Author Topic: Griso - wet misfire, again.  (Read 6740 times)
Offline Trogladyte
  • Location: South London - home of the world's best football team.
« on: July 01, 2019, 07:47:26 AM »
I thought I had finally cured this, but after washing the bike yesterday, it seems not.
Bike is a 2008 Griso 1200 8v.
Symptoms - when it gets wet, it misses on the right hand side. It runs on one, until there is a wide throttle opening/higher revs, when it suddenly kicks onto two.
I thought I'd cured it twice. 1st time I replaced the plug, NGK plug cap, and HT lead. It then ran fine with a hose pouring water onto the r/h side. Until it didn't and started missing again. So I noticed that the plastic plug on the injector was cracked, so I replaced the injector.
Again all was well for a while. But after washing the bike yesterday, the old symptoms were back again. I took the plug cap off, and plug out. The boot and plug cap were bone dry, but I gave them a good clean. Also took the ht lead out, cleaned and dried connection, and reassembled. Took the lt plug off the coil, dried, cleaned and reassembled.
I still have an issue. It is better than it was, but still intermittently going onto one, then kicking back in as revs rise. Although oddly, it runs on two at idle.
What's next? I feel a bit stumped.
« Last Edit: July 01, 2019, 07:49:43 AM by Trogladyte »
Offline Trogladyte
Re: Griso - wet misfire, again.
« Reply #1 on: July 01, 2019, 07:53:42 AM »
Incidentally I have posted about this before.
https://wildguzzi.com/forum/index.php?topic=90674.0
I should probably have gone back to the original thread. But there's the link. In that thread I had incorrectly described it as l/h misfire. it's definitely right hand side.
« Reply #2 on: July 01, 2019, 07:59:35 AM »
It's obviously related to water ingress somewhere on the high tension side. Stop bloody washing it!
Offline Dilliw
« Reply #3 on: July 01, 2019, 08:07:59 AM »
Bummer.  When you swapped the caps did you get the right seals?  In the U.S. we don't get the SD05E which has the proper boot on the end.   The NGK caps cured my bike's alergic reaction to water.
George Westbury
Austin, TX
Offline Trogladyte
« Reply #4 on: July 01, 2019, 08:45:00 AM »
Yeah...it does it in the rain sometimes too.
But is it on the HT side? I have replaced everything but the coil. That, and the way it cuts in at higher throttle openings is starting to make me suspect injectors rather than HT. I've replaced the injector. Could it be the injector wiring? How would I check?
This is starting to drive me slightly loopy-loo. I was probably a bit that way already, so this isn't good.
Offline Trogladyte
« Reply #5 on: July 01, 2019, 08:48:10 AM »
I've got the NGKs, but not the right boots. But I don't think the problem is in this area. I took the cap off yesterday, when the problem occurred, and it was bone dry. I cleaned it all up anyway, including the plug, but the problem persisted.
If the problem is spark rather than fuel, it can only be the coil.
Offline Dilliw
« Reply #6 on: July 01, 2019, 09:07:59 AM »
Just to be sure I'd order the SD05F caps and swap the boots off.  It's cheap insurance.
Wouldn't it light a code if it were the coil?
George Westbury
Austin, TX
« Reply #7 on: July 01, 2019, 11:33:39 AM »
Sounds as though you have tried everything
The spark has a harder job jumping the plug gap with more throttle so it will find an easier path
Di-electric grease on the plug boots and wherever the cable connects will exclude moisture.
Try swapping components from one side to the other.
I don't think water would effect the injectors but make sure there is no corrosion in the connectors I would use Vaseline there.
Wait a minute the Griso has double ended coils with two plugs per cylinder, the inner ones are hard to get at have you cleaned those.
While you have it apart measure the resistance from inner cap to outer cap, both sides should be identical.
http://www.thisoldtractor.com/guzzi007/schematics/2006_Griso_1100.gif  Items 40 thru 45
« Last Edit: July 01, 2019, 11:39:39 AM by Kiwi_Roy »
« Reply #8 on: July 01, 2019, 11:58:16 AM »
Have you tried a trigger spray bottle of water to help narrow down the area that is causing the problem when wet? Also when wet, have the bike in a dark place, you might see arcing?
Just a thought,
Offline Trogladyte
« Reply #9 on: July 01, 2019, 05:19:11 PM »
This is a 1200, so single plug.
I had just about convinced myself that this was an injector problem rather than HT. I cleaned up the connector to the r/h injector (again) this evening. The rubber boot is perished and split, so i taped that up - but the wiring looks sound anyway.
I'm starting to think HT again.
I think I might swap the coils and see if the problem goes with the coil.
I rode it to work today. I had a fair bit of missfiring on the way in, but it was much better, and almost back to normal on the way home. So whatever has suffered from water ingress takes a while to dry.
« Reply #10 on: July 01, 2019, 05:40:50 PM »
Ok, then measure from each plug cap to chassis, both sides the same, i'm guessing 8,000 Ohms
This will confirm the coils and leads are connected
I don't think it will be a coil, sounds more like something shorting, I like Tom H's idea
Offline Trogladyte
« Reply #11 on: July 02, 2019, 08:24:54 AM »
|I have actually done that. No sign of sparks in the dark. And it ran fine with a hose on it after I replaced the HT leads and plug caps.
But the problem has returned.
I'll try again.
« Reply #12 on: July 02, 2019, 08:52:26 AM »
I looked through your earlier posting, this caught my eye.
I paid particular attention the left hand injector wiring. The contacts did have some mild corrosion.
Perhaps there lies the problem, some resistance causing the connector to change when wet, the injector wiring needs to be perfect because the injector pulses are very short and high current.
You already changed the injector perhaps it was the plug?
Offline Trogladyte
« Reply #13 on: July 02, 2019, 09:54:06 AM »
Yes, I agree.
If the problem is with the HT system, I think it has to be the coil, as I have replaced the plugs, plug caps and HT leads. Twice! I think I should be able to rule this in or out by getting the problem to happen, and then swapping coils.
I will also try selectively wetting the injector wiring. As I said, the rubber boot protecting the wiring into the plug is split, but the wiring itself looks fine. Nevertheless I have sealed it up with tape, cleaned the contacts in the plug and socket and put it all back together.
If it turns out that the plug is indeed faulty, is it possible to change that plug without splicing into the loom? I assume those plugs are available from somewhere. Are they?
Offline Two Checks
« Reply #14 on: July 02, 2019, 10:37:05 AM »
With all this misfiring the spark plug may be bad.
Doesn't cost much to find out.
1987 1000 SPII "Il Duce' II"
Offline Trogladyte
« Reply #15 on: July 02, 2019, 10:39:00 AM »
Done that. Changed them twice.
« Reply #16 on: July 03, 2019, 10:46:40 AM »
Reading the previous thread again
Pete said,
"Go into the menu, scroll to 'Diagnostics', enter the code 12425, scroll to ECU errors and see if any are active and then go to dashboard errors and see if any are active or memorised.
Do this when its firing on one as if there is an ECU error it won't list it as memorised, they only show up when active"
You should get an error message, I believe the ECU will detect the circuit is open.
But only while the error is active.
Or go over all the connectors again they should be pristine.
Offline Trogladyte
« Reply #17 on: August 01, 2019, 11:59:07 AM »
In case anyone is interested, here's where I got to.
I cleaned up all the connections. Again. I then borrowed a new coil off a friend (thanks Baldrick), and fitted it on the right hand side. I then started the bike, and attacked it with a hose, gently at first, but eventually I replicated absolute Biblical rain - full pressure water straight at the coil, the HT lead, the injectors, and finally, I shoved the hose straight into the gallery above the exhaust, and totally flooded the plug and plug cap, so that water was pouring Niagra-like from the plug gallery drain. And still it ran fine. I turned it off and soaked it again. It started and ran. And again. And again. No amount of water would make it run on one.
I bet it's not fixed. I will report back the next time I ride it in heavy rain. I'm in London, so it won't be long.
Offline Dilliw
« Reply #18 on: August 01, 2019, 01:54:53 PM »
Well it is an Italian mistress :)
I'm betting you got it  :thumb:
George Westbury
Austin, TX
Offline Trogladyte
« Reply #19 on: August 01, 2019, 03:24:56 PM »
:grin:
I really hope you're right! But I have some experience of Italian mistresses. :thewife:
I travel everywhere, including to work and back every day, by bike. For complicated reasons, I'm riding a KTM Superduke 1290R as my main bike right now. Ideally, I'd like to use the Griso as my main bike through the coming winter - but to do that I need to be able to rely on it in the rain!
Online Bulldog9
« Reply #20 on: August 01, 2019, 05:57:08 PM »
Running all that water into the motor... :shocked: I hope you at least ride it till the engine is hot and everything's dry or blow all the water out.
MGNOC#23231
Offline lucian
« Reply #21 on: August 01, 2019, 07:20:29 PM »
I would start by getting a can of de oxit and pulling every connector , relay and fuse on the bike and giving them a squirt.  It's always better still to do it before corrosion takes hold.
Offline Trogladyte
« Reply #22 on: August 02, 2019, 05:40:19 AM »
Yes - I did, eventually. But I wanted to get it really wet. It still ran perfectly, when VERY wet.
When I'd finished, I blew everything out with compressed air, and then rode it for an hour or so to get it fully up to temperature.
So far, so good.
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
« Reply #23 on: August 02, 2019, 08:29:31 AM »
You may have ruled out the HT Leads and/or Caps, but I'd still replace the original type Caps with the Red all-rubber type.
You get rid of two potential leak-points on each Cap by not having a rubber Boot at each end.
They're much easier to remove as well, so you negate the possibility of damaging the Leads and/or Caps as well.
They stick out the top a little when fitted, but as they're just rubber at the top, they flex enough to fold down under the little Cover-Plate.
Had mine on for nearly two years without issues, even in torrential rain.
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
Offline Trogladyte
« Reply #24 on: August 02, 2019, 02:15:20 PM »
Interesting.
I have replaced the plug caps with the NGK ones that folk on here have recommended. Do you think the red rubber ones are better?
Offline Trogladyte
« Reply #25 on: August 02, 2019, 03:24:32 PM »
Pete said,
If the problem happens again, I'll try to do this. I probably won't stop and do it in the middle of South London bandit country on my way home, but assuming it does it after a wash outside the garage, it will be fine.
And does anyone know what the best way to change the plugs that plug the loom into the injectors? Are the plugs available separately? Do I need to hack into the loom?
Offline frozengoose
  • To eaches his onus...
    • smiles from nowhere
« Reply #26 on: August 02, 2019, 04:20:04 PM »
The title reminds me of my first college date, but that was mostly a timing issue.
Good luck in bandit country!
Big Jon
Jerry Zee
Offline Guzzistaracing
  • Norwegian with a love for all Italian
« Reply #27 on: August 03, 2019, 07:15:13 PM »
How many times does this problem have to be posted!? It is covered in absurdum on this forum.  :violent1:
Ex.85�suzuki katana
 85`Le Mans 1000
`?? 1100 sport
`51 Ariel KH500
`07 Griso 850, black
`71 Nuovo Falcone civile
`78 BMW R100RS
`98 Centauro
`07 Norge
Current:
`99 Quota
`84 V65
Online Ncdan
« Reply #28 on: August 03, 2019, 09:36:18 PM »
Tro, Antmanbee just went through an extensive water issue with his Griso and I think he found some of the issues. Maybe check with him to see what he found to be water related issues.
Offline antmanbee
« Reply #29 on: August 03, 2019, 09:50:12 PM »
My issues were fuel related due to water and my symptoms were a bit different than Trogs. I am pretty sure Trogs are ignition related.
But here is links to my threads.
https://wildguzzi.com/forum/index.php?topic=101479.msg1604955#msg1604955
https://wildguzzi.com/forum/index.php?topic=101652.msg1607709#msg1607709
