Author Topic: 2.5” Monza gas cap on a V9 Roamer  (Read 1674 times)
Offline Neogas
« on: June 11, 2019, 07:11:35 AM »
Hi all,
Just after some thoughts on how a Monza gas caps looks on the V9. I like it, but I am still unsure as I can see the cork gasket and I worry it sits a little too high.
Could find one for a Guzzi, but research said the Bonneville one will fit.
What’s the consensus?
Experience is something you don't get until just after you need it.............
Online frozengoose
  • To eaches his onus...
    • smiles from nowhere
Re: 2.5” Monza gas cap on a V9 Roamer
« Reply #1 on: June 11, 2019, 11:43:49 AM »
Hi all,
Does look a little tall, but gives it a "classic" look, kind of like the kind on the 850T/T3. That style of tank needs all the help it can get, it's certainly not to my taste!
Big Jon
Jerry Zee
Offline menzies
« Reply #2 on: June 11, 2019, 03:04:46 PM »
The same happens on the Bonnies so a lot of folks take the cork gasket out so it will sit lower on the tank, they do not seem too have any issues with seepage or leaks.
2001 Triumph Bonneville
2007 Triumph Bonneville
2006 Triumph Scrambler
Online frozengoose
« Reply #3 on: June 11, 2019, 03:24:12 PM »
Here's a link to those early style gas cap, not sure if it'll fit the newer tanks tho. It says:
Consult your parts manual for proper fitment, 48mm Seal Ring
Please compare to current cap. Fit later model V7 Sport and Eldorado, T3, 850T, Lemans 1, early Convert.
https://www.ebay.com/itm/Moto-Guzzi-Fuel-Gas-Tank-Cap-850T-T3-V7-Sport-Convert-13103960-Ducati-Laverda/3230888499
« Last Edit: June 11, 2019, 03:29:32 PM by frozengoose »
Big Jon
Jerry Zee
Offline grebmrof
« Reply #4 on: June 11, 2019, 05:56:17 PM »
I used one on a Bonneville for a while, but ended up removing it as I continued to smell gas with every ride.  Sold it and went back to a stock cap, problem over.  I like the mechanics of the Monza, but that was it, it was a stinker for me.
'08 Triumph Bonneville T100
