Perhaps the master cylinder is out of adjustment and the piston is not moving back far enough to uncover the return hole.As its been dropped it may be a little bent to put it out of adjustment, if you take the top off you should be able to see the hole.
2007 Nevada 750. The bike has been dropped a couple times by the previous owner due to the front brake locking up.
Both seals should face the mc outlet. That is the larger diameter should face the direction of applied pressure. First picture is correct.Brian
My recollection is the large thin washer goes between the seal and the holes in the piston. Yes, the bleed-back port is very tiny - about the diameter of a pin. I'll bet it's clogged.
Can you blow low pressure air through the m/c with the piston in the retracted position ?If you can, it’s not blocked.
So far the bike is doing exactly what I bought it for, to be a good platform for tinkering. Great recreation!
And.... it's a good feeling to "fix" a mysterious problem. Especially when several others gave up - in fact selling the bike as-is and not even letting you know there was a problem. Pretty funky finding out about a dangerous thing like that on your own. I pretty much expect issues with used stuff I get, whether a yard sale find or a used bike. The challenge of making it right is fun - puzzles without cut-and-dried solutions that force you to think outside the box.
