Author Topic: Throttle not snapping shut  (Read 1241 times)
Pizza Guzzi
« on: June 29, 2019, 11:38:41 PM »
Quick backstory - I recently added a Breva 1200 to my fleet. The sacred screw had been molested but ran ok. I happened to pick up a nice clean used set of TB's with untouched throttle stop screw and fitted them today.
Everything went beautifully only problem being the throttle sort of slowly glides closed rather than snapping shut when the twist grip is released.
1. Both return springs are intact on the TB's and with throttle cables disconnected snaps closed when opened by hand.
2. I have not re routed throttle cables in any way.
3. I have not attempted to lube the throttle cables at all.
4. Cable adjustment seems correct with a small amount of slack in the throttle cable at rest and a bit more slack in the return cable.
5. I disconnected the throttle cables at the twist grip end to give me enough slack to remove / replace the cables at the bell crank when fitting the new TB's. I didn't readjust the cables at the bars because the cable slack felt good.
6. Throttle used to work normally
Am I correct in thinking there is no return spring at the handlebar end ?
Any suggestions welcome.
Glenn
Online Tom H
Re: Throttle not snapping shut
« Reply #1 on: June 30, 2019, 12:40:47 AM »
Not knowing a Breva....
My EVT had a slow throttle return. The bike has like a bar end weight factory stock. Turns out the weight was up against the hand grip ever so slightly, It was just enough to not allow the grip to snap back.
Just a thought,
Pizza Guzzi
« Reply #2 on: June 30, 2019, 01:02:59 AM »
Thanks Tom, turns out a little more slack in the throttle cable and all is well !
Glenn
