If I understand it right. It appears that both types are measuring the vacuum at the manifold and that it's just two different tools to do the same job.I think I got it?Tom
Kinda right.You are measuring and calibrating to inches of mercury. Not inches of some other liquid. Mercury is over 7 times heavier than water. The scale marking of a water filled gage would have to be over 7 times greater between marking to equal 1 inch spacing between mercury markings. Also, the i.d. of the column (tubing) determines the spacing on the scale. There is a specification on what the mercury column weight/height should be on an idling engine. There is a tolerance between two or more intake points also. If you use a light liquid verse mercury, You could be really close if the two columns (or more on multiple cylinder) with a light liquid and a difference of 5 inches between any of them. Unless you calculate column/tube i.d., liquid weight, scale spacing ratio, the accuracy of a home made set up is a guess. Go buy some real gages. The new vacuum gages work great. Save the liquid in a tube for a level between two points.
Sorry, as someone who spent much of my working life figuring out how to measure stuff in an industrial setup I must take exception.In the case of a throttle balance manometer we are not really interested in measuring relative to atmospheric pressure just the pressure difference between left and right manifolds and we don't really care about the numbers so we don't need a scale marking. Water is fine for that although I prefer something lighter still, engine oil as it has the added advantage of a high viscosity with it's added dampingMercury is 13.663 times as dense as water. yes you can if you want to measure inches of mercury using water or oil or any other liquid for that matter.The ID of the column has nothing to do with it, for a given pressure the fluid rises the same distance up a small tube as a large tube, its pressure and density that matter.A manometer is a real gauge, it's used as a standard to set Bourdon tube gauges against.The problem with using Bourdon tube gauges is you now have 2 or more "Gauge pressure" numbers you have to juggle in your headWith a manometer you just have a single "Differential Pressure" which you only need to reduce
Do I have this right?
Manometer body in general is set to VENT;[/color] I assume you are referring to the valve to each manifold is open, both sides of the manometer and the reservoir should be under vacuum otherwise you could suck mercury into the motor
The Motion Pro mercury filled manometer comprises a plastic reservoir, into which four plastic-encased glass columns are affixed (at the top). Said glass columns go to the bottom, or well-nigh to the bottom of the plastic reservoir. At the top of each, a rubber tube is attached... and if memory serves, there is an orifice that fits into the rubber tube, there... (or the orifice is in the rubber tube, at the other end... where it attaches to the bike's manifold. There are four rubber tubes, four columns. When the hose is NOT used, at the top of the Motion Pro device there are "nipples" where the un-used hoses plug-in to... so that the mercury does not evaporate-away (which is hazardous). The reservoir, below, has a short hose off the top of the reservoir, and it plugs-in to an air-tight nipple nearby, or a vent-type nipple nearby - which allows the top of the reservoir to be vented to atmosphere when in use.So, the way I use the device... is the two unused hoses / columns remain attached to the no-vent nipples at the top of the device. The vent on the reservoir gets shifted from Air Tight to Vented to Atmosphere... and the two intended-to-be-used columns / hoses are put onto the manifolds... ONLY once the bike is started-up, warmed up, etc.... At the last moment the manifold-plugs are removed and the hoses are attached.... so as to NOT lose the mercury into the bike's intake tract! No blipping of throttles when attached!
For anyone wanting to try the Corona beer bottles here's a good demohttps://www.youtube.com/watch?v=7D_f05_a74YI use a "U" tube manometer filled with engine oil myself but I would give this a try for sure. its compact and self standing.One thing you might want to do on a Guzzi is finish your hoses off with a short length of rubber otherwise they fall off the nipple when it gets hot.
Thanks for the description, so you really have 4 individual vacuum gauges with a common reservoir, the glasses must be quite tall since each column is referenced to atmosphere. The restriction in the hoses is so that if you suddenly apply the vacuum the mercury doesn't rush up the tube well past where it would normally sit and spill out the top, don't ask me how I know.Many of the industrial ones have a catch pot or a cork valve that slams shut and they are vented outside.One way to stop the mercury from evaporating is to put a drop of oil on the surface but its ok if you just keep it closed off
We used to use mercury in the instrument shops because but it's pretty much banned as being too dangerous nowadays. Spilling a mercury manometer in your garage would be considered a major environmental disaster these days.
I used to synch my H2 (three carbs) by sticking nails or pencils under the slides and opening the throttle slowly while watching. Not bragging, just establishing a baseline for further assessments of my competency. And I loaned my store-bought carb-synch tool to a friend who got carried away with the throttle and sucked the mercury into his engine.
I use that method on my 72 Eldorado, it has no taps for a manometerOh dear, I hope he was outside.If you read through your local work safe regulations regarding Mercury it will put you off using it.
I had the same problems with mine - bubbles in the columns. Got a twinmax and the mercury gauge has collected dust ever since. I'm going to try the corona manometer and compare against the electronic. That oughta be interesting.
Can anyone suggest a sure-fire method to i) clean out (what we think is) gasoline liquid / vapour "bubbles" / gaps in the mercury column; and ii) KEEP said gasoline from getting-in to the piping / columns in the first place?
I was told by more than one person, that if you put it under a vacuum for a while all would be right again. i sealed mine up and used my vacuum pump. Left it that way for a few weeks. It never did clear up.
Can anyone suggest a sure-fire method to i) clean out (what we think is) gasoline liquid / vapour "bubbles" / gaps in the mercury column; and ii) KEEP said gasoline from getting-in to the piping / columns in the first place?With all of the necessary cautions in dealing with mercury, I imagine you could pour-out (from the reservoir) the mercury and you might be able to strain it through some panty-hose / womens' nylons. You obviously are not straining-out gasoline... but there may be other contaminants that are not liquids. And then, possibly, the gasoline could either leave a varnish (as it flashes-off, or as it "spoils") on the inside of the glass tubes: you could buy a super-long pipe cleaner... to rod-out the columns???? Or a really small diameter wooden dowel... and a rag on same? You would NOT want to lose the rag down the tube, though! What kind of cleaning solvent could aid in cleaning-out the bores of the tubes (bearing in mind that the reservoir itself is plastic - not sure what type, possibly polystyrene?)? If you use the air-in-the-syringe trick to push-out the gasoline, get it to FLOAT on the top of the mercury.... do you even NEED to clean out the bores of the glass tubes?Do any of you have suggestions. I know that per the post, above, I am NOT the only person experiencing these "bubbles" / gaps in the mercury columns. I have to wonder HOW, with mercury about 15 times more dense than gasoline... HOW it could happily sit ABOVE the gap or bubble? It seems so implausible to me.I want to save $ (and I like the theoretical accuracy of the Hg columns) - but I know that with bubbles in the columns, they are NOT accurate.I suppose you could test-out your cleaning success by using a MityVac on it... to see that the columns remain gap-free.TIA!
Can anyone suggest a sure-fire method to i) clean out (what we think is) gasoline liquid / vapour "bubbles" / gaps in the mercury column; and ii) KEEP said gasoline from getting-in to the piping / columns in the first place?With all of the necessary cautions in dealing with mercury, I imagine you could pour-out (from the reservoir) the mercury and you might be able to strain it through some panty-hose / womens' nylons. You obviously are not straining-out gasoline... but there may be other contaminants that are not liquids. And then, possibly, the gasoline could either leave a varnish (as it flashes-off, or as it "spoils") on the inside of the glass tubes: you could buy a super-long pipe cleaner... to rod-out the columns???? Or a really small diameter wooden dowel... and a rag on same? You would NOT want to lose the rag down the tube, though! What kind of cleaning solvent could aid in cleaning-out the bores of the tubes (bearing in mind that the reservoir itself is plastic - not sure what type, possibly polystyrene?)? If you use the air-in-the-syringe trick to push-out the gasoline, get it to FLOAT on the top of the mercury.... do you even NEED to clean out the bores of the glass tubes?Do any of you have suggestions. I know that per the post, above, I am NOT the only person experiencing these "bubbles" / gaps in the mercury columns. I have to wonder HOW, with mercury about 15 times more dense than gasoline... HOW it could happily sit ABOVE the gap or bubble? It seems so implausible to me.I want to save $ (and I like the theoretical accuracy of the Hg columns) - but I know that with bubbles in the columns, they are NOT accurate.TIA!
And, amazingly, here is a source for mercury if you need it: https://www.saber-cycle.com/store/product1003.htmlAMAZING that they still have this.
