Author Topic: What was the smaller battery for the 98 EV ( I want to mod the seat)  (Read 1447 times)
Offline Gusable
I’m getting my EV back next week!! It’s got the meds comfort seat on it but I want to cut out the hump and move the computer.  Which battery is smaller and allows the clearance?  I guess I’m going to whizzy wheel the hump and cover it with an aluminum plate? Fill in the cavity with foam maybe? I need to try and make it better before I go Corbin/ russell. Thanks! Gus
1994 California 1100
Offline Kiwi Dave
    • Guzzi Gander Ltd
The later EV Tourings came with a "half" battery, Spark 500 from memory.  This was to allow some room for the mandatory environment filter for the fuel tank.
I haven't done any measurements, but I think you'll be lucky to fit the P8 ECU in this spot.  Perhaps a lithium battery might make more room.
Or you could change over to the smaller IAW 15M ECU, but you will need a later wiring loom at least.
I have done a couple of those. The Spark 500 was a good battery and made by Odyssey. That is the battery I put in can't remember if it was the 680 or smaller size.
To work you have to cut the tabs on 1 side(heat sync)of ecu. Go slow and create no heat in cutting. They are for mounting ecu in another application.
Offline Gusable
Ok great thanks for the info
Offline Kiwi Dave
    • Guzzi Gander Ltd
The best!  I had two EV Tourings that came with the Spark 500s,  They lasted twelve years and died within a month of each other.
Offline KiwiKev
. maybe a gel type battery is the answer ? You can mount them on the flat if you want And they can be physically smaller. One worked fine in my Cali 1100i
Offline twhitaker
My LeMans and my Centauro both use an Odyssey PC545 so I changed the California to that for commonality. Works fine.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline Howard R
And, the Spark 500 is a "repainted" copy of the PC 545.  The Odyssey is an exact fit in the Centauro, and really the only thing that will work in that bike.  The battery compartment is alomst "molded" around the battery.
Howard
Littlestown, PA  USA
1996 Sport 1100
1998 Centauro
MGNOC # L-707
I use the STX12-BS for $32.99 from batterysharks. https://www.ebay.com/itm/STX12-BS-YTX12-BS-UTX12-GTX12-BS-MBTX12U-CTX12-BS-PTX12-Replacement-Battery/323332195018?epid=18027213003&hash=item4b4819c2ca:g:pR8AAOSwoudW6lcd:sc:USPSPriority!70605!US!-1&frcectupt=true
It seems  to work fine and cheaper than the PC545 for $112. The only thing is the battery posts (-&+) are reversed.
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
Offline Gusable
Does anyone have a picture of a big computer EV with the smaller battery and computer relocated?
