Author Topic: V7 iii head bolt torques  (Read 2712 times)
Offline chrisk
« on: July 23, 2019, 07:14:31 AM »
Hi, gone through all 320 pages of the service manual on thisoldtractor and can’t find -
Torque for 4 main 15mm cylinder head nuts
Torque for the 12mm nut that bolts down the rocker assembly and the head..
Torque for the 7mm bolts that hold the retainers on the rocker shafts
Help please...
Re: V7 iii head bolt torques
« Reply #1 on: July 23, 2019, 07:22:56 AM »
Why have you had the heads off? If you haven't leave them alone. They are steel laminate gaskets that do not require re-tourquing.
Offline chrisk
« Reply #2 on: July 23, 2019, 08:33:05 AM »
One is off due to a leak
« Reply #3 on: July 23, 2019, 09:52:47 AM »
Help please...
This should help:
http://www.thisoldtractor.com/mg_manuals/workshop_manual_v7-iii-engine-750-euro-4_en.pdf
« Last Edit: July 23, 2019, 09:53:16 AM by Kev m »
Offline chrisk
« Reply #4 on: July 23, 2019, 09:59:53 AM »
Top man, thanks. Didn’t realise there was another manual lurking...
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #5 on: July 23, 2019, 03:46:05 PM »
I never did re-torque the heads on my 1985 850 T5.  It only has about 4500 miles on it, I regret to say.  I obviously will try to retorque them now.  Can it erode the sealing surfaces if not properly re-torqued at the first service?  Of course this is a big-bock Guzzi.
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
