Author Topic: higher 5th gear for 73 Eldo  (Read 1206 times)
Offline ray bear
« on: March 26, 2019, 05:40:59 PM »
 Any one increased 5th gear ratio on a big block 5 speed by substituting the two 5th gears with the higher ratio ones from the Quota 1100, yes they fit and It has been done and works  but I don't know anyone that has done it that I can ask, the ratio is increased by 2 1/2 percent however I don't believe that equates to KPH  ?  and I would like to know what advantage  obtained is  as in lower RPM when cruising. I don't think it is 2 1/2 per cent ,  I have just had my main shaft separate so have the transmission down while I repair it and with the shaft separating  it has forced 5th gear into the bearing requiring the two gears to be replaced so seems a good time to go down this path  as Im already up for two gears and the only other item I require is to change my 6 dog engagement ring to a 5 dog.   Any one have any knowledge in this area   (Charlie/Peter ??)  chime in if you know anything     Thanks Bill.
« Last Edit: March 27, 2019, 02:54:10 AM by raybear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline Rolf Halvorsen
Re: higher 5th gear for 73 Eldo
« Reply #1 on: March 27, 2019, 04:10:04 AM »
I have a brand new 5-dog slider for sale. Send me a PM if interested.
Rolf
Offline ray bear
« Reply #2 on: March 27, 2019, 04:22:25 AM »
thanks Rolf, if I get some positive feedback with my question I will take it off your hands, every thing I require is available here in oz but its all gold plated. Someone on here must have done the conversion I just have to locate him.  Bill
73 V7 sport
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
XT 500 Yamaha
Offline mtiberio
    • TiberioRacing
« Reply #3 on: March 27, 2019, 08:18:20 AM »
Charlie Cole has told me about this. For my Land Speed Racer, he was suggesting that I get the 5th gear set out of a Lemans SE straight cut gear set. Less HP loss. Whine as well, of course.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
