Author Topic: Bassa , a few questions  (Read 2669 times)
« on: June 14, 2019, 07:40:15 PM »
 1. What is the small Allen screw located at the top rear side of the shocks for ?
 2. Why do the fork seals on the non-adjustable forks never seem to leak , while the adjustable forks on the EV and Bassa models always seem to weep ?
Re: Bassa , a few questions
« Reply #1 on: June 14, 2019, 07:46:26 PM »
(1) I have no idea.
(2) I'm *guessing* that the adjustable forks are designed with less stiction, and the seals are more delicate. Certainly the Ohlins seals on the V11S don't last as long as the less expensive spread.
« Reply #2 on: June 14, 2019, 08:24:00 PM »
1. If that Allen is on the underside of the frame , they are plugs.  I was on a ride with John Ulrich who has a beautiful white Bassa, perfect machine. We were parked and I noticed a rust spot on the top of one of his mufflers, I of course politely pointed the unsightly gob to John. Turns out the Allen plugs were missing and it happened when the bike was parked at a certain angle, water from a recent wash drained out.   I tried to not let the other guys tease him so unmercifully but great sport was had by all.
2. I donno?
« Reply #3 on: June 14, 2019, 08:27:32 PM »
2. I donno?
 Allen is on the top rear of the shocks John .
« Reply #4 on: June 14, 2019, 08:33:15 PM »
Do you think it's a fill hole for the oil?  I never took the plastichrome covers off the top of mine to notice the top of the shocks.
« Reply #5 on: June 14, 2019, 08:35:53 PM »
 Had that thought . There doesn't appear to be any adjustment on the shocks , which seems weird .
« Reply #6 on: June 14, 2019, 09:14:08 PM »
I've not seen what you are describing.  On my Bassa there is way to adjust spring preload. There is a circlip with three grooves. You have to compress the spring, like you were taking the spring off to change grooves. Not for the faint of heart
« Reply #7 on: June 14, 2019, 09:21:10 PM »
#3, are these shocks worth keeping?   No
« Reply #8 on: June 14, 2019, 09:34:19 PM »
 They are under the chrome cover at the top . Will take the bags off and look for any adjustment .
 Dunno , they seem to work alright .
Offline bad Chad
« Reply #9 on: June 14, 2019, 09:46:39 PM »
Stock Bassa stocks will crush your spine.  I put a set of Ikon made a huge difference.
1988 YX600 Radian
Offline John Ulrich
« Reply #10 on: June 14, 2019, 10:31:28 PM »
A picture’s worth a thousand words.
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
