Author Topic: Timing Chain Tensioner old bolts  (Read 2405 times)
Offline Bob_Fla
« on: July 22, 2019, 07:54:34 AM »
I've removed the old block tensioner on my 850 and replaced with a blade.
Two questions:
- The blade is VERY tight, is that normal?
- Do the old block tensioner bolts and spacers need to be replaced?
1984 Guzzi T5
1973 Hodaka
(1998 Ducati 916) Sold
Online John A
Re: Timing Chain Tensioner old bolts
« Reply #1 on: July 22, 2019, 07:57:32 AM »
Yes they are snug, no reason to replace the bolts unless they have a defect.
Offline Bob_Fla
« Reply #2 on: July 22, 2019, 08:04:46 AM »
About replacing the bolts - I'm referring to the ones that were holding the old tensioner. Do the bolts that held on the old tensioner have to be replaced even though they do not hold anything any more?
1984 Guzzi T5
1973 Hodaka
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #3 on: July 22, 2019, 08:08:46 AM »
OP, I don't know about bolt replacement (though I am guessing - it is not required) - but I have to ask you: i) what year / model of Guzzi do you have; and ii) did you find any Locktite or other thread-locker on any of the sprockets (assuming you removed the sprockets / timing chain to make the change-of-tensioner) - and generally, how hard was it to remove the timing chain / sprockets?
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Online John A
« Reply #4 on: July 22, 2019, 08:10:34 AM »
Nope, sorry I wasn't clear, the bolts are fine for reuse unless they have an obvious defect.
Offline Bob_Fla
« Reply #5 on: July 22, 2019, 08:21:28 AM »
First, my bike is a 1984 850 T5.
And I think my question needs more clarification.
The old block tensioner was held by a horizontal plate secured with two bolts. The two bolts that held the old tensioner had spacers to hold the plate at the correct depth. The new blade tensioner is held on by two different bolts.
Do I need to replace the old bolts and sleeves even though they are not holding anything?
1984 Guzzi T5
1973 Hodaka
« Reply #6 on: July 22, 2019, 08:24:01 AM »
No, you do not need to reinstall those old bolts and spacers.
Offline acogoff
« Reply #7 on: July 22, 2019, 08:25:49 AM »
    If'n the bolts no longer are for anything , leave them out. And yes the blade seems extremely tight. Thought the same thing 30,000 miles ago when I installed mine and it is still wirring away and the oil pump bearings still are holding up. :thumb:
Marshall County Minnesota USA
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #8 on: July 22, 2019, 08:32:35 AM »
Some images...
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #9 on: July 22, 2019, 12:02:08 PM »
OP, can you please indicate ease (or not) removing timing chain, sprockets (or maybe you did not do so)?
Offline Stevex
« Reply #10 on: July 22, 2019, 02:59:04 PM »
When I replaced the timing chain and tensioner on mine I removed only the lower sprocket, easy enough to do*. To split the old chain involves grinding a link out.
I fitted the new timing chain with a split link fitted, which you can do with the 2 upper sprockets in place.
The replacement chain came from Mercedes Benz with the split link, I just had to remove a few links. If it's good enough for MB....
The MB chain was recommended via this forum, sorry can't remember who, maybe this will ring a bell and you'll get supplied with the part number.
*Remove alternator bolt, insert non compressible length of metal rod into the bolt hole (I use a cut down allen key, again sorry, I can't remember the exact length),
Refit bolt and tighten against the metal rod insert, Tap bolt head and the alternator should pop off the taper. Make sure you catch it. The lower sprocket behind the front engine chest is located
 via a woodruff key, don't loose it).
« Last Edit: July 23, 2019, 04:23:11 AM by Stevex »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #11 on: July 22, 2019, 03:48:08 PM »
Thank you SteveX et al. Very helpful ☺.
Offline Bob_Fla
« Reply #12 on: July 22, 2019, 05:00:23 PM »
Great information and pictures. Thanks everyone.
1984 Guzzi T5
1973 Hodaka
