Master cylinder size 850 GT
Topic: Master cylinder size 850 GT (Read 1029 times)
motogman
Gaggle Mentor
August 03, 2019, 06:27:59 PM »
What is the diameter (in order to buy a rebuild kit) for the front brake master cylinder on a '74 850 GT?
Furbo
Re: Master cylinder size 850 GT
Reply #1 on:
August 04, 2019, 08:36:54 AM »
I'm guessing....11mm as it was only supposed to operate one disc.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Antietam Classic Cycle
Happily stuck in the past.
Reply #2 on:
August 04, 2019, 08:39:08 AM »
There should be a number on the underside of the master cylinder that denotes what size it is. If it's the same master cylinder as used on the US market disc Eldorado, it's "15 mm" (actual piston diameter is 15.84 mm).
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_112&products_id=753
That 15 mm master cylinder was never a good match for a single F08 caliper (as on the Eldo), although it does work well with two F08s.
