Author Topic: '96 Cali i running rich  (Read 1704 times)
Offline flower_king001
« on: June 15, 2019, 12:26:57 AM »
1996 Cali i
right side spark plug looks ok..but only ok
left side spark plug dry/black
compression (hot motor / WOT) 180 psi both cyl
Thoughts where to start?
« Last Edit: June 15, 2019, 08:55:47 AM by flower_king001 »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Re: '96 Cali i running rich
« Reply #1 on: June 15, 2019, 09:10:26 AM »
Weak spark Would do it. Maybe swarf stuck on the sensor in the bellhousing.
Offline Idontwantapickle
« Reply #2 on: June 15, 2019, 09:13:40 AM »
Check the basic tune up first.
Valves, timing, throttle balance and cables. Clean the throttle bodies too.
After all of that is done and the problem persists it could be leaking injector or other similar minor or intermittent failure.
Most problems are found by going through the basic maintenance items.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Gappy
  • StLouis MO
« Reply #3 on: June 15, 2019, 09:21:46 AM »
I would check to see if the fuel enhancer or choke is fully closed and put a new set of plugs with the correct heat range in. Start there and work your way back. Checking to see if the spark plug leads are not leaking spark and are in good working order.
2003 Suzuki burgman an650
1994 Moto Guzzi California 1100
1992 BMW k75s
1983 Harley Davidson FLHT
1981 BMW r100rt
1981 Honda 650/4
« Reply #4 on: June 15, 2019, 10:52:54 AM »
My first thought, too. It *could* be nothing more than a bad plug/cap/cable..
« Reply #5 on: June 15, 2019, 11:36:22 AM »
Yes, I have new plugs, wires/caps and air-filter on route from MGCycle
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline pehayes
« Reply #6 on: June 15, 2019, 12:31:51 PM »
Where does this model get its engine temp reading?  Left valve cover like the 98?  Elsewhere?  Check for an accurate temp reading.
« Reply #7 on: June 15, 2019, 12:57:41 PM »
Yes Patrick...left valve cover like a 98 EV. I will check that as well
thanks!
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #8 on: June 15, 2019, 03:02:12 PM »
Check OHM on spark plug wires
Side that is running richer reads
4.5
Side running better reads
5.2
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
