Author Topic: First longer ride on my 02 California..  (Read 3518 times)
Offline s1120
« on: June 07, 2019, 10:40:02 AM »
Just picked it up in Dec, and its my first guzzi...  Well Ive been tooling around, fixing little things, and getting to know the bike the last month. Well yesterday i took a trip up to Americade in Lake george NY, and put in a 250mile day.  So off the rip I love the bike! Its a blast to ride, and will cruise at 75-80 all day long...  A few things came up...  I need to recheck the valve adjustment.. When it got hot one side seemed to put out more tapping sound then the other..  Easy check...  next I really need to map her...  she coughed and spit once in a while..  plus popping on shifting, and decell..  Next...  I gotta do the TB sync right away...  its clear one cyl is working more then the other. A lot of thumping when adding throttle, over and above what I feel is normal...  Next the oil has a little fuel smell..  Might have to do with long hot stop and go riding...  or the sync being off...  or the mapping..  Ill keep a eye on it. plugs look good.. Left bank might show a little more lean the the right... but neither is terrible.  Might have been loading up at low speed, and the plugs cleared off on the highway trip home..  So I got some work planned....  and a few things to keep a eye on. Loving the bike though!!
Paul B
Offline JC85
Re: First longer ride on my 02 California..
« Reply #1 on: June 07, 2019, 11:08:07 AM »
Any pictures of the pretty girl from the ride?  :gotpics:
'74 Eldo Police Model
'07 CalVin
Offline Gusable
« Reply #2 on: June 07, 2019, 11:15:06 AM »
Mines got the common tps stumble off idle and hiccups a little in the lower revs. Maybe yours does too. Fuel smell could be common fuel seeps from the plethora of fuel lines/regulators. ( same issues here)
1994 California 1100
Offline s1120
« Reply #3 on: June 07, 2019, 11:22:00 AM »
Some... my phone camera sucks, but I got a few...
Paul B
Offline wolfeguitars
  • Jay Wolfe
    • Wolfe Guitars
« Reply #4 on: June 07, 2019, 01:10:55 PM »
My '02 Cali. with "cough" a little when I'm going slow and too little rpm. I'm finding it likes more revs than one would feel is normal for a cruiser style bike, but it does redline at 8k! It'll not cough if I down shift or speed up slightly. FYI- My '02 is towing a hack, so it will likely behave somewhat different than yours. Mine will NEVER see anything near 8k of course BUT I enjoy pointing to the tach redline for my HD buddies. They instantly become speechless cuz they have no idea what that means....
I ride to work, ride to eat, ride to nowhere for nothing.
* Moto Guzzi 2002 California 1100EV w/ Sidecar
* Ducati 1990 851
* Ducati 1993 900 Supersport
Offline nsmith
« Reply #5 on: June 07, 2019, 01:59:35 PM »
Wolfe; just tell them you shift 3000 rpm after they blow up.
Neil formally from South Dakota now living it up in Arkansas
Offline s1120
« Reply #6 on: June 07, 2019, 02:51:24 PM »
I do really wish this bike had a tach.....  I really want to add one somehow.
Paul B
Offline s1120
« Reply #7 on: June 07, 2019, 05:15:43 PM »
So recommended valve clearance on these.....  4 and 6??    I see lots of debate on US vs euro spec... the 4 and 6 are the euro right?
Paul B
Offline ejs
« Reply #8 on: June 07, 2019, 05:30:04 PM »
Yes.
 0.10 and 0.15 mm
 :cheesy:
California EV 1999
Offline s1120
« Reply #9 on: June 08, 2019, 07:33:55 AM »
Whaaaa   valve clearance was out to lunch..  .010+ on ex, and about .008 on intake..  So I buggerd something up when I adjusted them last... Either set them wrong, or didnt tighten the lock nuts enough. Ill keep a eye on them..  No wonder she was clacking!!
Paul B
Offline Dilliw
« Reply #10 on: June 08, 2019, 08:38:45 AM »
If she's popping check for exhaust leaks and especially the crossover.
George Westbury
Austin, TX
« Reply #11 on: June 08, 2019, 08:58:40 AM »
Thats not loose, I thought my Lario was getting a little noisy so I took the tappet cover off, one of the screws fell out and dropped on the ground.
Enjoy your Guzzi, lots to love.
Offline s1120
« Reply #12 on: June 08, 2019, 02:02:36 PM »
Ya I checked it all over. All tight, no signs of leaks. It has a aftermarket crossover, Lafrancini [sp] mufflers, and a open airbox... my guess it was never mapped after the mods.
Paul B
Offline s1120
« Reply #13 on: June 08, 2019, 02:05:08 PM »
Thats what I thought I would find. :)   So i adjusted them, and took her for a ride today. Seems much better!  So I dont know what I did last time. Ill keep a eye to make sure they don't open up again.  Now I need to get to work on setting the TPS, and throttle balance!  Thats next on my list... Still loving the bike!!
Paul B
Offline xackley
« Reply #14 on: June 09, 2019, 10:35:20 AM »
With those symptoms I would try 5 ounces of seafoam.
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Offline s1120
« Reply #15 on: June 09, 2019, 11:21:26 AM »
I do have some, maybe I will. Fuel system was real clean though..  But a touch wont hurt. Today or tomarrow Ill set the TPS on it, and then hopefully get the TB's balanced..
Paul B
Offline Kent in Upstate NY
« Reply #16 on: June 09, 2019, 07:48:08 PM »
Crud in the tank will clog the petcock filter. Easy cleanup. Intake rubbers will have age cracks and leaks.
Offline xackley
« Reply #17 on: June 09, 2019, 10:19:14 PM »
Black gorilla tape work wonders for sealing cracks in the intake tube. Remove clamps, 2 layers of tape, clamp. Put them on the list of rubber parts that need replacing when it is too cold to ride.
Offline azguzzirep
  • Gratzi Carlo!
« Reply #18 on: June 10, 2019, 03:21:26 AM »
250  miles is just a warm up!!
I did over 2000 miles last year on a ride through southern France, Italy and back to Germany!!
Murphy's  Law sucks!
Offline s1120
« Reply #19 on: June 10, 2019, 05:51:05 AM »
I checked the petcock over the winter. Sparkling clean. Rubbers are also soft and pliable. I went through a lot of the bike over the winter. I just got it in dec so a lot was unknown.  Its only got 9K on it though..
Paul B
