to me to want to do so with the Sato slider mounts. Maybe that's because there's already so much black on the IIID that a little bright work doesn't bother me.
Hmmm come to think of it, get they would look good in matching red....
« Reply #25 on: August 01, 2019, 06:05:45 AM »
Hamlin Cycles has access to a fantastic machine shop.  The guy who runs it is a pure artist.  On my SATO someone at design didn't rally think it thru.  The guards did not protrude quite enough to be as effective as they could have been.  Last visit to jim's shop we removed one, called the guy, and an hour later he returned with two PERFECT extended mounting spacers, all tapped and supplied with correct bolts, to reinstall the SATO on the bike.  All edges were slightly rounded off and mounting holes were countersunk perfect.  An absolute joy to behold if you can appreciate the skill of a good machine shop.
He's the same guy who made custom mounts for the fork visibility lights on my Norge.  Pure machine art made out of top notch materials.
Offline Bulldog9
« Reply #26 on: August 01, 2019, 06:22:21 AM »
Hmmmm, I wonder if this guy to machine shop would be able to fabricate handlebar risers for the MDX? Several people have mentioned they would like one to two inches of lift and reach. I'll have to reach out to Hamlin.
MGNOC#23231
« Reply #27 on: August 01, 2019, 09:00:28 AM »
What year is your V7?
I bought the Over Racing sliders for my 13 V7 Stone (well, my wife did as a xmass present), but when they arrived they were too short to protect well. At that time I realized the problem, the 1TB models (with larger/fatter jugs) had just come out and the sliders were designed for the thinner jugged 2TB models. In that case it was a "relatively" easy case of having 1" round adapters machined out of aluminum and using longer bolts.
Ironically Over Racing stopped making them anyway, so I had to turn to Sato this time. But I think Sato realized it because they had different part numbers for the Mk I/Mk II models and the Mk III models.
« Reply #28 on: August 01, 2019, 10:02:06 AM »
2015 V7.
« Reply #29 on: August 01, 2019, 10:04:50 AM »
Jim's on his way to the NC rally.
Best to send him an email.  I know he just sold his last Flying Fort-hopefully the guy is local.  I don't know how one could fabricate without the bike.  On the other hand, it would make a GREAT road trip for you.  You'll love the shop.
