Author Topic: New to me 850T  (Read 6612 times)
Offline Inshan
New to me 850T
« on: June 01, 2019, 10:33:02 PM »
Gentlemen (and Ladies!),
I'm rejuvenating a 75 850T that I picked up recently.  The plan is to get it mechanically sound, and address a few cosmetic issues.  It's not going to be a nut and bolt show deal.  This is my first older Guzzi so I will be asking lots of questions, and yes I always search before I ask.  The bike is a runner with lots of deferred maintenance.  Mostly original with some unfortunate ape-hanger bars, and wrapped headpipes.
Charging system was not working.  Diagnosed open rotor.  After weighing options I decided to purchase the Euro MotoElectrics Enduralast III upgrade:  https://www.euromotoelectrics.com/product-p/edl3-altkit105.htm
Tried installing today and ran into an issue with the stator.  New one seems to big for original stator frame.  May need to buy a different frame?  Haven't talked to them yet.
Going through the carbs tomorrow, have carb kits, viton tip float valves, and new fuel banjo strainers.
I want to order some Tygon from McMaster-Carr for the fuel lines.  Fuel system is original Dellorto VHB30s.  What size line do I need to order?
The breather hoses from the valve covers to the crankcase breather were sweating oil, so I removed them.  I cut the swage crimp off with a hacksaw, so I have the bare banjos now.  Is it OK to just run regular hose and clamps on that?  What have you guys done?
The bike has highway pegs with long studs that go through the crashbars.  I will be deleting the pegs and crashbars.  Any idea what the original size of the frame bolt is?
I'm also on the lookout for a set of original bars in nice shape.  MGcycle has some for $65 or so, but says they are not drilled.  I guess I can drill if necessary.
Re: New to me 850T
« Reply #1 on: June 01, 2019, 11:13:20 PM »
I use the 1/4" Tygon hose: https://www.mcmaster.com/5552K25
For breather hose, I use SAE 30R7 hose: https://www.mcmaster.com/54605K33
The bolt for use without crashbars is M12-1.25 x 30 IIRC.
Are you running the original handlebar switches? If not, then undrilled 'bars will be fine, the only reason for drilled 'bars is for the wiring of the original switches to snake through. I have a pair of original T3 'bars, but they aren't what I'd call in "nice shape".
Offline Turin
Re: New to me 850T
« Reply #2 on: June 01, 2019, 11:37:51 PM »
That's a lot nicer than mine was. Oil filter or early version sans Filter?
1985 Sidlow Guzzi
Offline Inshan
Re: New to me 850T
« Reply #3 on: June 01, 2019, 11:50:06 PM »
Charlie,
thank you for the help, much appreciated.
Will place MMC order now.
Yes, I plan on using the original switches at this time.  They all seem to work fine still.
Turin - I believe it's a NO filter sump.  Here's a pic of the pan... haven't dropped it yet.
Offline Turin
Re: New to me 850T
« Reply #4 on: June 02, 2019, 03:28:06 PM »
No filter, no problem. You'll just have to change the oil a little more often.
1985 Sidlow Guzzi
Re: New to me 850T
« Reply #5 on: June 03, 2019, 09:50:15 AM »
So, have you addressed the elephant in the room? (chrome bores)
Offline Jake
Re: New to me 850T
« Reply #6 on: June 04, 2019, 11:06:41 AM »
good buy - it's a fun bike (now, to get mine back in shape, right?)
change oil more frequent, yes -
switches:  originals = not if but when will they fail.  Easy to find replacements.
have you looked in the cylinders?  am told the chrome is another not if but when situation.
MG Cycle always been good to me :)
Granville, Ohio
1975 850-T
1977 R750/7
Re: New to me 850T
« Reply #7 on: June 04, 2019, 11:15:29 AM »
Put relays on every high load on the switchgear, and they'll last as long as you will.
Offline Inshan
Re: New to me 850T
« Reply #8 on: June 04, 2019, 03:44:37 PM »
Good info guys!  I haven't looked in the cylinders yet.  I was hoping that elephant would stay invisible for a bit longer until my $$ recovers.
If it doesn't have Gilardonis already, it will get them... it's just a matter of when, not if  :grin:
Unless Chuck has a magic solution to that problem like he did for the broken shifter spring on my Scura  :thumb:
Offline Inshan
Re: New to me 850T
« Reply #9 on: June 04, 2019, 08:07:51 PM »
The bike has 16" ape hangers on it. Thinking of switching to renthal high road bars. Anyone use those?
« Last Edit: June 04, 2019, 10:09:12 PM by Inshan »
Re: New to me 850T
« Reply #10 on: June 05, 2019, 09:01:22 AM »
Big castings and forgings are a *somewhat* beyond my little shop's capacity..  :grin:
Offline swooshdave
Re: New to me 850T
« Reply #11 on: June 05, 2019, 02:38:46 PM »
I put BikeMaster Superbike bars on mine. Totally will change your riding position.
2001 V11 Sport
Offline wirespokes
Re: New to me 850T
« Reply #12 on: June 05, 2019, 04:28:36 PM »
Here's a second vote for the superbike bars. Put them on the T3 and love em.
Offline geodoc
Re: New to me 850T
« Reply #13 on: June 05, 2019, 04:38:57 PM »
Also install one for the ignition (main power) switch. Otherwise the contacts on that old switch can drop a volt or even close to 2 volts across it.
https://archive.guzzitech.com/Dockray_key.html
Offline Gusable
Re: New to me 850T
« Reply #14 on: June 05, 2019, 05:49:38 PM »
Nice pussy cat
1994 California 1100
Offline siabeid
Re: New to me 850T
« Reply #15 on: June 05, 2019, 06:14:49 PM »
I use Guzzi SP bars on both my T3 and LM3. As far as I'm concerned they are perfect. A bit of lean and the angle for the wrists is a little nicer than superbike bend. They are all day comfortable.
Offline frozengoose
  • To eaches his onus...
    • smiles from nowhere
Re: New to me 850T
« Reply #16 on: June 05, 2019, 09:48:22 PM »
When I got my 850T, it had K&N super bike bars. I rode it like that for quite a while. but as age and arthritis intruded, I found a pair of Triumph bars from an old 650, bent them back a ways, and they're just about perfect now, take the weight off my wrists and forearms, so suits my current Alzheimers riding position!
« Last Edit: June 15, 2019, 03:22:51 PM by frozengoose »
Big Jon
Jerry Zee
Offline Inshan
Re: New to me 850T
« Reply #17 on: June 15, 2019, 01:38:37 PM »
Confirmed today, chrome cylinders still. Zero magnetic attraction. Had a little wishful thinking maybe they were replaced.  Will plan to replace maybe as Christmas present.
Have carbs apart now, finishing up charging system.
Seat pan is pretty rusted. Going to try to salvage since they seem to be scarce.
Re: New to me 850T
« Reply #18 on: June 15, 2019, 02:02:06 PM »
Keep the miles as low as possible until the cylinder upgrade or those chrome bores may add a lot $$$ to the cost of your Christmas present!
Offline Siamese
Re: New to me 850T
« Reply #19 on: June 15, 2019, 03:08:47 PM »
Yeah, nice kitty.
Offline redrider90
Re: New to me 850T
« Reply #20 on: June 15, 2019, 07:48:32 PM »
dropping those 16" ape hangers will maybe need new brake line and cable issues?
Red 90 Mille GT
Online nc43bsa
Re: New to me 850T
« Reply #21 on: June 15, 2019, 09:32:25 PM »
Is the seat pan the same as the 1000SP?
1990 MilleGT
Offline Turin
Re: New to me 850T
« Reply #22 on: June 15, 2019, 11:15:26 PM »
you may want to consider upgrading the brakes when you change out the brake line.
Here is my old set up: Guzzi-power adapter, stainless goodyear brake line, Brembo 4 piston caliper, EBC rotor with the factory 15mm master cylinder. Works pretty well, although the feedback from the lever is a little on the wooden side. Beats the hell out of the stock set up. The slotted EBC rotor not necessary, the factory cast rotors are great.
My T is a bit hot rodded so I recently went to a dual disk set up with dual 4 piston calipers.
1985 Sidlow Guzzi
Offline guzzista
Re: New to me 850T
« Reply #23 on: June 15, 2019, 11:24:59 PM »
No.  Gen 1 SP 1000 seat,   SPNT seat and 850T/T3 , G5 /Convert all bolt up interchangeably but  are slightly different  . Mark at Moto Guzzi Classics has  the current version available  on Ebay
https://www.ebay.com/itm/Moto-Guzzi-T3-G5-Convert-Seat/323813376391?hash=item4b64c80187%3Ag%3AoyIAAOSw57tc5GU5&LH_ItemConditi
Offline swooshdave
Re: New to me 850T
« Reply #24 on: June 16, 2019, 12:00:05 AM »
Once the sale on my 850-T is finalized (wire transfer issue) I'll have some spares to get rid of including original handlebars, rear fender and a funky seat.
The stock bars aren't bad at all. You may want to consider rear sets before going with lower bars.
If your crash bars aren't junk you should really consider keeping them. If they are junk I'd highly recommend finding another set.
2001 V11 Sport
Online nc43bsa
Re: New to me 850T
« Reply #25 on: June 16, 2019, 12:30:46 AM »
Goodridge brake line?
« Last Edit: June 16, 2019, 12:31:18 AM by nc43bsa »
1990 MilleGT
Offline Turin
Re: New to me 850T
« Reply #26 on: June 16, 2019, 12:45:43 AM »
autocorrected. goodridge, yes.
1985 Sidlow Guzzi
Offline Inshan
Re: New to me 850T
« Reply #27 on: June 16, 2019, 10:54:10 PM »
Thanks for the feedback.  No plans to hotrod this thing, have a Scura to scratch that itch.  Plan for the brake upgrade is the 12mm MC.  Have rebuild kit for caliper and new ceramic pads.  I do plan to get a new front brake line and re-install a tee with the brake light switch.  Right now I only have brake lights on rear brake.
Can't think about spending $$ on a seat until I get the chrome bores replaced.  I like the way the bike runs now, it's a cool putz-around-town bike with decent power.  Plan on getting Avon Roadriders as well.  Current tires are dryrotted.
Offline Jake
Re: New to me 850T
« Reply #28 on: June 20, 2019, 08:46:38 PM »
My T has the set backs for the handle bars - works well for me.     Steel brake lines made a huge difference - enough that I quite thinking about putting the 2nd disc on...and...ride within ones means, of course.  I use an Allyn Air Seat on top of the stock saddle - pretty comfy and not expensive.   As for tires, Bridgestone Spitfires have done well for me, too.    Enjoy the post- motivation it gives me.
Granville, Ohio
1975 850-T
1977 R750/7
Offline larrys
Re: New to me 850T
« Reply #29 on: June 21, 2019, 07:51:04 AM »
I have a pan from a '83 SP that I'd let go cheap. And, how did my cat get in your garage?
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
