98EV ECU Big one
Topic: 98EV ECU Big one (Read 3616 times)
steven c
98EV ECU Big one
April 05, 2019, 10:56:24 AM »
So after much checking, probing , steering, we have come to the conclusion that my ECU is fried some how, I'll know for sure tomorrow when we plug it into another 98. Does anyone repair them?
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Lesman
Gosling
Re: 98EV ECU Big one
Reply #1 on:
April 05, 2019, 11:26:18 AM »
Is the 98 a 15M? You have lots of choices if it is. Ducati/Aprillia use them. 15M can be found inexpensively. MPH in Houston has a few 15M's .
steven c
Reply #2 on:
April 05, 2019, 11:30:36 AM »
Thats a good question. It's the big one that sits on the fender.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
guzzisteve
"Just Ride It"
Reply #3 on:
April 05, 2019, 11:45:47 AM »
It's a P8 in a 98. When mine was put in a customers bike. I got a MyECU P8 from Cliff.
http://www.cajinnovations.com/MyECU/
You can run it open or closed loop. The best ECU in my opinion.
steven c
Reply #4 on:
April 05, 2019, 12:14:54 PM »
The P8
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
steven c
Reply #5 on:
April 05, 2019, 12:19:16 PM »
So found this, so do you just swap out the Ducati chip for the Guzzi?
https://www.ebay.com/itm/Ecu-Magneti-Marelli-P8-For-Ducati-851-888-748-916-Code-6160019202-IAW435/263908852387?epid=9009380538&hash=item3d723182a3:g:yIcAAOSwTIhaZbnJ
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Reply #6 on:
April 05, 2019, 12:27:20 PM »
it might be repairable with a good tech, my friend at work fixed mine..
this is the culprit,
steven c
Reply #7 on:
April 05, 2019, 12:38:38 PM »
Good friend to have.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Reply #8 on:
April 05, 2019, 02:50:32 PM »
+1
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
Turin
Reply #9 on:
April 05, 2019, 03:26:37 PM »
I got one from Ed Milich ( guzzipower.com ) for my Paso. I'm sure he'll have one or two that you can pop right in.
1985 Sidlow Guzzi
Kiwi_Roy
Reply #10 on:
April 06, 2019, 02:39:32 AM »
Quote from: fotoguzzi on April 05, 2019, 12:27:20 PM
The Safety Diode i believe, I have fixed a couple of those., it doesn't even need to be inside the ECU, it can be outside on the relay.
It's purpose is to protect the ECU if you accidentally put the battery in backwards it grounds the other side of the ECU relay
Steven C, if the ECU relay is not picking up of course check your battery is in right way around first (it will still crank)
I don't know how it gets blown
electricians don't confess when they screw up but I blew mine also, any small signal diode will do, say 1 Amp with the striped end to chassis.
It's the diode shown at the top of this sketch in the dashed box, it will work just as well outside on the Y/R wire to chassis.
Last Edit: April 06, 2019, 03:06:44 AM by Kiwi_Roy
yogidozer
Reply #11 on:
April 06, 2019, 06:07:01 AM »
Computers in cars, trucks, and motorcycles. Gotta love 'em.
Guess you think I'm a
But that's my point(s)
upload image
steven c
Reply #12 on:
April 06, 2019, 07:58:43 AM »
I found the RY wire coming out of the ECU relay ,so is this external diode located inside the harness? Just asking before I start cutting up the cover.
Last Edit: April 06, 2019, 08:12:46 AM by steven c
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Kiwi_Roy
Reply #13 on:
April 06, 2019, 01:50:54 PM »
So I take it from your question your ECU relay is not picking up?
The diode can be anywhere, the relay coil only draws 100 milliamps so the diode is not stressed (won't heat up)
Perhaps the original RY wire soldered to diode, diode band end soldered to a short wire connected to a chassis screw and cover the diode with a piece of heat shrink.
As I said the diode is to make sure ECU relay doesn't pick up if the battery is in backwards.
The later bikes like VII Sport with the 15M ECU have the diode outside in the loom somewhere.
BTW I made the EV Wiring Sketch to carry under the side cover as a cheat sheet, with a test light you should be able to check on most important stuff from there
Last Edit: April 06, 2019, 01:55:47 PM by Kiwi_Roy
Chuck in Indiana
Reply #14 on:
April 06, 2019, 04:00:05 PM »
I (probably) have a new one from the Aero engine. Considerably cheaper than the ebay one..
steven c
Reply #15 on:
April 06, 2019, 05:43:07 PM »
That would be awesome!
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Chuck in Indiana
Reply #16 on:
April 06, 2019, 08:31:22 PM »
Quote from: steven c on April 06, 2019, 05:43:07 PM
I'm in SoCal right now. Remind me (I'm old) in a couple of weeks and we can work something out.
steven c
Reply #17 on:
April 07, 2019, 07:55:05 AM »
Okay.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
98EV ECU Big one
