Author Topic: Carburation question.  (Read 1385 times)
Offline injundave
« on: August 14, 2019, 04:52:04 PM »
As a general rule will fitting pod filters in place of the difficult to get at, original filters on the likes of a V50 or T3 necessitate any change in jetting? I ask because my daughter's V50 with pods seems to use gas faster than I remember with the original system and smells of fuel in the exhaust.
1975 850 T3
2019 V85TT
Offline lucian
Re: Carburation question.
« Reply #1 on: August 14, 2019, 06:01:41 PM »
Could be the  rubber seat inserts on the choke plungers.  You can try flipping them over .
Offline 80CX100
« Reply #2 on: August 14, 2019, 10:56:45 PM »
     I'm not familiar with the bike or carbs, but it sounds to me like your float needle(s) isn't/aren't seating properly and cutting off the fuel delivery into the carbs, wag.
     If the carbs are older and have never been rebuilt, new float needles & carb kits would probably be worth doing fwiw
     Edit re the pod filters, I think 5-10% richer jetting is usually called for,,, but with the increased gas usage and fuel smell, doesn't sound like that's the issue imo.
     Good luck
     Kelly
« Last Edit: August 15, 2019, 11:08:47 AM by 80CX100 »
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline malik
« Reply #3 on: August 15, 2019, 03:20:12 PM »
In situations like this, I'm a firm believer the efficacy of a dyno run. When I had the Carberry Enfield V Twin built, the only one with the Electra top ends, a stab was made at the jetting, but it ran at 6 to 8 L/100k. After I had it dyno-ed, and the jetting changed, it ran at 4.5 to 6 L/100k. And the dyno guy was really happy to work on a bike he didn't have to spend half a day removing plastics to get get access to hook up. With the dyno, you don't have to guess at the jetting.
« Reply #4 on: August 15, 2019, 03:24:18 PM »
Normally, when you fit up a more free breathing intake and or exhaust, you need to jet richer. It's counter intuitive to me for it to run richer with pods and no other changes..   <scratching head>
I think I'd look for other issues.
Offline antmanbee
« Reply #5 on: August 15, 2019, 04:39:44 PM »
Pods being over oiled can choke it.
