Author Topic: Bad Master Cylinder ?  (Read 2693 times)
Offline SmithSwede
  • I don't want a pickle
« on: May 26, 2019, 04:59:12 PM »
I’m trying to bleed a hydraulic clutch.  I’ve replaced the slave cylinder, and the hydraulic lines are pretty new.    Can’t really seem to get all the air out.  Will try again tomorrow.
Beginning to wonder if the master cylinder is worn, and thus not vigorously pumping fluid down the lines.   Or somehow sucking air back in.
How do you diagnose a bad master cylinder or one in new of rebuilding?  I knew the slave cylinder was bad because it was obviously leaking fluid.   The master doesn’t have an obvious leak.
Thoughts?   Tips?
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline troyhamilton
  • Dr frankie
Re: Bad Master Cylinder ?
« Reply #1 on: May 27, 2019, 04:33:29 AM »
You might try to bleed it with a mity vac set up.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Online Chuck in Indiana
« Reply #2 on: May 27, 2019, 05:24:33 AM »
Use a syringe, and push fluid up to the reservoir.
« Reply #3 on: May 27, 2019, 05:46:12 AM »
Thoughts?   Tips?
Well. What bike we are talking about would be a good start.......
Offline Darren Williams
  • Finally got me a Griso!
« Reply #4 on: May 27, 2019, 07:02:35 AM »
Tie the lever in against the grip with a bungie cord or similar for a while, Does it bleed off or will it not compress the plates at all? If it's the bike I think you are working with, you can easily see the movement.
If it is just air in the slave area (I had that happen once) compressing the air and releasing it while moving the slave around can get the bubble loose and let it travel up the line to the master cylinder. If bleeding and no visible leaks, that is probably seals and master cylinder will need rebuilding. Usually, but no guaranties.
Good luck sorting it out.
Offline SmithSwede
« Reply #5 on: May 27, 2019, 10:41:21 AM »
Sorry.  It’s a 1996 Ducati 900SS.
I’ve got a big horse syringe I’ll try today.
« Reply #6 on: May 27, 2019, 10:51:01 AM »
On a Ducati you should use a cattle syringe :grin:
Sorry, it's early.  The evening show should be better
Offline SmithSwede
« Reply #7 on: May 27, 2019, 11:50:13 AM »
At least you didn’t recommend I use Duck tape.
Offline Furbo
« Reply #8 on: May 27, 2019, 11:58:12 PM »
If the MC is original - yes, it needs a rebuild or replacement. That simple.
Otherwise, get it off the bar and stick a broom handle thru it and get if BELOW the slave cylinder. Bleed it then, hope that helps.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline SmithSwede
« Reply #9 on: May 28, 2019, 05:45:24 PM »
I found a new master cylinder for $89.  I'm going to replace it, and install an new line while I'm at it.
Offline SmithSwede
« Reply #10 on: July 08, 2019, 01:04:54 PM »
Just to close the loop on this.  I replaced the master cylinder, installed new Galfer lines, new banjo bolts and copper washers.
Works perfectly now.
Online PJPR01
« Reply #11 on: July 08, 2019, 04:05:52 PM »
This is the same one we looked at in Cedar Vale, right Prescott?  Sucking air in, did you tighten sufficiently the philips screws on top to get a good seal?  Found that on my Norge one screw had worked loose and was sucking in air and softening up the clutch once headed thru Santa Fe...a quick tighten and all was good again.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #12 on: July 08, 2019, 04:37:46 PM »
Thanks for posting the resolution.. :thumb:
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #13 on: July 08, 2019, 05:00:58 PM »
That reverse-bleed method is (I believe) oft-used with light aircraft, to good benefit.  I imagine a person would want to cover the paintwork and at least loosely put the m/c cover on to prevent a geiser of brake fluid from damaging the paint lest any cylinder stiction be encountered... That and use a turkey baster first...
On second thought, cylinder stiction is not a factor.  It is syringe stiction.
« Last Edit: July 08, 2019, 11:04:29 PM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline SmithSwede
« Reply #14 on: July 08, 2019, 09:14:38 PM »
Paul, yes, the red Ducati.   Works great now.  Of course, since I basically replaced everything in the hydraulic system with new parts, it had to work good!
By the way, a local body shop guy repaired and repainted the busted left fairing.   Good as new.   $300
I won’t be making that mistake again.
Online PJPR01
« Reply #15 on: July 08, 2019, 09:54:59 PM »
Excellent!  That was a painful sound for all of us hearing the Ducati go to sleep On its side!
Did you get the farkle for the reverse rotation exposed clutch?
Make it down to Houston last weekend?
Paul R
2008 Silver Norge
2002 V11 Scura
