Author Topic: 8V oil thermostat  (Read 13170 times)
Offline Murray
Re: 8V oil thermostat
« Reply #30 on: April 11, 2019, 07:36:09 AM »
Personally, I would like a 1400cc retro standard, based on the Bellagio.
The bellagio has been out of production longer than the griso and the rest of the CARC bikes.
beetle
« Reply #31 on: July 06, 2019, 05:16:28 AM »
An update. Yesterday, I incorporated a temperature sensor into the oil cooling line from the sump to the thermostat.
The oil temp stabilised around 100C. It never went above 105, and never below 98 on cruise. Once the engine temp stabilised at 107C, oil temp sat on 101-103 the whole time. Ambient temp was 17C.
« Reply #32 on: July 06, 2019, 05:23:02 PM »
A really nice mod there Beetle. :thumb:
Much better oil temps.
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
8V oil thermostat
« Reply #33 on: December 08, 2019, 12:52:32 PM »
Nice job Beetle.
I made one for my Stelvio back in April 2017.
Used a Mishimoto 93°C Wax-Stat.
Housing machined from a Round Bar of Alloy.
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
beetle
« Reply #34 on: December 08, 2019, 01:46:17 PM »
Nice!
I looked at the Mishimoto gear, but went with the Improved Racing one due to its shape/port orientation. I was determined to have it 'out of sight'.
Offline John Warner
8V oil thermostat
« Reply #35 on: December 14, 2019, 03:22:45 PM »
Mine's half-hidden by the new Sump Guard I made to mount it to.
For such a large Bike, there's very little space to fit anything extra.
Doc out . . .
« Reply #36 on: December 14, 2019, 05:46:37 PM »
Doc, if you think there isnt much space on a Stelvio you ought to have a squizz at a Griso! There is nowhere for anything! :grin:
Offline John Warner
8V oil thermostat
« Reply #37 on: December 14, 2019, 06:03:55 PM »
I'd guessed that already Pete, hence the lack of ABS on them.
Does make you wonder though, how the hell they managed to fit ABS to this . . .
Doc out . . .
Offline JanBarton
« Reply #38 on: July 01, 2020, 03:25:16 AM »
Hi ,
inspired by Mark solution on Griso I decided to do the same on my Stelvio. The goal was to install thermostat with original hoses to be able to quickly change it back to original connection in case of broken thermostat or leaking fittings. I made 4 new fittings of 2 types. First type is AN6 to M16x1,5 and second is M16x1,5 to 9/16-18 UNF-2B . One of fitting must be little bit bended to don´t stress original hose.
Thermostat is completely hidden behind original oil sump cover . The resulting oil engine temperature is between 96 to 103°C at any riding style. Heating up form 23 to 100°C is less than 15minutes at 20°C ambient temperature.
beetle
« Reply #39 on: July 01, 2020, 04:02:01 AM »
Good job!   :thumb:
Offline John Warner
8V oil thermostat
« Reply #40 on: July 12, 2020, 01:31:38 PM »
I concur, nice and neat.
What unit did you use, can't quite make out the Logo/Lettering?
Doc out . . .
Offline JanBarton
« Reply #41 on: July 26, 2020, 07:58:26 AM »
Hi, I used the same thermostat as Beetle. It is FSC-215 from Improved Racing.
http://www.improvedracing.com/oil-thermostats/compact-high-flow-engine-transmission-oil-cooler-thermostat-p-879.html
Jan
Offline John Warner
8V oil thermostat
« Reply #42 on: August 02, 2020, 05:42:22 PM »
Thanks Jan.
Doc out . . .
