Author Topic: Peg Nut Replacement?- Crank & G/Box Input Hub  (Read 2651 times)
Offline 1down5up
« on: June 13, 2019, 09:36:41 PM »
Hi All,
I recall reading somewhere that there are standard "hex" replacements for the Crank & G/Box Hub peg nuts for tonti's (t3/lemans etc), i have searched but haven't been able to find any older posts.
Believe they may have been used on later guzzi's (v11's etc)?
Does anyone have a part number for these replacements, and do they still use the tab lock washer?
Offline 1down5up
Re: Peg Nut Replacement?- Crank & G/Box Input Hub
« Reply #2 on: June 14, 2019, 04:53:23 PM »
Many thanks, now to see if I can find a long enough socket for the crank nose
Crank nut: http://www.mgcycle.com/index.php?main_page=product_info&cPath=68_126&products_id=1451
Washer used with it: http://www.mgcycle.com/index.php?main_page=product_info&cPath=68_126&products_id=1505
For the input shaft of the 5 spd. I use an output shaft nut with the "lip" ground off, secured with threaded locker.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=55&products_id=507
