Author Topic: Disassembling flanged spoked wheels  (Read 2902 times)
Offline Rich A
« on: April 18, 2019, 09:26:05 PM »
I have an alloy flanged spoked wheel from a Bassa or EV that I want to clean up--it has a lot brake dust or some other hard to remove stuff on it. I've tried some aluminum wheel cleaner, and that worked a little, but not as well as I'd like. I think I could clean it up nicely if I took the rim off, but the problem with disassembly is that you can't get a wrench on some of the nipples.
Has anyone taken one of these apart? Do you just use a screwdriver to get those nipples off?
Rich A
Re: Disassembling flanged spoked wheels
« Reply #1 on: April 19, 2019, 08:10:47 AM »
I am not familiar with this particular wheel but if its like any of the earlier Boranni rims then once the tire, tube and rim lace are peeled off the spoke nipples will turn off with a screwdriver.
If the nipple gets stuck I use a small vice grip to hole the spoke while turning the nipple off, sometimes a liberal dose of penetrating fluid is needed around the nipple.
a small wrench should be able to reach every spoke and turn it 1/4 rotation.
Offline Perazzimx14
« Reply #2 on: April 19, 2019, 08:13:57 AM »
Do yourself a favor and get a can of PB Blaster or other penetrating oil and apply a few times over a day or so to the spoke nipples to get things lubed up before trying to disassemble.
Offline Rich A
« Reply #3 on: April 19, 2019, 08:40:54 AM »
Thanks for the advice. Here's a pic that shows the problem with the nipples. These are such nice wheels that I think it's worth restoring them.
x6 50i 0 60
Rich A
Online John A
« Reply #4 on: April 19, 2019, 09:11:15 AM »
Unless you are competent with lacing wheels,  I wouldn't disassemble them.  Those wheels are evidently assembled by a machine and are troublesome,  although it can be done by hand.  The guy I use for wheels says that the regular wheels he does but tubeless spoked wheels go to Buchanons wheel.  By the looks of it,  you have a large project there.  Some of the spokes may have to be destroyed just to get them out.
Offline Rich A
« Reply #5 on: April 19, 2019, 10:53:30 AM »
Good advice--I'll try cleaning it up w/o disassembly.
Rich
Offline Roebling3
« Reply #6 on: April 19, 2019, 12:45:55 PM »
If you gave it to a competent shop they would likely cut them in half and replace w/new. It's a time spent thing @ an hourly rate $$$.  R3~
Online RinkRat II
  • Lake Powell AZ
« Reply #7 on: April 19, 2019, 01:17:49 PM »
    Those are some short nipples right there! They make them in longer lengths and it may be worthwhile to change them out if you need to adjust the tension properly.
   Buchanans website has all the dimensions and lengths to choose from.
       Hope this helps
       Paul B :boozing:
Offline Rich A
« Reply #8 on: April 19, 2019, 01:37:46 PM »
My plan of the moment is to remove a few spokes, clean up the area around them, re-install those, then move on to the next set.
I think it'd be $400-500 for Buchanan's to re-do the wheel. I'm retired, so labor is cheap. The worst I can do is to damage some spokes/nipples and have to replace them or send it off.
Rich
Offline acogoff
« Reply #9 on: April 19, 2019, 02:50:02 PM »
    Yikes!, The nipples are in the hub on those wheels???? You are a better man than me if you are able to tackle that disassembly and reassembly and get them trued up again. A toothbrush and mothers polish and some elbow grease while they are all together looks a whole lot easier.
Marshall County Minnesota USA
Offline wirespokes
« Reply #10 on: April 19, 2019, 03:46:52 PM »
If the wheels spin true with no damage, I'd leave them. I've built a lot of wheels, and worst, by far, were the BMW tubeless spoke wheels similar to the EV. I think I spent 50 hours on a GSPD tubeless wire front wheel. And it still wasn't perfect. It had about 1/2 the wobble, in the end, I'd started out with and considered myself fortunate it came out that good!
Aren't those spoke nipples socket-head on the other side?
Sounds like excellent advice to me to clean them up as-is. Even removing one spoke at a time isn't a good idea.
Offline Rich A
« Reply #11 on: April 19, 2019, 05:39:14 PM »
Those aren't socket-heads.
I won't try disassembling the wheel. In fact, it may go to a dusty part of the garage for a rainy day (and it doesn't rain much in New Mexico)
Rich
Offline Gusable
« Reply #12 on: April 19, 2019, 08:12:16 PM »
Couple words if I may.. woodys wheel works in Colorado.  That’s where I’d send em.  Best spoke shop in USA
1994 California 1100
Offline Huzo
« Reply #13 on: April 19, 2019, 10:51:35 PM »
I’ll admit that as a young bloke I didn’t get out much.
But the end that’s in the hub don’t look like any nipples I’d seen.. (although I admit it was in the dark most of the time.. :wink:)
« Last Edit: April 19, 2019, 10:54:03 PM by Huzo »
Offline Rich A
« Reply #14 on: April 19, 2019, 10:57:59 PM »
That's not a flanged tubeless rim--looks like a Borrani from the 70s. There's a pic of the nipples barely protruding from the tubeless wheel hub (and one completely hidden) is a previous post.
Rich
Offline Huzo
« Reply #15 on: April 19, 2019, 11:14:05 PM »
Rich
Reply #3 Rich ?
Offline Rich A
« Reply #16 on: April 19, 2019, 11:57:54 PM »
Yes, has an x6 50i something in the reply for some unknown reason.
Rich
Offline BrotherJim
« Reply #17 on: April 20, 2019, 08:47:29 AM »
Rich
Seems imgbb places a link into some of the pictures that we upload.  If you look at the line of code for the photo in your reply, you'll often see the link with some unrelated text in it.  You can go through and delete it if you wish.  I like to for some reason. :grin:
Short Time Livin'...
'02 Moto Guzzi California Stone
