Author Topic: V7 iii USB  (Read 3820 times)
V7 iii USB
« on: May 26, 2019, 05:26:11 PM »
The V7 ii has roughed in wiring for a USB connector, it talks about it in the manual, off one of the switched fuses.
Very handy for a GPS or charging a phone.
I took a look around the bike but I cannot see where the USB jack is to be located, can someone please enlighten me.
Thanks in advance.
Roy
Offline malik
Re: V7 iii USB
« Reply #1 on: May 26, 2019, 05:34:04 PM »
Someone with a III will be along later, but I thought the III had it hidden under the seat. The first 1TBs had it hidden under the facia beside the top of the LHS fork.
Offline Bigboy3000lbs
Re: V7 iii USB
« Reply #2 on: May 26, 2019, 08:46:27 PM »
 I believe what you are looking for is on the rear break side by the battery cover
« Last Edit: May 26, 2019, 08:47:47 PM by Bigboy3000lbs »
Re: V7 iii USB
« Reply #3 on: May 26, 2019, 10:29:10 PM »
That bike has what looks like a USB just in front of the side cover, not on mine unfortunately however I found a spare 2 pin connector under the side cover just next to the battery Positive terminal (about where it says V7), seems to be the right one, comes On with Fuse 5 as it says in the manual.
Also right there is the roughed in Bluetooth connector for cell phone link, missing the expensive part of course.
Thanks for that, saved me pulling the bike apart.
Roy
« Last Edit: May 27, 2019, 03:23:00 AM by Kiwi_Roy »
Offline ITSec
Re: V7 iii USB
« Reply #4 on: May 31, 2019, 10:42:36 AM »
Just a quick reminder to all - when installing a USB charging port, ALWAYS check that there is a drop from the bike's 12v to 5v somewhere, either in the USB plug you are connecting or elsewhere. Don't assume you are getting the lowered voltage from the bike's existing connectors or wiring without testing...
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Re: V7 iii USB
« Reply #5 on: May 31, 2019, 01:53:53 PM »
Plus one on that :thumb:
I usually use one of those plug in adapters just tear it out of the plastic package it comes in leaving the converter and socket to tape up.
The headlight bucket is a good spot to keep it dry and a convenient supply is the park (city) light.
Offline Red
Re: V7 iii USB
« Reply #6 on: May 31, 2019, 03:21:08 PM »
Manual says my V9 USB (top front frame) can only be used with Apple I Phone, Apple NANO, Blackberry. "Do not use with Motorola".
I have a Samsung; better charge it at home?!
72 XS 650 Original Owner
76 XLCH Sportster
14 Road King
16 Street Triple R
17 Bonneville T100
17 Moto Guzzi Roamer
Offline stimpoff
Re: V7 iii USB
« Reply #7 on: June 06, 2019, 05:39:20 PM »
Connector is hidden under battery cover like Kiwi_Roy described. Switched and fussed.
I just bought one of cheap 12V to USB converters + connector for few bucks on eBay
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=12V+to+usb&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=shelly
Conector is 2 pin female "Superseal" type (it was hardest part to find what put into google search :violent1:)
Stimpoff
Re: V7 iii USB
« Reply #8 on: June 07, 2019, 03:06:34 PM »
I have an adapter that plugs into my SAE battery tender connection.
Offline LBC Tenni
2011 GRiSO SE8V Tenni
Re: V7 iii USB
« Reply #11 on: June 07, 2019, 09:33:59 PM »
Yes those are good, I have one if only I could find it but they don't turn off with the key.
Re: V7 iii USB
« Reply #12 on: June 08, 2019, 06:16:34 AM »
True, but if you remove it after every ride and plug in the tender you'll never have an issue.
Re: V7 iii USB
« Reply #13 on: June 08, 2019, 09:10:13 AM »
Funny enough my new V7 came with an SAE connector, I thought those were only add ons.
Offline Bulldog9
Re: V7 iii USB
« Reply #14 on: June 08, 2019, 12:02:03 PM »
On the V7ii, the GPS lug is right behind the headlight, wire tied to the bundle. Not sure on the iii.
I also have one of these which works great too. Plug the lead into your tender port. I use it on longer trips when I need extra USB power.
 https://www.amazon.com/gp/product/B072JM3NWG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
MGNOC#23231
Re: V7 iii USB
« Reply #15 on: June 10, 2019, 07:02:18 AM »
If the dealers prep the bikes for test rides they usually add the connector so they can maintain the battery until the vehicle sells.  If they only prep the bike for the sale or for the "I'll buy contingent on the test ride", then they might not add it.
All my bikes are plugged into tenders between rides.  I've had batteries last 10 years that way.  I've had batteries fail because of bad cells as well so there are no guarantees that using a tender will solve that or make the bike start every time.
