LeMans 1 Shock Disassembly
Topic: LeMans 1 Shock Disassembly (Read 849 times)
fasduc
New Egg
September 14, 2019, 01:37:39 PM »
Need to ask, once the spring is compressed, how do these shocks come apart? I don't see a circlip or retainer clips at the top like most shocks. See pics.
Thanks,
Chris
1977 Moto Guzzi LeMans 1
1997 Ducati M750
2011 Moto Guzzi V7 Racer
2012 MV Agusta Brutale 1090RR
2022 BMW R1250RT
Loop Tonti EV
Re: LeMans 1 Shock Disassembly
Reply #1 on:
September 14, 2019, 03:01:03 PM »
If you're wanting to remove the springs it's done at the adjuster ring at the bottom I believe. There should be open slots in the preload ring that when turned to lign up with the dogs on the cartidge they will slide down off. You'll need a press or tool to compress the springs. My original Eldorado units looked similar and that's how they come apart.
Antietam Classic Cycle
Happily stuck in the past.
Reply #2 on:
September 14, 2019, 04:20:45 PM »
Same as Loopframe shocks:
http://thisoldtractor.com/moto_guzzi_loopframe_shocks_-_tear_down_and_rebuild_of_the_stock_shock_step_1__outer.html
If you're going in farther:
http://thisoldtractor.com/moto_guzzi_loopframe_shocks_-_tear_down_and_rebuild_of_the_stock_shock_step_2__inner.html
Last Edit: September 14, 2019, 04:33:05 PM by Antietam Classic Cycle
fasduc
New Egg
Reply #3 on:
September 15, 2019, 11:16:17 AM »
Thank you!
1997 Ducati M750
2022 BMW R1250RT
