Author Topic: Replacing Tonti headlight rim/bucket?  (Read 1651 times)
Offline yackee
« on: August 01, 2019, 07:54:11 AM »
The chrome headlight rim on my T3 is starting to get very rusty. I have looked a bit into replacing the headlight unit (for example, MGCycle has a replacement bucket/light unit: http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_154&products_id=4408). They also have a repro chrome ring for Eldorados, but apparently no repro rings are available for the Tonti headlight bucket.
But if I go the route of a replacement bucket I am at a loss as to how I would replicate (or deal with) the fact that the all of the bike's wiring goes through Molex connectors into the stock bucket. I recently replaced all my wiring with a new Greg Bender loom and don't want to start monkeying around with cutting wires etc.
I was wondering what others have done in this situation. I'd especially appreciate any details on the wire-through-the-bucket issue when dealing with a replacement bucket.
Re: Replacing Tonti headlight rim/bucket?
« Reply #1 on: August 01, 2019, 08:13:27 AM »
Rather than opening a "can of worms", why not just have the o.e. headlight rim rechomed?
Offline guzzista
« Reply #2 on: August 01, 2019, 10:06:20 AM »
+1. Path of least resistance ( pun intended) No need to dremel holes in the aftermarket bucket to avoid messing with new harness.  And to Charlie. Chrome plater(s)  you use and recommend?
« Last Edit: August 01, 2019, 10:09:36 AM by guzzista »
Online JoeW
    • The Guzzi Doctor
« Reply #3 on: August 01, 2019, 10:15:55 AM »
If the only issue with the headlight is the chrome ring, then have it re-chromed. My chrome shop charges me 100.00. These assemblies are rare and if you have all the pieces, (and there are a lot) by all means keep it stock. Harper's sells replacement gaskets that work with a little patience.
Joe Walano
« Reply #4 on: August 01, 2019, 11:46:06 AM »
I haven't found one that I'd recommend. I'm still mourning the closing of Brown's Plating. They once did all of the bits (including the exhaust) for a V7 Sport in 7 days, beautiful job, $2k. St. Louis Plating has had my latest batch for two months, they had the first batch for four months.
MG Cycle sells one also. http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_154&products_id=4546
