Author Topic: MGX-21 running rough  (Read 7728 times)
Offline Luap McKeever
  • Owner, WildGuzzi.com
  • Administrator
    • Wildgoose Chase Moto Guzzi
« on: July 30, 2019, 06:11:55 PM »
The past several weeks this bike is running bad.  Not all the time, but it appears to be happening more when the temperatures are up.
I'm approaching 18,000 miles on it. It's mainly running rough at idle. Once up to speed it is still a rockstar, but idling rough is getting annoying. It's died on me a time or two as well. Today on my home from work pulling into a gas station it almost died and when I lost momentary power, I thought I was going to crash it until I got the engine speed back up.
Having never cleaned the throttle bodies, I'm wondering if I need to do that.  The plugs are new as I put them in at the last service, 12,000 I think. I try to run mid range fuel in it.
Thoughts?
Thanks,
Luap
2021 V85TT Centenario E5
2001 California Special
2001 California EV
2007 Honda Goldwing GL1800
Re: MGX-21 running rough
« Reply #1 on: July 30, 2019, 06:16:04 PM »
Single throttle body, but I hear what you're saying, especially if it carries oil over from the breathers. I'm just not sure what you can and can't do safely when cleaning it.
I was going to ask about plugs... You answered.
You sure about the plug wires? Insulation on them? Connection at coil posts? Insulation of coil itself.
Offline kballowe
  • - Kevin the Great -
« Reply #2 on: July 30, 2019, 06:19:08 PM »
Here's a thread for GuzziTech
https://www.guzzitech.com/forums/threads/california-1400-running-rough.17415/
run that thing in pitch black and see if you can find any little blue sparks
« Last Edit: July 30, 2019, 06:21:27 PM by kballowe »
  • Administrator
« Reply #3 on: July 30, 2019, 06:20:24 PM »
Yeah, the plugs are fine. It's strange. In the cooler mornings all is perfect. Then when the temp rises, it gets rough. Maybe a temperature sensor problem?...
2001 California EV
Offline SportsterDoc
« Reply #4 on: July 30, 2019, 06:23:03 PM »
Suggest you first pull plugs for a read.
Does your bike have an IACV?
If so, check connection...it may need cleaning or replacement sooner than the throttle body.
Is the mid-range fuel Tier 1?
Good suggestions from Kev M
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
« Reply #5 on: July 30, 2019, 06:26:27 PM »
 Sounds like a bad temp sensor , doesn't it . Is it loading up at idle ?
  • Administrator
« Reply #6 on: July 30, 2019, 06:27:39 PM »
I don't know if it has a control valve or not. Probably so.  Yes, mid range fuel is tier1, I usually try and run at least 90 octane in it.  Guess I'll pull the plugs again and have a look, but I did that about 1000 miles ago and they looked fine.
yeah it does load up a bit at idle.
2001 California EV
« Reply #7 on: July 30, 2019, 06:31:08 PM »
So that ECM thinks engine is still cold and enrichens mixture?
Quite plausible.
Would expect plugs to so indicate
Offline Bud
« Reply #8 on: July 30, 2019, 06:37:31 PM »
     How is it starting? Do you have to turn it over several times or does it fire off fairly quickly. Just wondering about the condition of the battery. What does the voltmeter read at idle and or when you start it.
« Reply #9 on: July 30, 2019, 06:43:12 PM »
Intermittent timing sensor that starts to open sometimes at high temp is a possibility.
Temp sensors, in my experience, tend to show faults more at startup then intermittently hot, but could be.
Any stored codes?!?
  • Administrator
« Reply #10 on: July 30, 2019, 07:08:58 PM »
Fires up quick...normal. It reads 13.5 volts at idle.
« Last Edit: July 30, 2019, 07:22:11 PM by Luap McKeever »
2001 California EV
  • Administrator
« Reply #11 on: July 30, 2019, 07:10:37 PM »
Any stored codes?!?
No engine light on, but I can check it this weekend with GuzziDiag. I actually thought about putting the OEM map back on it. I'm running a beetle map right now and it's been fine. But I think the map tweaks the temp sensor a bit to make the bike think it's cold.
2001 California EV
  • Administrator
« Reply #12 on: July 30, 2019, 07:23:39 PM »
FWIW, I just went out to verify the volt check and the bike would barely start and stay running until I fluttered the throttle a few times to keep it running. Once it leveled out, it's idling fine. But I believe this has something to do with a temp sensor or maybe the map?  It's getting quite annoying at this point.
2001 California EV
« Reply #13 on: July 30, 2019, 07:51:36 PM »
Is the motor still warm?!?
If the motor is cold and the map tweeked it to read colder then it would just be richer and likely still start.
I dunno... I'm skeptical but let's pull codes, maybe talk to Beetle about the map and go from there. No?
« Last Edit: July 30, 2019, 08:48:08 PM by Kev m »
  • Administrator
« Reply #14 on: July 30, 2019, 08:07:31 PM »
I'd the motor still warm?!?
Yeah it was still warm. I've reached out to Beetle.  Thanks for the ideas.
2001 California EV
beetle
« Reply #15 on: July 31, 2019, 12:18:29 AM »
No so.
I reckon I need to richen it up a bit in the hot weather.
I'll get onto that.
Online TN Mark
« Reply #16 on: July 31, 2019, 05:44:31 AM »
I’d guess the fuel map is fine since it previously ran fine. My Victory will do the same with a weak battery and/or slightly loose battery connections.
Offline s1120
« Reply #17 on: July 31, 2019, 06:59:35 AM »
Ya a fuel map doesn't "go bad"... well unless the ECU is going, but I doubt that...  Any other changes around the time it started acting up?
Paul B
  • Administrator
« Reply #18 on: July 31, 2019, 01:44:12 PM »
No other changes. It runs perfect in the cool mornings. Afternoons, not so much.  Beetle is working on a new map to help lean it out.
2001 California EV
Online TN Mark
« Reply #19 on: July 31, 2019, 05:57:13 PM »
I've run a custom map (dyno tune/PCV) on my bike for several years now. If it suddenly started running differently in different temperatures, one of the last things I'd suspect would be the fuel map.
I hope new map somehow fixes what went wrong without masking over another possible cause.
Offline Bulldog9
« Reply #20 on: August 01, 2019, 06:36:27 AM »
Dirty injectors? Bad fuel? Plug caps? Sometimes its the simple things.
Also, I wonder if it could be that aux air injector system with the reed valves near the exhaust ports. This is the small octopus system on the front left and front of motor just above the horns. I think the MGX is the only model with it, I've not seen it on any Eldo or Cali's. If the contraption works like it does on other vehicles it is supposed to put air into the exhaust stream when the engine is cold. If that system is malfunctioning it could be injecting air into the exhaust stream when hot and confusing the O2 sensor?.
Never mind... I just remembered you're running a beetle map and he shuts off the O2 sensors.
Still may be worth a look as well as checking over all the sensors and connections, and reflashing the map.
MGNOC#23231
  • Administrator
« Reply #21 on: August 01, 2019, 11:57:41 AM »
Beetle sent me a new map and I installed it yesterday evening. I was able to ride it around just a little and couldn't ride today due to rain. But, the preliminary result was encouraging. I'll have to wait until the weather clears and try again.
Stay tune :)
2001 California EV
« Reply #22 on: August 01, 2019, 12:13:52 PM »
Good, did you check plugs before and after?
If the map is not the full solution, suggest diagnostics on (1) oil temp sensor and (2) IACV.
Oil temp sensor is simple resistance measurement
  • Administrator
« Reply #23 on: August 01, 2019, 12:20:52 PM »
I checked the plugs about 1,000 miles ago and they looked good. If the map don't help, I'll chime back in for more guidance on those other things.  thanks.
2001 California EV
Offline Tkelly
« Reply #24 on: August 02, 2019, 10:47:03 AM »
How about mid grade gas in a Stelvio,any one have experience?I have always used premium an wonder if I am wasting money.
Offline jbhotchkiss
« Reply #25 on: August 02, 2019, 02:42:54 PM »
Long shot, but I'll chime in anyway.  When replacing the airbox with a pod filter on my Cali14 Custom, I noticed the center spark plug wire on the left cylinder was being pinched between the blow-by collector box and the cylinder, such that the insulation was wearing noticeably.  I widened the gap between the cylinder and the collector box and re-wrapped the wire in the area of wear and I think I'll be OK.  Worth a look I believe.
« Last Edit: August 02, 2019, 02:49:08 PM by jbhotchkiss »
  • Administrator
« Reply #26 on: August 03, 2019, 09:58:34 AM »
Thanks. I checked this and all is well.
2001 California EV
  • Administrator
« Reply #27 on: August 03, 2019, 10:00:02 AM »
2001 California EV
Offline jbhotchkiss
« Reply #28 on: August 03, 2019, 12:54:17 PM »
Looks like one good and three a tad rich?
beetle
« Reply #29 on: August 03, 2019, 05:42:42 PM »
I agree. A tad rich.
