Author Topic: Ryan's V50II resto  (Read 4834 times)
Offline ryanolivieri
  • 1980 V50II
    • Contracting website
Ryan's V50II resto
« on: September 11, 2019, 08:58:54 AM »
I waited to post this bike until I actually had it running.  It only took me 5 years.  All new plumbing and electrical, lots of freehand metalwork, rebuilt forks, calipers, a few junkyard goodies from Italy. Check it out.  Sorry for the caps, I ripped it from my website.
BEFORE
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_5.jpg[/img]
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_6.jpg[/img]
CURRENTLY
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_3.jpg[/img]
ITALIAN COP SEAT AND HOME MADE GAUGE CLUSTER, FRONT FENDER MOUNTED TO STEERING HEAD
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_4.jpg[/img]
LUGGAGE RACK FROM HARPERS, WHEELS SPRAYED WITH PPG OMNI ARGENT SILVER
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_7.jpg[/img]
PINION STEERING HEAD BEARINGS, STANDARD TRAILER TAIL-LIGHT
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_8.jpg[/img]
ITG FOAM FILTER WITH CUSTOM WATERJETTED MOUNTING PLATE
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_9.jpg[/img]
ELEKTRONIK SACHSE REG4 VOLTAGE REULATOR, VELOCITY STACKS OF FORGOTTEN ORIGIN
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_10.jpg[/img]
MOST ALUMINUM SHEET SALVAGED FROM APPLE G4 POWER PC TOWER
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_11.jpg[/img]
5 OHM DYNACOILS, CRANKCASE VENTS TO ATMOSPHERE FOR NOW, PUSH/PULL IGNITION SWITCH
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_12.jpg[/img]
ANTIGRAVITY AG-1601 BATTERY 480 CCA 16-Cell, LARGE BLADE GROUND DISCONNECT
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_13.jpg[/img]
CUSTOM BRAIDED STAINLESS PTFE BRAKE TUBING/FITTINGS FROM BAT/MOCAL THROUGHOUT
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_14.jpg[/img]
M-UNIT V.2 AND ELEKTRONIK SACHSE ZDG3 IGNITION, FRESH MASTER CYLINDER LINKED TO FRONT/REAR BRAKES
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_15.jpg[/img]
BILLET BRAKE FLUID RESERVOIR, BLUE SEA FUSE BLOCK
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_16.jpg[/img]
GAUGE CLUSTER MADE FREEHAND, PNEUMATIC FRONT SHOCKS LINKED, MOTOGADGET PUSH BUTTON CONTROLS, VDO VOLT AND OIL PRESSURE GAUGES
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_17.jpg[/img]
ANTIGRAVITY AG-1601 BATTERY 480 CCA 16-Cell, LARGE BLADE GROUND DISCONNECT, BILLET BRAKE FLUID RESERVOIR
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_18.jpg[/img]
AMAZON HEADLIGHT BUCKET: CHROME STRIPPED TO NICKEL, MOST ALUMINUM FINISHED WITH VERY FINE SAND BLASTING AND OILED
[img width= height=]http://www.ryanolivieri.com/_images/MOTO_GUZZI/V50II_19.jpg[/img]
« Last Edit: September 11, 2019, 09:02:27 AM by ryanolivieri »
ryanolivieri.com/MOTO_GUZZI
Offline SED
Re: Ryan's V50II resto
« Reply #1 on: September 11, 2019, 11:21:05 PM »
Looks great.   front fender looks street trackerish.
You must be an electrician?!
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline Frenchfrog
« Reply #2 on: September 12, 2019, 03:32:07 PM »
Wow thats some rebuiild ! how did you connect the oil pressure sensor ?
Offline Rick4003
« Reply #3 on: September 13, 2019, 05:43:40 AM »
Very nice rebuild.
I like your electrical setup, similar to mine. I do need to clean my wiring up during winter. It didn't turn out as well as I would have liked.
I am curious to know how you like the moto gadget two button indicator setup. I greatly dislike it if I have to be honest. It is one of the first things to be changed in winter.
Thanks for sharing your project!
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
