Author Topic: FUEL LINE FITTING  (Read 1602 times)
Offline Spuddy
FUEL LINE FITTING
« on: April 15, 2019, 12:00:58 PM »
What is the correct way to release the quick disconnect fuel line from the tank?
Spud
« Last Edit: April 15, 2019, 12:02:55 PM by Spuddy »
'13 Stelvio NTX
'07 California Vintage
'01 W650
Online Wayne Orwig
Re: FUEL LINE FITTING
« Reply #1 on: April 15, 2019, 12:18:39 PM »
First, relieve the fuel pressure. If you don't, it may put up a fight.
Usually, you unplug the pump, then crank the motor to fire the injectors. Guzzidiag can also fire them.
Then, push the grey ring in and push the line in. Then pull the line out.
« Last Edit: April 15, 2019, 12:25:15 PM by Wayne Orwig »
Online flower_king001
« Reply #2 on: April 15, 2019, 12:31:41 PM »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline malik
« Reply #3 on: April 15, 2019, 06:40:34 PM »
That looks even more awkward than the red elbow. As mentioned above, it may help if the pressure is first relieved by removing the pump's power lines & spinning the starter. If it hadn't been removed recently, a little lube  (I find silicone or lanolin spray works) in the teeth of the QD helps. Once you have if off, lube those teeth again from the inside for next time. You push the fuel line in while pulling the grey collar back. There is no click or other tactile feedback to tell you how well you're going. It doesn't take much pressure or effort. Just pull the collar back, perhaps wiggle it slightly, and all of a sudden there's a little left over fuel on your fingers & it's off. Once it's off, and you've done what's needed, it is an idea to practice doing it again several times, so that next time your fingers know what to expect. There's not much in it, and your fingers will end up knowing more than the rest of you does, and it'll work every time. And remember, it's a Guzzi, so if you struggle & struggle, and it's still not working, take a rest, a cuppa, a beer, a glass of red, a run around the block, whatever. When you come back to it, it usually works first go.
Offline TimmyTheHog
« Reply #4 on: April 15, 2019, 06:43:39 PM »
Here is a PDF write up from someone but me :P...but I used to use it.
This is my personal Dropbox link
https://www.dropbox.com/s/yqitp1iyvp6r01t/Fuel%20tank%20removal.pdf?dl=0
Currently Bikeless...*cry*
« Reply #5 on: April 15, 2019, 10:27:52 PM »
You can see the guy in the video has a bit of a struggle, as Wayne says killing the pump then trying to start makes it so much easier without 40 psi behind it.
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
« Reply #6 on: April 16, 2019, 03:12:14 AM »
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
