...Let someone else work on it.I dropped the pan and there is ridiculously awful black gunk in it slowly draining out before I even try to clean it out. It looks as if someone put moly in the oil, but lord only knows what it is. The previous owner certainly did not.Has anyone ever tried using an oil flush on the Lario or a small-block motor? I planned to get some cheap oil and sacrifice it and a filter to try to clean out the insides, but an oil flush would be better. Ideas?TIADaniel
Could be worse.
Malik, What caused this?
This was the carbed Nevada I bought for the frame - a rod had punched holes in the crankcase. One of the con rod caps on the big end had come off (& broke in two), the rod had jumped the crank & jammed the other one. All sorts of destruction in there. In dismantling the bike, it's my opinion that it had been serially abused in its 60,00km odd lifespan. The previous owner, young & inexperienced, only got 500km out of it before it disintegrated under her.
