Author Topic: V7iii First Service  (Read 21527 times)
Re: V7iii First Service
« Reply #60 on: June 28, 2019, 11:37:00 PM »
Tips:
This adjustment reminds me that I need to get a proper valve adjustment tool to hold the valves when tightening the nut. I've always just used a pair of pliers, but it's too easy to allow it to nudge just slightly and then I have to loosen the nut again, readjust, tighten again. If anyone has a suggestion of a better way to hold the adjuster tab I'm all ears.
Z
Kev, does the hemi head make it more awkward to adjust the valve clearances?  I don't recall having to use pliers on the Heron setup.
« Reply #61 on: June 29, 2019, 04:06:33 AM »
Not at all.
How do you hold the adjuster from turning when you tighten the locknut?!?
« Reply #62 on: June 29, 2019, 04:37:32 AM »
Motion Pro makes a tool for that-of course they do!
Offline sign216
« Reply #63 on: June 29, 2019, 04:42:10 AM »
My main "hunting" knife is a Frost laminated steel jobbie.  A story behind how I got it but over the years it has cut through hundeds of rabbit bones and has been given a quick tickle up twice.  A beautiful knife.
Love the laminated carbon steel.  It's a struggle to get a carbon steel knife anymore, let alone one with a laminated blade.  The kids now want stainless, because they can't bother with caring for it, and don't know what a working knife looks like.
I'm thinking of buying another, since they might stop making them anytime.  Of course, they've only been making them for hundreds of yrs, right?
https://morakniv.se/en/product-category/all-knives/morakniv-classics/?v=7516fd43adaa
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Online Cam3512
« Reply #64 on: June 29, 2019, 05:48:38 AM »
Why are you guys discussing knives in the middle of a First Service thread??
« Reply #65 on: June 29, 2019, 06:48:50 AM »
I would assume so right.
I should buy something after all these years.
Offline Vagrant
« Reply #66 on: June 29, 2019, 07:24:15 AM »
a tool came in the 1972 Eldorado kit. mine got lost somewhere but if you can still find a pack of ignition wrenches one will fit. otherwise long nose vice grips.
Offline sign216
« Reply #67 on: June 29, 2019, 07:47:59 AM »
You can still find SAE and metric ignition wrench sets at Sears.  Even though people haven't been adjusting dwell and points in years.  Your local Sears may still have made-in-America sets, probably old stock, left over from yrs ago.  At least my store did.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline sign216
« Reply #68 on: June 29, 2019, 07:49:36 AM »
The topic came up, as threads drift like a stream in the woods.
Come on, don't you have some favorite knives?
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Online Bulldog9
« Reply #69 on: June 29, 2019, 09:01:51 AM »
I have a terrible bad habit of confusing my bikes but if I remember correctly I used a small Allen wrench to hold the adjuster in place while I tightened the nut. But I could be remembering the Norge or agree so. I've done them five or six times but the V7 stornello only once.
MGNOC#23231
« Reply #70 on: June 29, 2019, 01:02:13 PM »
Not at all.
I use a 4" adjustable crescent wrench, I should make one out of 1/8" aluminium but I use it so rarely.
« Reply #71 on: June 29, 2019, 01:14:54 PM »
I don't recall ever seeing a Guzzi with an Allen head valve adjuster. The four valve Carcs or Cali?!?
Online Bulldog9
« Reply #72 on: June 29, 2019, 02:19:47 PM »
LOL, could be one of my cars too....
MGNOC#23231
« Reply #73 on: June 29, 2019, 04:36:47 PM »
 :embarrassed: :embarrassed: :embarrassed: Now ya got me Kev.  I can't remember. (More  :embarrassed: :embarrassed:)
The problem is, I can't remember what is on the top of them now.  I know I don't use pliers.  I was thinking they were slotted, hence screwdriver.  If they are not and are square it would be either my mag spanners or the little square Honda tappet holder, which is basically a small deep socket with a handle on it.
With the Breva, if the clearance is out by even a couple of thou then it has quite a loud tick.  I gave up having a regular service schedule for the valves because I couldn't see the sense of  the possibility of damaging the gaskets simply to take up one thou on one valve.  Now I do them when the tick tells me to, which is very rare indeed.
« Reply #74 on: June 29, 2019, 06:38:18 PM »
Lol, the adjuster screw has a thin raised lip/tab across the center, like the negative of a flat-head slot.
« Reply #75 on: June 29, 2019, 10:00:54 PM »
I found it! :grin:  I have an aluminium shelf bracket where the alloy is quite hard and appears to be tempered.  I have put two slots in it on the rounded end, which gives me two bites of the cherry.  One slot does the valve lash, the other fits the tang on the end of the clutch adjustment on the gearbox.  Cheap is good, free is better.
Old age creeping in. :grin:
« Reply #76 on: June 30, 2019, 08:17:07 AM »
Ahh, yes, I can see where it should be relatively easy to slot a piece of steel or aluminum to do something like that. But I think a handheld/knurled tool that you held from directly above the adjuster screw would be more versatile and less likely to foul the tank or locknut wrench.
Online Bulldog9
« Reply #77 on: June 30, 2019, 01:02:48 PM »
Did the valve adjust on the MGX today, it has the allen head I was referring to, so I mustve been thinking of the Norge. On the V7ii i used a tiny wrench.
MGNOC#23231
« Reply #78 on: June 30, 2019, 04:06:22 PM »
I suspect I have more room with the Heron head and the flat alloy piece (Guzzi part #54321 :wink:) is of course lying flat as well.  Your hemi is going to have my patented spanner sitting at an angle; not so easy I suspect.
Offline bald.male
« Reply #79 on: June 25, 2020, 10:45:17 AM »
Hello, and some things I noted while performing the first service (my first Guzzi, btw) on my 2019 V7III Special.
1) I had the same exact black rubber snake in the gearbox (transmission) filter as Kev m in his pictures posted in this thread. Any insight on what this was?
2) My spark plugs were gapped around .6 but the manual says .9mm on page 220. That is quite a difference! I followed manual spec and widened them. Thoughts?
3) Valves were close to spec but as per recommendations I went with .005 and .007 (instead of spec .004 and .006).
4) Either the factory over tightened the valve cover bolts or I did when putting thing back together because I have multiple oil leaks around the bolt grommets. Or perhaps these grommets are meant to be replaced when servicing. Either way, new grommets on the way and hopefully this problem goes away. Finger tight plus a little is my new understanding.
5) Super fun to work on and quite easy. 10/10 will do it again!
Offline Rich A
« Reply #80 on: June 25, 2020, 10:59:41 AM »
This is the tool I made to hold the adjuster when setting the valves.
Rich A
Offline Ronkom
    • Virginia Moto Guzzi Owners Club
« Reply #81 on: June 25, 2020, 11:34:54 AM »
The  "use+maintenance" manual for my '17 V7III lists a "transmission oil filter" to be Checked at .9 & 6ox1000 km.  Never heard of such, is there one?
ronkom
THE MOTRESYKLMAN
Offline egschade
« Reply #82 on: June 25, 2020, 12:00:29 PM »
ronkom
It's behind the drain plug.
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline bald.male
« Reply #83 on: June 25, 2020, 12:33:42 PM »
Can anyone comment on plug gap? Manual says .9mm but factory (or dealer) set them around .6mm.
beetle
« Reply #84 on: June 25, 2020, 08:06:38 PM »
0.8/0.9 works well in the V7.
Oh, and I recommend setting the valves at 4 & 6 thou again if you are planning on a remap.
Offline Chethro
« Reply #85 on: June 26, 2020, 04:38:26 AM »
Thanks to all contributors to this thread!  :thumb:
My first service will be done next week and I printed this off for a great reference.
2018 DR 650
2020 V85TT
2022 V7 850 Stone
Offline bald.male
« Reply #86 on: June 30, 2020, 11:15:28 AM »
I'm just waiting on the cables, but how critical are these valve clearance values in your opinion? Are we talking about "for optimum results" or "bad things will happen" if not exact?
I haven't got a proper stand yet for my new-ish bike to make top dead center a snap for adjustment and wasn't planning to go at them again until 6,000 miles. Thoughts?
« Reply #87 on: June 30, 2020, 03:41:36 PM »
I had the same problem, can't get the back wheel off the ground so I sat on the bike and bumped it back and forth in top gear with a straw in place, its easier that way.
« Last Edit: July 01, 2020, 01:01:26 AM by Kiwi_Roy »
Offline Marquezdl
« Reply #88 on: June 30, 2020, 08:41:28 PM »
I fell in love with Mora laminated carbon blades 30 years ago. Unbelievable how easy it is to put a shaving sharp edge on them.
I have several!  Now if I had several Guzzi’s....lor even one!  I hope my tiger will complete its transformation into a V7lll dark this summer
