Author Topic: weird braking problem  (Read 3417 times)
Offline troyhamilton
  • Dr frankie
« on: April 17, 2019, 10:19:43 PM »
My Jackal will come to a stop normaly then i have to break the front brake  line lose at the caliper to release  the brake. Is it the master cyl? rubber brake line or my caliper? previous owner told me of this happening to him. any ideas would be appreciated,
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline normzone
Re: weird braking problem
« Reply #1 on: April 17, 2019, 11:00:33 PM »
I'm not a brakes expert, and I don't even play one on television.
But one will be here shortly, so until they get here I will offer my opinion.
It's either the master cylinder or the caliper - you figured that out already.
You say you " break the front brake line loose at the caliper " - if I understand you correctly by doing so you're letting air into the system, and releasing the pressure the master cylinder built up.
I vote the caliper is sticking. But if I had brakes that treated me like that I'd rebuild / replace both parts, and you may as well do the hose while you're there.
There you have it - wisdom from the mouth of babes.  No, don't thank me, just diagnose my tail light / turn signals issue, and we can call it even.
 :evil: :bow: :wink:
« Reply #2 on: April 17, 2019, 11:08:57 PM »
For whatever reason the piston in the master cylinder isn't able to return fully so the priming port to the reservoir isn't open. This means the braking system is effectively closed when the brake is released.
As the caliper heats up the fluid in the system expands. Since it can't escape back into the reservoir it's only choice is to push the pistons in the caliper out thus locking on the brake.
Find out why the piston can't return fully and fix it. There may be a small plunger from a barrel on the lever that is adjustable. I'll have to go and look at the one on my shitbox Cali to confirm.
  • Dr frankie
« Reply #3 on: April 17, 2019, 11:31:45 PM »
it done it when i rolled it out of the shop, maybe 10 ft back. no heat there. it hadnt been ridden all day, 65 degrees out side.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #4 on: April 18, 2019, 12:32:05 AM »
It'll still be the return port. The fact releasing the pressure by cracking the bleed nipple or banjo bolt pretty much confirms it.
Offline Old Jock
« Reply #5 on: April 18, 2019, 03:28:19 AM »
Well of course Pete is right
If you release the line and vent the pressure and the brakes loosen off, then its not the caliper, that is beahviing as it should
The fact you can brake at all, more or less tells you that the lines are fine that leaves the master holding the pressure on the system, so either the ports or the spring or a jammed seal I reckon
But my money is on the master
Go with Pete's idea first of course I'm an amateur and a not very competent one at that
  • Dr frankie
« Reply #6 on: April 18, 2019, 06:26:04 AM »
yep new fluid and maybe a new master cyl then.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Huzo
« Reply #7 on: April 18, 2019, 06:34:22 AM »
Maybe the fluid hasn’t been changed since Christ died and has contaminated the bore of the m/c.
This could very well be contributing to the reluctance of the piston to fully retract and uncover the port.
The system cannot depressurise unless that port communicates between the reservoir and the piston.
« Reply #8 on: April 18, 2019, 06:54:25 AM »
Troy, not necessarily. It may simply be an adjustment problem. I have to admit I can't remember what the actuation mechanism is, or even the M/C Setup on the Cali's. I see few of them nowadays as my work is almost exclusively CARC/8V.
I am though rebuilding my sidecar tug which will have the same, (Or very similar.) master cylinder. Let me have a Squizz at it and see if I can see what may be the issue. It maybe, really, very simple.(A bit like me.)
  • Dr frankie
« Reply #9 on: April 18, 2019, 06:57:26 AM »
thanks, i may get some brake cleaner and new fluid in the old beast.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #10 on: April 18, 2019, 07:11:40 AM »
Don't think brake cleaner will fix it. Do you understand how a brake master cylinder works?
  • Dr frankie
« Reply #11 on: April 18, 2019, 07:20:20 AM »
kind of pete, ive never took one apart to be honest.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Mike Tashjian
« Reply #12 on: April 18, 2019, 07:25:05 AM »
The fluid is not returning and the Caliper releases when you crack the line.  Obvious it not the Caliper. The master cylinder piston gets pushed by the brake handle. If the brakes stay on either the M/C piston is not returning (stuck, bad return spring handle and not returning all the way) or the rubber hose has swelled from age and is blocking the return of fluid to the M/C.  I would remove the hose at the caliper and note how hard it is to move the brake handle. Fluid should drain out quite easily with almost no effort.  Mike
  • Dr frankie
« Reply #13 on: April 18, 2019, 07:28:47 AM »
brake handle works as normal.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #14 on: April 18, 2019, 07:30:30 AM »
and it doest do it every time. just ocaisionaly. irritating in traffic to say the least. and it dont lock up all at once
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline s1120
« Reply #15 on: April 18, 2019, 07:32:37 AM »
So if it was a car....  I would say its the brake line. Ive seen them often on older cars..  The rubber breaks down and falls away from the outer cover and works like a one way check valve. Fluid under pressure goes down fine, but the rubber makes a flap that stops it from going back up after pressure is released..  Granted Ive not seen that often on motorcycles, and the master seems to be the much more common problem spot. Caliper is fine its releasing when you remove pressure.
Paul B
  • Dr frankie
« Reply #16 on: April 18, 2019, 07:39:59 AM »
thats what my brother thought. his ford truck done this. gonna order a hose.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline s1120
« Reply #17 on: April 18, 2019, 07:49:31 AM »
And really... it can never hurt to replace a hose.. they do go bad, and the bike is not a spring chicken any more...
Paul B
  • Dr frankie
« Reply #18 on: April 18, 2019, 07:51:56 AM »
nope not a spring chicken but i have a rubber chicken zip tied to the bike. the bike sat in a barn for 10 plus years...but was doing this before it was parked.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Craig in Alabama
« Reply #19 on: April 18, 2019, 10:17:08 AM »
Hi Folks,
This happened to me about 1/2 mile from the sellers house when I picked up my '98 V11EV. I released the pressure on that caliper with the bleed nipple and rode home using only the rear brake. Turned out to be a piece of crud in the master cylinder. A brake fluid flush solved the problem. I  was going to do that as a matter of course, so no big deal. Also on that ride home the left rear turn signal broke off and the charge system wasn't working. Glad I rescued the poor bike from the PO.
Cheers!
Craig
22 V85TT Travel
98 V11EV
05 Suzuki DL-650
25 Ibex 450
Offline johnk
« Reply #20 on: April 18, 2019, 10:59:32 AM »
It could be an aftermarket/badly adjusted brake lever. If there's not enough free play it might not be allowing the master cylinder piston to clear the relief valve.
John Koester
2002 V11 Scura, 1982 V50 'Monza', 82 BMW R65LS, 1992 DR350S, 1971 CB350
Offline D Knaus
« Reply #21 on: April 18, 2019, 01:13:14 PM »
I have had this happen on pickup trucks, and once on the rear brake on my Norton (1975 Mk III with disc rear brake.)
It was the rubber brake line that had come apart on the inside and would not let the pressure off the caliper.
Try shaking the brake line when the brake is locked up, if it comes free it is probably the hose.
YMMV
-Dale
