Author Topic: rear flange out - crankcase damaged  (Read 2906 times)
Offline lazlokovacs
« on: June 09, 2019, 11:19:47 AM »
Calvin 1100 engine
rear main flange recently out
was flipp-------ing tight in there
factory tool couldnt move it, so pressed it out
made quite a -pop- when it let go
now there is a nasty nick/scratch on the crankcase (maybe it was always there?)
about to rebuild the engine, should I worry??
thanks to all as usual    :thumb:
Offline Gusable
Re: rear flange out - crankcase damaged
« Reply #1 on: June 09, 2019, 11:32:28 AM »
Pookey.  Permatex ultra black
1994 California 1100
Offline Rolf Halvorsen
« Reply #2 on: June 09, 2019, 12:09:14 PM »
No problem. The damaged has no function. You seal the rear crank bearing with a paper gasket.
« Reply #3 on: June 09, 2019, 12:46:15 PM »
 Yes , go ahead and worry.
« Reply #4 on: June 09, 2019, 01:05:39 PM »
Check for a burr on the main bearing that could have caused this, carefully remove if there is one. Carefully remove any burr on the case that may make it harder to insert the main bearing or that might interfere with gasket sealing.
It might help if you can warm the case and chill the bearing before assembly.
« Reply #5 on: June 09, 2019, 02:08:51 PM »
It looks like a burr or maybe a machining chip was on the bearing carrier. I'd file it off, measure both if you have the capability, and don't worry, be happy.  :smiley:
Offline lazlokovacs
« Reply #6 on: June 09, 2019, 04:07:38 PM »
thanks guys as ever!
while I'm at it, anyone got a good trick for getting that gasket off???
« Reply #7 on: June 09, 2019, 04:17:46 PM »
This works as well as the purpose made gasket remover:
If the gasket is really stuck on, I've found that using a heat gun to make it soft makes it easier to remove.
Offline pete mcgee
« Reply #8 on: June 09, 2019, 05:42:14 PM »
Patience, elbow grease and a sharp one sided razor blade.
Offline swooshdave
« Reply #9 on: June 09, 2019, 05:56:25 PM »
I tend to nick the aluminum with a razor blade. I use a scotchbrite pad.
2001 V11 Sport
« Reply #10 on: June 09, 2019, 06:30:17 PM »
I have a Toyota gasket scraper. It's brilliant! Best scraper I've ever used. Really.
As for the mark on the case? I wouldn't worry unduly. Use a thin smear of threebond on the new gasket and it will seal it just fine. DO NOT squeeze it on like toothpaste!
Offline wirespokes
« Reply #11 on: June 09, 2019, 07:17:29 PM »
Pete - I just searched for Toyota gasket scraper and came up with ordinary scrapers and some sort of crankshaft oil scraper gasket. No Toyota gasket scrapers.
Will they know what i'm asking for at the Toyota parts desk?
Could you post a foto of this thing?
Offline acogoff
« Reply #12 on: June 09, 2019, 07:27:04 PM »
     Never used them but there is such a thing as a plastic razor blade.
  https://www.amazon.com/Plastic-Double-Edged-Razor-Scraper/dp/B004623NU2
Marshall County Minnesota USA
Online rschrum
« Reply #13 on: June 09, 2019, 08:09:33 PM »
Sharp wood chisel, best I've used.
15 GRISO
21 streetfighter v4s
24 zx14r 40th anniversary
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
« Reply #14 on: June 09, 2019, 10:43:06 PM »
Wait until tomorrow, (It's a public holiday here today and I can't be arsed going to the workshop.) and I'll give you a pic and a part number! :grin: :thumb:
Offline dguzzi
« Reply #15 on: June 10, 2019, 12:38:44 PM »
Beryllium scraper....  Likely Beryllium/copper... But its overkill.
« Last Edit: June 10, 2019, 12:39:59 PM by dguzzi »
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
