Anything plated 2013 will be roller. The changeover point was production in early to mid MY 2012.Pete
Hi all.Not sure if this has been covered before but was wondering what would be a reasonable expectation of the life expectancy of the engine and components ( mileage ) of the 8V Stelvio and its variants if looked after and serviced in a reasonable fashion?Many thx in advance......
“non replaceable front main bearing”?What the heck? Why in the world would they do that?
Saving nickels and dimes, the hard way.
One out of curiosity and one of the early ones to add washers to the shock absorber stack.
I’ve often wondered if the amount of drive line lash in my old ‘07 is representative of others.I have done the rubber bush in the torque arm mod and it did make a difference. Is the shock absorber stack to which you refer, there to remove some of this lash?I can ride with virtually none, but I tap the clutch very lightly when on/off the throttle in the lower gears.
Anything plated 2013 will be roller. The changeover point was production in early to mid MY 2012 . . .
The 'Rattle' issue shouldn't be a problem on your Norge.The backlash in the driveline that causes the 'Clank' is just that, backlash and its effect on the spinning gears and shafts in the gearbox exerting force on the reactive rod. Removing crush on the Cush drive will, if anything, exacerbate the 'Clank'.Pete
using a pressed in split bearing also made delivering oil to the under piston sprays easier.
The year of manufacture can be determined by the VIN.
Hey guy,s needing some help finding out how to obtain Roller kit from Moto Guzzi, i would very much appreciate the help. I have a 2012 ntx which i,m pretty sure would like to be rollerised before any damage is done it,s currently parked up with 29,000 klm on it Cheer,s Tim
