Author Topic: SP brake & shifter pedal info wanted  (Read 1509 times)
CanBike
« on: April 02, 2019, 12:40:21 PM »
I'm building a G5 that originally came with floor boards, but what I think I want is the SP footpegs, brake pedal and shifter pedal set up. The SP seems to have the cleanest set up. Can anyone point me in the right direction to make this change?
Thanks.
« Last Edit: October 24, 2024, 09:29:39 PM by CanBike »
Re: SP brake & shifter pedal info wanted
« Reply #1 on: April 02, 2019, 01:18:27 PM »
just swap out the lower frame rails complete with the controls. you can do it on the center stand one side at a time and use the long thru bolts to keep the frame aligned.
« Reply #2 on: April 02, 2019, 02:21:23 PM »
I see. if you can find the SP or Lemans complete with frame rails it would be best.. they all share the same main frame so all frame rails bolt up.  the G5 & SP foot controls mount to a bracket/support that then mounts to the frame so you can probably use the frame rails from the G5 for SP pegs and hangers.. could use the footboard version too, just cut off the lugs that the boards mount to. I don't think those SP peg mounting hangers will be easy to find tho..
Online Frenchfrog
« Reply #3 on: April 02, 2019, 04:00:53 PM »
Just to add to the story the first series SP had the same footpegs as the LM 1 and 2 but I think series 2 is the T3 type....Hardly any difference between the two as the lm pegs are less than an inch shorter and the foot rests are slightly higher and further back,The exhaust is higher on the Lm though.I think Guzziology covers all the variations.
