Author Topic: Brembo 15mm round master cylinder rebuild  (Read 5514 times)
Offline JC85
« on: August 24, 2019, 08:09:13 AM »
Is there a tutorial anywhere out there for doing this job?
'74 Eldo Police Model
'07 CalVin
Re: Brembo 15mm round master cylinder rebuild
« Reply #1 on: August 24, 2019, 08:21:10 AM »
Not that I've seen, but it's really quite simple. The piston is driven out using a length of rod inserted into the outlet. I use a suitably sized socket for pressing the new retaining ring into place during reassembly.
Offline JC85
« Reply #2 on: August 24, 2019, 10:02:55 AM »
 :thumb: Got it. Thanks for the tips.
'07 CalVin
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #3 on: August 25, 2019, 04:12:13 PM »
Couple/three photos for discussion re this subject...
What I would like to know is, given the lip-seal design of at least one of the two brake seals - does a person NOT need something like a piston ring compressor to insert the piston in the first place?  At the very least, brake assembly paste should be used.  This is non hydrocarbon "grease" like Silglyde or the like, to ease assembly.  To my mind, using brake fluid, instead, promotes rust... as the brake fluid beyond the sealed part of the brake system ... it is hygroscopic, and will attract moisture, and will rust the parts.  Silglyde or other will not.
« Last Edit: August 25, 2019, 04:22:17 PM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #4 on: August 25, 2019, 04:19:45 PM »
Incidentally, a PS15 Brembo is not exactly 15mm dia.  I think it is 15.875 mm by way of BORE, and the piston is mebe .3mm ??? less, by way of dia.  I think the cylinder is, actually, 0.625" or 5/8" bore.
« Last Edit: August 25, 2019, 04:20:18 PM by Cdn850T5NT »
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #5 on: August 25, 2019, 04:24:36 PM »
BTW, I cannot see how a socket would work unless it were a very, very thin-wall socket, and I can't see how the hex form or the 12-point form inside of the socket would not foul the piston of the Master Cylinder....?  I think a thin tube of the correct dia. is needed... like the MdinaItalia one.
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #6 on: August 25, 2019, 05:31:17 PM »
Tutorial:  https://www.laverdaforum.com/gallery/albums/userpics/11278/Repair_Guide_Clutch_and_Brake_Master.pdf
The fellow uses the old retaining ring, in backwards, to put the new retaining ring in place.  At least I THINK that is what is happening.  This is being done on a PS15 FRONT master... but the retaining ring system, and indeed the piston, seals, etc... ALL appear to be the same as the PS15 rear master on the Tonti Guzzi's.
« Last Edit: August 25, 2019, 05:39:01 PM by Cdn850T5NT »
« Reply #7 on: August 25, 2019, 07:23:51 PM »
I've done dozens with a socket as the insertion tool without a single problem of any sort. But, YMMV.
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #8 on: August 25, 2019, 07:30:40 PM »
Can't argue with success.  Do you use a particularly thin-wall 12 point socket... and is it 1/2" drive?  Also, do you have to wiggle the piston to get the lip-seal to enter the bore?
« Last Edit: August 25, 2019, 07:31:53 PM by Cdn850T5NT »
« Reply #9 on: August 25, 2019, 10:04:26 PM »
A regular old Craftsman 12-point, 3/8" drive socket. Yes, grease the seals with the supplied grease and move the piston around until the seals go into the bore.
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #10 on: August 26, 2019, 04:09:17 PM »
Thx Charlie.
Also, adding a picture of the properly assembled order of the components.  Retaining ring is on the extreme LHS... over top of the stepped rubber element
« Last Edit: August 26, 2019, 04:10:10 PM by Cdn850T5NT »
Offline n3303j
  • Ron Cichowski
« Reply #11 on: August 27, 2019, 09:40:36 AM »
Yes on the 5/8 bore. I found it odd that these were exact SAE dimensions. On the other hand it simplified sleeving the master cylinder when I had to deal with a pitted one. K&S sells seamless brass tubing to the hobby industry. Their 21/32 stock has a 5/8 bore. Ream the casting to 21/32. Loctite in an appropriate length of brass tubing and drill the cross hole  (polish off the burr). Then you are set for another 40 years.
T3 rear master cylinder was also SAE bore.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Tusayan
« Reply #12 on: August 27, 2019, 09:47:50 AM »
As with wheel and handlebar diameters, it is common for brake cylinders to be sized in inches.  Also true for Japanese parts.  1/2 inch diameter for a single front disk and 5/8 inch for dual disks.
https://www.randakks.com/upgraded-front-master-cylinder-version-a-5-8-piston.html
« Last Edit: August 27, 2019, 09:49:10 AM by Tusayan »
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #13 on: August 27, 2019, 11:42:32 AM »
Excellent to know this...  I assume that the Loctite is not attacked by brake fluid...  Others like Whitepost Restorations I believe create an interference fit... but I would bet that the aluminum casting that comprises the Master is not meaty enough to allow this.
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #14 on: August 27, 2019, 11:45:22 AM »
Thx for the info!  Unfortunately the link you provided does not work...
« Last Edit: August 27, 2019, 11:46:51 AM by Cdn850T5NT »
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #15 on: August 27, 2019, 11:56:29 AM »
A comment re sleeving to a brass bore:  It seems to me that the OEM cylinder is anodyzed aluminum which I believe has a measure of corrosion protection by having that anodyzation (sp?).  Brass, not so much.  Critical, then, to flush brake fluid yearly, as brake fluid is hygroscopic - and will corrode the brass bore.  Do folks agree?
« Last Edit: August 27, 2019, 11:58:01 AM by Cdn850T5NT »
« Reply #16 on: August 27, 2019, 12:00:38 PM »
Works fine for me.
Stainless steel would have been a better choice for the sleeve and is what rebuilders normally use.
Offline n3303j
  • Ron Cichowski
« Reply #17 on: August 27, 2019, 01:12:52 PM »
Works fine for me.
Brass was what was available in the proper dimensions.
I did throw a piece of the same tube into a clear bottle of brake fluid about 10 years ago to monitor the effect of DOT 3 on the tubing. So far the tubing looks unchanged.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #18 on: August 27, 2019, 01:39:46 PM »
Excellent test.  If the brake fluid in the jar is open to the atmosphere, then any hygroscopically taken-up moisture would have done its job rotting the brass.  If no, that's great.  Mind you, it would also take oxygen to cause rot.  So, the areas of the master cylinder or the caliper bore that alternatively see air, and then see brake fluild (as piston movement occurs) - those are the ones that rot out.  So I'm not sure submerging the brass in brake fluid really is a test.  If the brake fluid gets darker as time goes on, that is corrosion-product going-in to the fluid.  If it remains more or less straw-coloured - no corrosion is occurring.
« Last Edit: August 27, 2019, 01:45:36 PM by Cdn850T5NT »
