Author Topic: '98 V11EV Throttle Position Sensor  (Read 2101 times)
Online n3303j
  • Ron Cichowski
« on: June 22, 2019, 09:23:32 PM »
Last season I re-read all the info on synching throttle bodies and setting throttle position sensor correctly.
I went through the procedure and the bike has been running well ever since (wasn't bad before). I did have a lot of fun with all the details and was pleased with what I have learned.
But I have never been thrilled with the fuel consumption on this bike coupled with its small tank. Son-in-law remarked that it smelled like it was running a bit rich.
I figured that the TPS tells the control unit how wide the butterfly is open. The control unit adds the proper amount of fuel to work with that figure. The higher the voltage the more fuel delivered at each cycle.
So if I were to set the TPS voltage a bit lower than the standard number, the control unit would be delivering a bit less fuel at every throttle position. Therefore I would effectively lean the mixture over the whole throttle range.
Anyone done this with positive results? Any reason I shouldn't try? Hot run / ignition chop / plug inspect a good way to judge mixture at speed?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online fotoguzzi
Re: '98 V11EV Throttle Position Sensor
« Reply #1 on: June 22, 2019, 10:42:58 PM »
I think your problem might be in the fuel trim setting...
Have you tinkered with the trim dial that's on the side of the computer box? (Under a rubber plug)  It's said to trim the fuel amount at idle but I found it altered how the motor ran further up the rev range.
That dial has a range of maybe 2 revolutions each direction then it has no effect and can even become disconnected so don't dial it too far.
If you do any adjustment to it take a ride of 10 minutes or so, I think the CPU has to learn the new setting? On one of my 98's I turned the dial pretty much cause it didn't seem to change anything then went on a ride and after a few minutes ran horrible, all rough and cutting out, I think it even died.. took me awhile to discover the dial was the cause.. so, turn at your own risk and only about a quarter or half turn at a time.
This on the p8 cpu in the 98 EV, after that (99 Bassa, 2000 EV with the 5m the trim is set with computer via guzzidiag or techno research software.
 I think the FI supplement manual tells which direction to dial for a leaner mix.. I don't remember. now, that was probably 9 or 10 years ago.
If you had a Co  reader you could know just what the mixture is while idling.
« Last Edit: June 22, 2019, 10:54:52 PM by fotoguzzi »
Online JoeB
« Reply #2 on: June 23, 2019, 06:42:28 AM »
[quote author=fotoguzzi link=topic=101542.msg1605741#msg1605741 date=1561261378
[/quote]
"Turning the screw clockwise leans the idle mixture"
https://dpguzzi.com/efiman.pdf
I marked it on the box so I'd know when adjusting it. LOL I don't remember things easily.
« Last Edit: June 23, 2019, 06:43:02 AM by JoeB »
Offline flower_king001
« Reply #3 on: June 23, 2019, 06:44:11 PM »
Been thru the same....
1. check plugs
2. check air-filter. IMHO a K & N flows better than the stock paper
3. If still carbon plugs adjust fuel trim. Clockwise > lean Counter Clockwise > rich
Even after all this I still get in the mid 30's on the highway with my 1998 EV. Running between 75 and 80 mph
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
« Reply #4 on: June 23, 2019, 08:06:12 PM »
Use a non metallic screw driver or put some heat shrink on the shank or be careful to not short anything with the screwdriver , I'm led to believe the ECU  can be damaged that way.
« Reply #5 on: June 24, 2019, 08:00:15 AM »
http://ca-cycleworks.com/efi.html
Maybe one of these TPIs is the right one. Prices seem decent,  someone here posted this link a few years ago and I saved it.
« Reply #6 on: June 24, 2019, 09:18:12 AM »
Yes, PFC3 works fine on a 1998 EV as I have been running one.
http://ca-cycleworks.com/pf3c.html
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
