Author Topic: What K&N pods for 1100 Sport??  (Read 2646 times)
Offline GuzziFuria
« on: May 07, 2019, 07:36:42 PM »
Ciao Tutti,
What would be the correct K&N pod filter model, for the Dellortos to flow enough air for the big 1064cc cylinders ??
Was going to put K&N 1250, but came to the conclusion these are too small for such big jugs...
Molto Grazie
Carlito
Re: What K&N pods for 1100 Sport??
« Reply #1 on: May 07, 2019, 08:26:04 PM »
I'd suggest sticking with the original airbox. It works OK and the filter actually works unlike K&N's
jwinwi
« Reply #2 on: May 08, 2019, 11:28:12 AM »
Not trying to influence your decision one way or the other BUT...
I have a like new pair of these - used briefly on a LeMans 1000 - I'd sell for $50 plus shipping.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=164_166&products_id=1906
BTW, my Sport 1100 still wears its airbox.
« Last Edit: May 08, 2019, 11:49:15 AM by jwinwi »
« Reply #3 on: May 08, 2019, 12:40:16 PM »
I kept the stock airbox.  It's pressurized, and performs pretty well with its rectangular air filter.
Offline LBC Tenni
« Reply #4 on: May 08, 2019, 12:47:47 PM »
Consider the science. Oiled media filters are a scam:
https://nicoclub.com/archives/kn-vs-oem-filter.html
2011 GRiSO SE8V Tenni
Offline Dimples
« Reply #5 on: May 08, 2019, 01:40:39 PM »
Maybe just skip the ugly filters and add a pair of Italian-made Malossi velocity stacks-- they SOUND great!
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
Offline yogidozer
« Reply #6 on: May 08, 2019, 03:47:28 PM »
Same here. With correct jetting it runs well.
Offline Idontwantapickle
« Reply #7 on: May 08, 2019, 03:49:15 PM »
Most Guzzis run better this way, especially a Sport.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Tusayan
« Reply #8 on: May 08, 2019, 05:57:16 PM »
Injected 1100 Sports are OK with the airbox, Centauros etc with the same airbox gain >5 HP with long stacks and Uni filters per Daytona C-Kit.
Offline GuzziFuria
« Reply #9 on: May 09, 2019, 02:48:29 PM »
Looks nice too, but here lots of road dust, and straight it goes into your Jugs...
Offline GuzziFuria
« Reply #10 on: May 09, 2019, 02:57:23 PM »
Yes do like the ram air system lots...  But some idiot saw off the top of the air box, revealing the paper filter element...
Really do not understand this type of idiocy, what's the purpose ??
Will get an old top again...
In the mean time decided to part with the whole air box and run K&N...
Also read in Guzziology that the airbox pressurized system confused the dellortos carbs and created a dead zone at mid range...  The solution was to take it out and replace with cone filters...  Guzzi initially did not want the ram air box system, but responded to fashion of the time and EPA...
Guzzi also made on purpose for the 1100 to easily be customizeable, ie take off air box and put cone filters...
Offline yogidozer
« Reply #11 on: May 09, 2019, 03:10:13 PM »
With proper getting, there shouldn't be a flat spot. I believe Guzziology also state with the ram air, top end is improved.
I also run a DigiPlex from the Strada, that maybe why I have no flat spot in the midrange.
Offline Murray
« Reply #12 on: May 09, 2019, 03:15:18 PM »
Haven't got the part number to hand I'll get some measurements on the weekend, however you will need to change the manifolds the stock ones are not designed to support carb and filter, some copper wire re enforced fuel delivery hose works well. The tops of the airbox mod was standard practice with the V11 and some of the calis to get it to breath better, to actually get the air box to start pressurizing you need to be north of 100mph as the intakes are simply in the wrong spot aerodynamically. There is also some oddness with the length of the intake in the midrange, I suspect the people who claim the airbox is fine are the same people who claim the 1960's carbs the bike is saddled with work ok because they haven't experienced anything else.
Offline yogidozer
« Reply #13 on: May 09, 2019, 03:19:55 PM »
I and others running the airbox will disagree with you.
With the setup I posted, my 95 spot pulls VERY hard throughout the entire range.
Offline Tusayan
« Reply #14 on: May 09, 2019, 03:43:18 PM »
John Wittner when interviewed explained that the 1100 Sport airbox was not developed at all and resulted in lean spots with carbs.  Guzzi knew that there was a market for a “kit bike”, with buyers who might well remove the airbox.  The lean spots can be mitigated to some degree with richer jetting.  The EFI bike is not affected by the same airbox resonance issues, only fuel map issues.
The pressurized airbox thing is a sales technique, the bike doesn't go fast enough for it to make much difference.  However cool air is good.
« Reply #15 on: May 09, 2019, 03:59:23 PM »
Keihin FCR41 and stock airbox on mine.
Cold air from the intake tubes can only be a good thing, no matter the speed.
Offline yogidozer
« Reply #16 on: May 09, 2019, 04:40:37 PM »
Yes, cold air is a plus for sure.
rocker, have you, or anyone you know, ever switched out the DigiPlex? Seems like that made a big difference with mine.
And Murray, don't know anyone buys a spot for riding at 55mph  :rolleyes:
« Reply #17 on: May 09, 2019, 09:54:58 PM »
Sorry, I don't know anyone who has.  Mine is still stock.
