Author Topic: geez, I don't remember the steering head nut this proud when disassembled?  (Read 1762 times)
Offline amamet
putting my 77 lemans back together from being apart since last year, after reinstalling the triple clamps, the top triple has about an 1/8" play up and down.  I definitely don't remember that when I took it apart. the head nut is longer than the body of the upper triple so I don't know how it would be flush anyway. it appears to be flush in older photos of my bike.  do I just raise the upper triple when I lock it onto the forks?  the second photo is me just holding the triple up to nut.
Sure looks like a spacer is missing between the nut and the clamp.
« Last Edit: July 13, 2019, 06:02:13 PM by Wayne Orwig »
Offline amamet
all parts taken off were put back on...and looking at a schematic everything is correct
Offline 1down5up
It looks like you might be missing the washer between the dust cap and nut - but that's not going to take up that much slack...
Offline amamet
Nope, it’s there. The washer is on top of the nut. Dust cap, nut, washer, upper triple and lastly the steering head nut
Offline acogoff
     Did you by any chance put in new bearings and races? A race not driven fully home would cause such.
Marshall County Minnesota USA
Offline amamet
Nope again, just reinstalled as it was removed. All parts the same
Offline amamet
the second photo shows, from the bottom up, the dust cap, steering head nut, washer then the lower part of the body of the top steering head nut.  I can't figure out how the upper triple doesn't "float" along the body of the top nut.  I've included the schematic from stein dinse
« Last Edit: July 14, 2019, 07:43:32 AM by amamet »
Offline Dimples
If everything is accounted for on top, maybe something is missing from the lower triple tree assembly.
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
