Author Topic: Steering Head Wrench '96 Cali  (Read 1113 times)
Offline flower_king001
« on: April 29, 2019, 10:58:03 AM »
Need to adjust the steering head bearings. Is this the correct tool ?
http://www.mgcycle.com/index.php?main_page=product_info&cPath=80&products_id=1659
Anything better out there?
« Last Edit: April 29, 2019, 11:52:56 AM by flower_king001 »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Re: Steering Head Wrench '96 Cali
« Reply #1 on: April 29, 2019, 12:36:14 PM »
96 California does not use a hex nut for the steering head bearing I don't think.
Pretty sure it is a peg nut(?) or whatever they are called. I use a drift and tap it to spin it.
« Last Edit: April 29, 2019, 04:28:07 PM by Wayne Orwig »
Offline bigbikerrick
« Reply #2 on: April 29, 2019, 04:26:20 PM »
Like Wayne says, that wrench is for the earlier model tontis. My85 Lemans, uses that thin wrench to reach into the narrow space to adjust the tension.
Rick.
Online wirespokes
« Reply #3 on: April 29, 2019, 04:38:02 PM »
As I recall, the nut isn't tightened with any force. It only adjusts tension on the steering bearings. The top clamp is what locks it in. So when you want to adjust steering head bearings, loosen the top clamp at all three points, not just the stem. It needs to re-position itself and can't if it's not free to move.
I think most guys use a drift to adjust the nut because it takes a very thin wrench to reach in there. I've seen the evidence.
I just worked on a 97 Cali and it used a hex nut, not a slotted ring.
So to answer the question, it looks like the correct tool to me if yours has a nut, not the slotted style.
