Magnum BYO fittings and brake lines?
Topic: Magnum BYO fittings and brake lines? (Read 2370 times)
troyhamilton
Dr frankie
April 18, 2019, 09:50:08 AM »
I saw these on MGCYCLE, have anyone on here used them? My brake lines are from 2000...Pros and cons of them. looks simple and easy to use.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Antietam Classic Cycle
Happily stuck in the past.
Re: Magnum BYO fittings and brake lines?
Reply #1 on:
April 18, 2019, 01:27:42 PM »
Used them on several projects. Work great.
Reply #2 on:
April 18, 2019, 01:37:32 PM »
I converted my 1972 Eldorado to dual disc front brakes using the Magnum fittings from MG Cycle, very easy to use.
Aldo
Reply #3 on:
April 22, 2019, 08:48:17 AM »
I've used them on several Guzzi projects over the years, including my current double disk Eldorado. Easy to use and work great. Much prefer these over "pre-made, one size fits all" sets...
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
jrt
Reply #4 on:
April 22, 2019, 02:57:24 PM »
Same here- used them to convert my Eldo to dual disc...well, triple disc actually. They are easy to work with. I used a dremel tool/cutoff wheel to cut length.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
larrys
Reply #5 on:
April 22, 2019, 03:01:37 PM »
A good hydraulic shop can make custom brake lines. Bring them your old ones. I did a BMW R65 recently. Beemer uses those weird flare fittings. Changed to braided stainless, wasn't a problem for them.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Diploman
"The future just ain't what it used to be." Yogi
Reply #6 on:
April 22, 2019, 04:25:53 PM »
I have used the Magnum BYO lines and fittings on two projects with good success. They are easy to fit, safe and reliable. However, the Magnum lines seem unnecessarily fat and bulky for a motorcycle - They are really intended for automotive use, I believe.
A better alternative for motorcycles, IMO, are Goodridge Sniper BYO lines. These are also easy to assemble, safe and reliable. But they have the advantage of being much less bulky than the Magnums and can fit into tight corners and passages because of their significantly smaller diameter. The Snipers (especially the black lines) are far less visually obtrusive than the Magnums, weigh less, and to my mind are better suited to motorcycle use. My V50 is equipped with Snipers throughout, and they have been extremely satisfactory. Revival Cycles (the renowned Austin custom builders) use Snipers exclusively and claim they are much easier to bleed than bigger diameter lines because the bubbles have to travel faster. Whatever the case, the Snipers are excellent lines from a company that has been building brake components for decades. Highly recommended.
https://www.amazon.com/s?k=goodridge+sniper+brake+lines&ref=nb_sb_noss
2015 KTM 390 Duke
troyhamilton
Dr frankie
Reply #7 on:
April 22, 2019, 06:14:26 PM »
I like doing things my own self. if it breaks its up to me to fix it i coulda bought new lines. but nope do it my own self
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
RoMoMoTo
Gaggle Mentor
Reply #8 on:
April 23, 2019, 07:05:07 AM »
I'm looking to replace the hose to the left front caliper on my early Tonti - the one that connects under the tank to the rigid pipe from the splitter. It's easy to find the hose, sold by the foot, as well as the banjo fitting at the caliper, but I haven't found the 10mm 1.0 female compression fitting needed to connect to the pipe. Anyone know where to find that?
RoMoMoTo
1981 CX100
2000 Quota 1100
1975 T3 FB
1975 Norton Commando
2005 Triumph Tiger 955i
1968 Hodaka Ace 100
1966 Wards Riverside (Benelli) 1125L
2000 Husaberg 501
Sundry projects
troyhamilton
Dr frankie
Reply #9 on:
April 23, 2019, 09:26:34 AM »
look on ebay magnum byo
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Diploman
Reply #10 on:
April 23, 2019, 10:50:25 AM »
Voila:
https://www.amazon.com/Goodridge-Sniper-Straight-Fitting-SN6001-02-03BDC/dp/B06Y4G4MCJ/ref=sr_1_40?keywords=goodridge+sniper+brake+lines&qid=1556034400&s=gateway&sr=8-40
(10mm sometimes referred to as 3/8")
2015 KTM 390 Duke
RoMoMoTo
Gaggle Mentor
Reply #11 on:
April 23, 2019, 07:45:16 PM »
Are you saying that 3/8" - 24 tpi is acceptable to mate with 10mm 1.0?
RoMoMoTo
1981 CX100
2000 Quota 1100
1975 T3 FB
1968 Hodaka Ace 100
2000 Husaberg 501
Sundry projects
Diploman
Reply #12 on:
April 23, 2019, 08:11:55 PM »
If you look at this chart you will see that Goodridge offers banjo bolts in both 10 x 00 (Brembo thread) and 10 x 25 (Japanese thread). It would make logical sense that both the male and female straight adapters would come in both threads, although it's not entirely clear. For the American market (the only one in the world where the English inch/foot/yard system is still used), the metric sizes are often referred to by the closest approximate inch measurement. Whether "24" refers to the Brembo or Japanese thread is not clear. If you are considering purchase, suggest you inquire beforehand.
http://www.phatperformanceparts.com/Goodridge_Sniper_II_Series_Brake_Lines_Fittings_p/good-sniper-series.htm
2015 KTM 390 Duke
